| Spin Take down #116779 09/10/07 07:09 AM 09/10/07 07:09 AM |
Posts: 186 Chattanooga, TN | The discussion of the takedown was brought up this weekend after I was noticing some wear around the lower patch. The spin has the patches on the starboard side of the sail. Some people felt that you should always snuff the sail when the line is on the inside of the sail (so on mine it would have to be on a starboard tack). Well this is not easy when you try to drop it rounding the mark as you are rounding it on port. Do you all think this is a thing to worry about or does the side of the take down is not a problem. As for the wear Ed says he is noticing the same stuff on his spin also. We have taped up what we can as far as sharp edges and what not, but are still looking for the cause.
Jody
Blade F16 724
Plays with Sharp Objects
| | | Re: Spin Take down
[Re: jody]
#116780 09/10/07 08:52 AM 09/10/07 08:52 AM |
Posts: 1,121 Eastern NC, USA | I've always run mine up the port side of the spin. Sometimes tiny friction burns can show up. Is it worse that that?
Tom | | | Re: Spin Take down
[Re: tshan]
#116781 09/10/07 10:15 AM 09/10/07 10:15 AM |
Posts: 186 Chattanooga, TN | It is a little worse, Even found 2 small (maybe 1 cm) holes in the area. All our patches are on the starboard side so not sure if I could run it up the port side.
Jody
Blade F16 724
| | | Re: Spin Take down
[Re: Gilo]
#116784 09/10/07 11:28 AM 09/10/07 11:28 AM |
Dyneema or swiftcord ?
| | | Re: Spin Take down
[Re: alutz]
#116787 09/11/07 03:27 AM 09/11/07 03:27 AM |
Posts: 9,582 North-West Europe | To echo Andreas,
I'm using 4 mm plain dyneema for 4 years now and I'm still flying my 4 year old spinnaker. It is pretty much blown out by now, but the damage from the retrival line is minimal. I think I have about 15 small tape repaires in it. Mostly as a precaution as I also "repair" small marks to prevent them from ever growing into larger holes. I also found that the tape repair cuts down on new damage. The first few repairs you get quickly after that the tape itself seems to reinforce the problem spots.
Once a season I take my spi halyard off and wash it. This makes it clean and soft again and then reduced wear on the spi significantly. Other then that my spi halyard is out in the condition 6 months a year and will become hard with salt, sand and algae.
| | | Re: Spin Take down
[Re: jody]
#116788 09/11/07 04:18 AM 09/11/07 04:18 AM |
Posts: 3,348 | . . . still looking for the cause. It seems that my problem is worse when I have a sloppy retrieval i.e. the sail does not enter the bag smoothly. What I try to do is; bring the sail down to the mouth of the bag with as little pressure as possible, then, with one fast pull, the whole thing goes in. | | | Re: Spin Take down
[Re: fin.]
#116789 09/11/07 05:35 AM 09/11/07 05:35 AM |
In my experience it also helps to pull the retrieval line more or less tight before uncleating the top halyard.
| | | Re: Spin Take down
[Re: Gilo]
#116791 09/13/07 12:34 PM 09/13/07 12:34 PM |
Why don't you leave the outer core on where you will be handling it during the hoist ?
| | | Re: Spin Take down
[Re: Wouter]
#116792 09/16/07 07:19 PM 09/16/07 07:19 PM |
Posts: 6,049 Sebring, Florida. | I had trouble with every single set and takedown at a regatta this weekend, due completely because the halyard (with a cover on it) kept kinking up and jamming in the tramp gromets or clete. I had to stop pulling on the halyard, reach down and clear the kink, then pull the halyard up again. Same thing on the takedown, cost me a place a couple times, very frustrating.
If I just pull the core out of the coverd line, will the core work until I get the 6mm dyneema? Does the 6mm dyneema wear at the clete and does it hold in the clete without slipping? Anyone know how long the Blade Spin. halyard is? I'm guessing about 60-70 feet?
Blade F16 #777
| | | Re: Spin Take down
[Re: PTP]
#116794 09/17/07 03:18 AM 09/17/07 03:18 AM |
Posts: 9,582 North-West Europe | Wash the line and run out all the twists properly and then fit it to the boat. DO NOT "bundle" it together like any sailors would between these operations and fitting it to the boat. This reintroduces the twists again.
The only exception is to "bundle" it up with figure 8 loops and not normal loops. Then the line can be fitted to the mast straight from the bundle without introducing any twists.
Another good modification is to replace the turning block on the trampoline by a steel ring. The steel rings allows the kinks to pass while a microblock doesn't. The kinks are only created in the slack portion of the halyard line and never in the tensioned portion. Bungee-ing the slack portion on the tramp will therefor work to reduce kinks and /or pull then out when they do form.
Alot can be done to have the setup be largely kink free and/or kink acceptant.
6 mm line is too thick for the spi halyard. It will be heavy and needlessly thick. 4 mm is enough of the line allows your hands to have some grib. The dyneema core is very slippery and I refuse to "hand" it as a crew. Best is too just use the unmodified line as a halyard and only strip some of the mantle off of the last few feet.
| | | Re: Spin Take down
[Re: Wouter]
#116795 09/17/07 03:38 AM 09/17/07 03:38 AM |
Posts: 4,451 West coast of Norway | Figure 8 loops? I think that also would introduce twist in the line, but two kinks running opposite each other so when you unfold the line it evens out. If you want to store a line without twisting it, which cause all kind of trouble if you dont "unroll" the line, you should "fold" the line. In rock climbing 60 meter ropes are used, and to stop kinks from forming they are always folded when carried or stored. If you look here, you get the idea, just scale the folds down to fit your length of line. http://www.swcp.com/~nmmc/climbrocks/knots/butterfly_coil.GIFWashing the line every fall when putting the boat in storage is a really good tip! Makes it last longer and it is nicer to handle afterwards. | | | Line folding..
[Re: taipanfc]
#116797 09/17/07 04:35 AM 09/17/07 04:35 AM |
Posts: 4,451 West coast of Norway | Like I said, if you make the figure 8 loops you are making two twists in opposite directions for each loop. When you uncoil the rope, the twists cancels out each other and you hopefully have a length of line without twists. Folding the line dont introduce twist at all into the line. Both my crew and I used do do a lot of rock and mountain climbing. Getting twist into the lines while climbing is outright dangerous, so the climbing community have developed ways to avoid that. Always folding the rope is the best way to avoid twists, barring putting the line into a rope-bag. We consequently always fold lines on our boat, and lock up the folded lines by doing some turns around the hoop and a a self-locking hitch. Quick, easy and relatively idiot-proof. Try it, and compare handling with figure-8 coils. The true test is coiling and uncoiling twin trapeze lines. If you can do that without twists and snarls you have a good method.
While talking about coiling and twists. When storing the SS rigging, we dont coil the wires but roll them up. When rigging the mast/boat, we dont uncoil the wires, but unroll them. This is another variation on the same problem, how to avoid twist and kinks. | | | Re: Line folding..
[Re: Rolf_Nilsen]
#116798 09/17/07 04:54 AM 09/17/07 04:54 AM |
Posts: 9,582 North-West Europe | Try it, and compare handling with figure-8 coils.
I certainly will ! Looks like a better alternative. Wouter
295
guests, and 19
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
