| Re: Robbert Lott's Boat Weight?
[Re: Matt_Stone]
#121985 11/01/07 01:19 AM 11/01/07 01:19 AM |
Posts: 461 Victoria, Oztralia | Hi Matt
I wouldn't worry about it and continue with what your doing the difference is not going very much. Not to take anything away from Roberts 3mm construction, 4mm will be stiffer and stronger, and I'm not too sure, but I've read somewhere 3mm is getting hard to get, maybe someone else can clarify that.
Regards
Matt Harper
Homebuilt Taipan 4.9
[Re: mattaipan]
#121986 11/01/07 03:09 AM 11/01/07 03:09 AM |
Posts: 393 Camden NSW | Hi Matt,
My mossie was built in 92 and used 2mm ply. The boat today was still underweight but very soft, you have to watch where you stand on it.
My old boat 1635 used 3mm ply and Cameron took some off the decks and Im pretty sure that was very close to minimum weight.
William | | | Re: Robbert Lott's Boat Weight?
[Re: wildtoy]
#121987 11/01/07 03:17 AM 11/01/07 03:17 AM |
Posts: 461 Victoria, Oztralia | Hi Will
Are you sure it was 2mm, that doesn't sound right.
Regards
Matt Harper
[Re: wildtoy]
#121988 11/01/07 03:35 AM 11/01/07 03:35 AM |
Joined: Apr 2007 Posts: 432 McCrae Y.C. Mornington Peninsu... Simon C
Posts: 432 McCrae Y.C. Mornington Peninsu... | Hi Guys,
While on the subject of "softness" , I've got a crunchy deck again, next foam frame up from the one I had replaced when I had the paint job done. It's not too bad so I've decided to sail the season with it and deal with it next winter. A few people in here have suggested that a Mozzie deck is not too difficult to replace. Would that be the case if you had the wood working skills of a "cerebraly challenged gnat"? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
I know I need to learn these things but I really wouldn't know where to start to get some knowledge? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Simon Taipan AUS341
[Re: mattaipan]
#121989 11/01/07 05:17 AM 11/01/07 05:17 AM |
Joined: Jun 2006 Posts: 177 Sydney/Northern Beaches Bandit
Posts: 177 Sydney/Northern Beaches | Hi Will
Regards Yeah Wills boat Jive was previously called Smik was built of 2mm ply and comes in under weight at around 50kg.His main deck was 3mm I believe. My new 3mm deck is reinforced with 120 gram glass on the inside. The downside is it does tend to flex and I have small hairline cracks in my paint job. Possibly by using 4mm with a layer of glass or 3mm with 2 layers of glass it would be alot stiffer but stll a few kgs lighter. I'd also like to point out removing the old deck is not easy and I had a few areas damaged due to this. All repairable and not structural but If you get unlucky it could create a can of worms. | | | Re: Robbert Lott's Boat Weight?
[Re: Bandit]
#121990 11/01/07 01:52 PM 11/01/07 01:52 PM |
Posts: 393 Camden NSW | Hi Matt, My boat is made of 2mm ply which makes it extremely soft and to more get a bit more technical the builder actually travelled to Vic to get the 4 lightest sheets possible. The builder was really picky with this boat to get it down to weight.
William | | | Re: Robert Lott's Boat Weight?
[Re: greymatter]
#121994 11/05/07 01:23 AM 11/05/07 01:23 AM |
Posts: 461 Victoria, Oztralia | Agreed, I went ahead and used 4mm with a thicker core, but all went well patience and plenty of steam. I did put a small crack in the ply when folding, but was easily fixed and tried again later, with more patience and no worries. I used 4mm on the main and rear decks and 3mm on the forward decks, all with a layer of light glass.
Regards
Matt Harper
1,466
guests, and 43
