| Light air #109225 06/08/07 07:35 AM 06/08/07 07:35 AM |
Posts: 1,152 tampa, fl | Last night I was sailing in our weekly beer can race on my N20 and the winds were light....in the 4-6 knot range. When sailing downwind under spin in winds this light, is it fast to sail a higher course, or just suck it up and sail deep and slow. There were a couple of A cats on the course, and I can usually out run them down wind, but last night, I could not gain at all. They seemed to be sailing much deeper than I was. Also there were a couple of Melges 24's that actually overtook me down wind sailing much deeper than I was.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Light air
[Re: fin.]
#109227 06/08/07 07:53 AM 06/08/07 07:53 AM |
Posts: 37 | Not sure. Never sailed in light air with Melges 24's but I know that it is not uncommon for them to beat a N20 around the bouys in that kind of stuff. I would say that you would probably want to try to really play the downwind angle alot , heading up when it feels to be decelerating and down when you have some speed. Just make sure you've got boards mostly up (windward board all the way up), downhaul off, keep your weight forward, trim the jim and make sure the chute stays full. That is assuming everything else on the boat is well setup (mast rake, diamond tension, ect..)
-Alan Stewart
Team Velocity Sailing; Crew N20
spare time; Hobie 18
| | | Re: Light air
[Re: Chris9]
#109230 06/08/07 09:19 AM 06/08/07 09:19 AM |
Posts: 12,310 South Carolina | Did you have you spin halyard tight? If so, ease off 6" or so. If you have a tack line, try easing that as well or instead. You may want to check your main and put on more downhaul and maybe even less mainsheet. If your boards were up and you were sailing high you may have been crabbing sideways.
I don't know about the melges, that is a big spin and in 4-6 it was helping them. Not unusually with the A Classers. Loosen the spin luff? That allows the kite to rotate to leeward which is not what you want if you are trying to go deep. Loosen the luff if you want to go high. It is contrary to intuition, but you should tighten the luff to bring the kite further to windward to keep it in the flow for deep downwind sailing.
Jake Kohl | | | Re: Light air
[Re: Todd Berget]
#109232 06/08/07 09:40 AM 06/08/07 09:40 AM |
Posts: 1,152 tampa, fl | That's pretty much the way I had set the boat up. Traveler eased a couple inches, main eased (not nearly enough wind to put the mast in peril), crew on main beam on leward hull, me on tramp at main beam holding the mast fully rotated with my foot, jib eased, and boards up about half way. To keep any speed in the boat, I was pointing so high that I seemed to be making very little progess towards the leward mark.
[Re: ksurfer2]
#109233 06/08/07 09:53 AM 06/08/07 09:53 AM |
Posts: 3,293 Long Beach, California | Mike Wilson taught me (at least, I learned from losing to him) that you have to know when to change gears to low-and-slow. It feels slow, it sounds slow (no reassuring burble from your transoms), but it works in light air. Make sure you know if there is current - if there is, and it is flowing toward your mark, keep those boards down! Ride the magic carpet! <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
| | | Re: Light air
[Re: ksurfer2]
#109234 06/08/07 10:09 AM 06/08/07 10:09 AM |
Posts: 1,307 Asuncion, Paraguay | To keep any speed in the boat, I was pointing so high that I seemed to be making very little progess towards the leward mark. It seems to me that you were sailing in less than 4 knots of wind. In very light conditions it pays to sail like a monohull.
Luiz
| | | Re: Light air
[Re: DanWard]
#109236 06/08/07 11:05 AM 06/08/07 11:05 AM |
Posts: 833 St. Louis, MO, | I agree with Dan.
Two points: 1. Head up in the lulls looking for the next puff. Ride the puff down deep and use it. Jibe on it if possible to ride it longer.
2. Keep your boards all the way down. This keeps flow and the boat going the right direction. I've been passed too many times by boats with boards down going downwind in light air (under 4 knots). This doesn't apply over 4 knots.
Mike Hill
Mike Hill N20 #1005
| | | Re: Light air
[Re: Mike Hill]
#109237 06/08/07 11:22 AM 06/08/07 11:22 AM |
Posts: 12,310 South Carolina | My motto on non-air lake sailing: "If we're going to drift, might as well drift toward the mark".
#109241 06/08/07 10:21 PM 06/08/07 10:21 PM |
Posts: 1,200 Vancouver, BC | I agree with Jake...tensioning the spin halyard adds draft/shape to the luff of the spin....while easing flattens it. You can test this while ashore with the sail raised and sighting along the luff under different tensions. You can get more tension by putting more pre-bend in the pole end if needed. Keep the spin loose-sheeted in the light...just enough to keep her inflated...luff should curl and re-fill periodically. Over sheeting is death! Sail as high as needed to get moving, but don't go crazy trying for more speed or hull flying until true winds are beter (typically 6-8 kts TWS is the transition for the Tornado) Keep all weight as forward as possible...keeps the transoms out and boat glides silently. I've found it a big benefit for one person to steer & run the spinny at the same time. Makes coordinating moment by moment adjustments so much better...lees over-correcting on both the helm and sheeting with each wave/puff. In the real drifters, consider popping a rudder and a board or boards up...but like others have said, take current affects into consideration. Did you have you spin halyard tight? If so, ease off 6" or so. If you have a tack line, try easing that as well or instead. You may want to check your main and put on more downhaul and maybe even less mainsheet. If your boards were up and you were sailing high you may have been crabbing sideways.
175
guests, and 87
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
