| Re: mast seal
[Re: binga]
#104146 04/18/07 07:16 PM 04/18/07 07:16 PM |
Posts: 12,310 South Carolina | First; nothing floats better than air. Adding foam inside the mast actually makes it slightly less buoyant and while it does provide a degree of protection should your mast take on water, you run the risk of the foam trapping water inside that you can't get out. If you are going to seal your mast, just seal it using silicone on 3M 5200.
Are you trying to plug up some really large holes?
Jake Kohl | | | Re: mast seal
[Re: binga]
#104147 04/19/07 05:22 AM 04/19/07 05:22 AM |
No tall blue foams are the same. Contact Phill Brander, he can tell you which types of foam to use. The foam I used was a cut off he send me so I don't really know what it was exactly but it was excellent for the job as it was a little bit rubbbery and would jam nicely in the mast.
| | | Re: mast seal
[Re: binga]
#104149 04/19/07 07:56 AM 04/19/07 07:56 AM | Anonymous
| Anonymous
Unregistered | Phillbrander(at)bigpond.com
replace (at) with @ | | | Re: mast seal
[Re: binga]
#104150 04/19/07 07:58 AM 04/19/07 07:58 AM | Anonymous
| Anonymous
Unregistered | Why do they put a foam piece below above the internal downhaul inside the mast? Thanks Andrew So if you turtle, your mast does not fill up with water making it impossible to right. | | | Re: mast seal
[Re: Inter_Michael]
#104152 04/19/07 11:48 AM 04/19/07 11:48 AM |
Sikaflex is what also used as sealant.
| | | Re: mast seal
[Re: Wouter]
#104153 04/19/07 04:24 PM 04/19/07 04:24 PM |
Posts: 3,528 Looking for a Job, I got credi... | Last weekend at Datchet we (hopefully) sealed Paul's Blade mast with Epoxy Foam.
You mix it up and then put it in and it expands to about 4x mix volume.
Hopefully Job's a goodun.
F16 - GBR 553 - SOLD I also talk sport here | | |
339
guests, and 200
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
