| Re: What is a stronger bond/ repair ?
[Re: MarkW_F18]
#116241 09/05/07 09:32 AM 09/05/07 09:32 AM |
Posts: 833 St. Louis, MO, | Option 1 for sure. 5200 is better as sealant. It's decent as glue but I'd go with West.
Mike Hill N20 #1005
[Re: MarkW_F18]
#116242 09/05/07 09:32 AM 09/05/07 09:32 AM |
Posts: 3,528 Looking for a Job, I got credi... | Clean it out well,
Open it with the screw driver and then epoxy it
Close it down tight, clamp it and keep it warm.
I sailed for about 9 months with a rudder fixed like this no problem
F16 - GBR 553 - SOLD I also talk sport here | | | Re: What is a stronger bond/ repair ?
[Re: fin.]
#116244 09/05/07 10:40 AM 09/05/07 10:40 AM |
Posts: 3,528 Looking for a Job, I got credi... | How old is your epoxy? I am currently having a problem with an epoxy mix not curing properly.
I'd test a small sample and make sure all is well. Ahhh; Good point; make sure it is almost in date.
[Re: fin.]
#116245 09/05/07 10:50 AM 09/05/07 10:50 AM |
Posts: 12,310 South Carolina | West System is really good about shelf life. I've had some two year old stuff that works just fine although the hardener was terribly discolored. With epoxy, however, you need to be sure that it is good room temperature before mixing though - I've had some incomplete cures because it was cold when I mixed.
As for the repair, I would stay away from 5200 because it will remain flexible and allow the crack to propagate. I would open the crack slightly, mix up some slow cure West System, heat the mixture to reduce the viscosity and warm the rudder up (heat gun but sunshine might work), pour into the crack, remove screw drive, repeatedly squeeze the crack to work in the epoxy, and clamp. I bet it would hold fine.
If you really want to get fancy, and depending on the shape/nature of the crack, I would seal up the crack and apply vacuum to suck in the epoxy.
Jake Kohl | | | Re: What is a stronger bond/ repair ?
[Re: MarkW_F18]
#116247 09/05/07 11:46 AM 09/05/07 11:46 AM |
Posts: 330 | For one weekend, spreading the crack and getting epoxy down in may hold. However, I've had rudders split down the seam on two occasions. Both were Hobie rudders split down the front seam in the area of the lower casting. One was an old-style EPO, and the other was a Hobie 20 rudder. In both cases, I got epoxy inside the split as well as wrap glass around the split (which can be difficult since you may not be able to make the rudder wider). In both cases, the rudder still eventually re-split.
Personally, I would try to get some glass or carbon on the split to help hold it together. There is a lot of load on those rudders. Try to make it stronger than original afterall, the reason it split was because it wasn't built strong enough.
Regarding old epoxy, I've been told that the epoxy/hardener doesn't like to be stored below freezing (32F) because crystalization can occur and thus effect curing. However, if you're epoxy does end up crystalizing, all you need to do is put it in hot water for a while (can't remember if it had to be boiling).
sm | | | Re: What is a stronger bond/ repair ?
[Re: srm]
#116248 09/05/07 11:55 AM 09/05/07 11:55 AM |
sm Yes, you are correct. If it crystallizes (you should be able to see the particulate), you can put the container in some hot water and stir to re-homogenize it.
[Re: MarkW_F18]
#116249 09/05/07 12:14 PM 09/05/07 12:14 PM |
Posts: 1,884 Detroit, MI | Is this delamination crack common among the Hobie Tiger Rudders? I know a couple of people that have had it happen on older rudders (2002). The biggest pain is that you can't get the "old style" white rudders anymore. You either upgrade to carbon or upgrade to the new rudder system that requires new gudgeons. | | | Re: What is a stronger bond/ repair ?
[Re: MarkW_F18]
#116251 09/05/07 03:31 PM 09/05/07 03:31 PM |
Posts: 3,528 Looking for a Job, I got credi... | My epoxy is pretty old, but I need to get some new hardener. I don't think there is a date on it,but I would say it's probably 6-8 years old.
Is this delamination crack common among the Hobie Tiger Rudders? I also noticed several stress cracks in the gelcoat where the rudder meets the bottom part of the casting. Our other rudder is also showing some stress cracks there. If it is that old, do a test before using it.
[Re: MarkW_F18]
#116256 09/06/07 08:53 AM 09/06/07 08:53 AM |
Posts: 805 Gainesville, FL 32607 USA | From older postings on Hobie rudders: reepoxy the crack, then add a 1 inch x 5 inch piece of Kevlar tape. It will never split again. If you do this when new, it will never ever split.
305
guests, and 46
