traveler #101855
03/27/07 03:24 PM
03/27/07 03:24 PM
dallas tx
airborne Offline OP
airborne  Offline OP
dallas tx
I have a nacra 5.2 and I need to know the line length and the diameter of the line for the traveler. It is separate from the main sheet. What are the pros and cons of having the two separate.
thanks airborne
nacra 5.2 #2410 live long and prosper
Re: traveler [Re: airborne] #101856
03/27/07 06:39 PM
03/27/07 06:39 PM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
Airborne,
I have tried it both ways and prefer it to be separate. I set my length to have two extra feet of line to grab hold of when the traveller is let all the way out. I still have the center bar (knee breaker) on my tramp and I stuff the line under the bar after I set the traveller. I use 3/8 line but I'm not sure what the standard is. Hope this helps. Sorry about not getting any pictures to you. Short story is that my digital camara is unavailable.
-Rob V.
Rob V. Nacra 5.2 Panama City
Re: traveler [Re: airborne] #101857
03/27/07 07:28 PM
03/27/07 07:28 PM
catman Offline
catman  Offline
I have a 1/4" line for my traveler. The smaller line runs through the blocks with less friction. So when you want to let the traveler out it can.
I attach the end of that line to the end of my mainsheet. As far as lenght, Mine is about a foot longer than the distance the traveler car can move from center. If your boat is 8' wide then about 5' should be enough.
Re: traveler [Re: Redtwin] #101858
03/27/07 09:26 PM
03/27/07 09:26 PM
rob, get it right, it's a "knee knocker". <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
I tie a separate line so I don't have to undo a very tight line at the beam (where the traveler line dead-ends). However, recent sailing with David Lennard has shown me a knot that keeps that from happening.
That said, I intend to start running one of the composite braided lines for a mainsheet - and they don't lend themselves to a split tail used on many of the Nacra boat traveler lines....so we'll need to continue running a separate traveler and sheet line.
Re: traveler [Re: catman] #101859
03/27/07 09:26 PM
03/27/07 09:26 PM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
Perhaps you should consider more like 9 ft. because of the 2:1 effect.
Re: traveler [Re: Redtwin] #101860
03/27/07 11:10 PM
03/27/07 11:10 PM
dallas tx
airborne Offline OP
airborne  Offline OP
dallas tx
Thanks alot guys,just 1 more question on this. I have a pulley or block on the center of the rear beam, from what I understand I tie a knot at the end of the line then run through the pulley than through the traveler than the eye and cleat, is this correct?
thanks again airborne
Re: traveler [Re: bobcat] #101861
03/27/07 11:13 PM
03/27/07 11:13 PM
catman Offline
catman  Offline
No. There's no point in having anymore smaller line. I don't want to handle the small line. With it attached to the end of the mainsheet I am able to work the traveler (smaller line) with the mainsheet (larger line).
I suggest it be a foot or so longer because of the knots that are tied.
Re: traveler [Re: airborne] #101862
03/28/07 04:28 AM
03/28/07 04:28 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Youve lost me here, is your cleat on the moving traveller or fixed to the back beam?
Re: traveler [Re: airborne] #101863
03/28/07 06:09 AM
03/28/07 06:09 AM
Sydney/Northern Beaches
Bandit Offline
Bandit  Offline
No its not correct.
Your rope ties off to your traveler. The rope then goes through your pully in the center of your beam. Then through the twin roller in your traveller and into your cleat.
Re: traveler [Re: Jake] #101864
03/28/07 07:34 AM
03/28/07 07:34 AM
Jake, I run a split tail mainsheet/traveler and the knots are difficult to undo, but I have the luxury of mast up storage with everything still on the boat- blocks and all. Wanna share that knot though?
Re: traveler [Re: PTP] #101865
03/28/07 08:28 AM
03/28/07 08:28 AM
Sure, it's really simple.
Run the line through the eyestrap. tie a simple square knot in the very end of the line (just on the line itself). Then tie another simple square knot around the eyestrap. That's it. I wouldn't believe that it would be easy to undo, but I've helped David de-rig the boat twice now and both times it was extremely easy to remove both square knots even after sailing in some substantial breeze.
Re: traveler [Re: Bandit] #101866
03/28/07 03:52 PM
03/28/07 03:52 PM
dallas tx
airborne Offline OP
airborne  Offline OP
dallas tx
Thanks, yes I did have it wrong. The cleat is fixed in the center of the rear tube.
airborne
Re: traveler [Re: airborne] #101867
03/28/07 05:43 PM
03/28/07 05:43 PM
Redtwin Offline
Redtwin  Offline
airborne
I have a single block attached to an eyestrap on the back of the rear beam too. I have no idea what it is for. I am going to change over to 1/4 like Catman uses. I do have some problems getting the traveller to play out in lighter winds. I'll try to dig up some old pictures to see if any have a shot of that block on the rear beam.
-Rob V.
Re: traveler [Re: Redtwin] #101868
03/28/07 05:48 PM
03/28/07 05:48 PM
I know exactly the block you are talking about. Mine had one there too - it was riveted inside an eyestrap. I never did figure out what in the world that was for.
Re: traveler [Re: Jake] #101869
03/28/07 05:55 PM
03/28/07 05:55 PM
Redtwin Offline
Redtwin  Offline
Here is a poor quality picture of it back when I was using a single line for the mainsheet and traveller. For those of you who don't know or can't make it out in the photo, there is a single block hanging on the eyestrap off the back center of the rear beam. Any ideas what this could be used for?
-Rob V.
Re: traveler [Re: Redtwin] #101870
03/29/07 01:17 AM
03/29/07 01:17 AM
Bandit Offline
Bandit  Offline
Its to create a 2:1 system on your traveler..
Re: traveler [Re: Bandit] #101871
03/29/07 07:10 AM
03/29/07 07:10 AM
yeah, but it just doesn't work very well for that. It won't center and the block usually get's caught on the eyestrap when you tack or gybe.
Re: traveler [Re: Bandit] #101872
03/29/07 07:29 AM
03/29/07 07:29 AM
Santiago, Chile
Andinista Offline
Andinista  Offline
Santiago, Chile
3:1 actually
Re: traveler [Re: Andinista] #101873
03/29/07 07:45 AM
03/29/07 07:45 AM
Bandit Offline
Bandit  Offline
I stand corrected
In reference to the pulley getting caught in a gybe I have never had that problem or any other problems with it so maybe your pulley is mounted differently?
Re: traveler [Re: Bandit] #101874
03/29/07 08:09 AM
03/29/07 08:09 AM
Do you really need purchase on the traveler?
0 registered members (), 442 guests, and 27 spiders.
