Nacra 5.2 balance #111502
07/11/07 07:09 PM
07/11/07 07:09 PM
San Francisco
TSurfer Offline OP
TSurfer  Offline OP
San Francisco
I've run into a bit of a problem solving boat balance in heavier air (18-25kts).
I have a decent main and I used to have a fairly beat up jib with my mast slightly raked (almost straight) and the boat felt very well balanced going to weather while double trapped roughly between the crossbeams but a little towards the aft one.
Since then, I purchased a new jib.
Now the bows really want to surge downward and the crew and I are positioned much further aft than before. I tried raking the mast back 2 more holes but I'm still experiencing
what seems to be excessive downward attitude. It's manageable but just doesn't seem correct.
I've raked the rig back as far is it will go but have yet to test that and I'm quite sure I'm going to run into unnecessary weather helm.
Any suggestions would be appreciated.
Tim S. Urfer 1984 Nacra 5.2
Re: Nacra 5.2 balance [Re: TSurfer] #111503
07/12/07 02:18 AM
07/12/07 02:18 AM
Zurich
Daniel_Gut Offline
Daniel_Gut  Offline
Zurich
Can it be that your new jib has the clew higher up than the old jib? That would change the sheeting angles and close the top of the sail?
Regards
Daniel
Re: Nacra 5.2 balance [Re: Daniel_Gut] #111504
07/12/07 11:19 AM
07/12/07 11:19 AM
San Francisco
TSurfer Offline OP
TSurfer  Offline OP
San Francisco
I compared the the two jibs and the clew is in the same position. The difference between the two is the old one
is cross-cut and the new one is radial cut.
Maybe it's just the fact it's a new sail and the old one was so blown out?!? Even still, I would expect to be able to adjust for this.
0 registered members (), 294 guests, and 30 spiders.
