| Re: How many knots before twin trapeze needed?
[Re: mmadge]
#125219 12/03/07 06:59 PM 12/03/07 06:59 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | This is good info.
Now, suppose the crew weight combined was more like 150lbs for myself and 120lbs for my girlfriend.
Would I be able to avoid double trapping if I were to sheet out?
The reason that I ask, is that my girlfriend is deathly affraid of sailing and I don't think I will ever be able to convince her to get out on the wire.
I honestly don't forsee myself sailing on more than 10-12 knot winds.
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
[Re: Tri_X_Troll]
#125220 12/03/07 07:35 PM 12/03/07 07:35 PM | Anonymous
| Anonymous
Unregistered | Sheet the main in, you want good flow of the telltales, but just travel out till the boat settles down. Try as much downhaul as you can first. Good luck and that should make the boat a little more stable for her. Last thing you want to do is scare her. She will NEVER get on again then. I had to add barbell weight to the boat by the mast before to make class weight. Once you learn the boat a little more it should settle down ad be easier.
Doug
[Re: Tri_X_Troll]
#125222 01/08/08 08:44 PM 01/08/08 08:44 PM |
Posts: 124 offshore | Ryan --
I can't tell you how many girlfriends I have seen converted. Get her out on the wire once, and you'll never be able to get her back in!!
Of course, you will want to do it on a day that is not real puffy. And you will want to make sure you have your game face on to make sure you don't dump the poor gal. All the while, of course, you want to make sure you are smiling BIG like this is the most fun you have ever had on a Hobie -- which it might likely be!!
Just make a deal she can't refuse -- hot tub afterwards, candlelight dinner, that soapy movie she has been dying to see, and oh yeah, don't forget the brand new Lexus!
Time Warp Racing Hobie 14, 16, & 17, Jeanneau Sun Odyssey 45.2
[Re: peter_nelson]
#125223 01/08/08 10:32 PM 01/08/08 10:32 PM |
Posts: 182 Coopersburg, PA | That exact technique worked for me!!! well, with the exception of the Lexus
~vinny~
308
guests, and 29
