| Re: rudder alignment
[Re: Wrinkledpants]
#12965 11/13/02 02:53 AM 11/13/02 02:53 AM |
Posts: 30 SF. Bay Area | They should be paralell or slightly toed-out, I think. For sure you have a problem if you can tell they are out of allignment visually! Rudders are a really important system, and it is worth it to spend the time to get them just right. Look at your pin to gudgeon clearances, your rake (back to front) AND the allignment. I took about an inch of slop out of my system and the boat sails much better!
Michael Rossney
West Oakland, Ca.
H-18
[Re: mwr]
#12966 11/13/02 06:30 AM 11/13/02 06:30 AM |
Posts: 170 Australia | Hey
Yeah the rudders are ment to paralell to each other and since your arn't that is a major problem. First thing it could be is, when you last put the rudders on you might of put the left rudder on the right side and vise verse, yes people do do this it is easy even i have done it. The second is maybe the person you got the boat off they might of tryed and fix them and put the castings in the wrong spot. Well there is many ways of stuffing your rudders up but the best person to talk to about these type of things are your local sailors and hobie dealer. Well im going so have fun sailing byebye.
Jules
Jules_topcat
[Re: Wrinkledpants]
#12969 11/23/02 07:01 PM 11/23/02 07:01 PM |
Joined: Nov 2002 Posts: 54 Panama City Beach, FL Sunjammers
Posts: 54 Panama City Beach, FL | The rudder arms should slightly bend in towards each other, The upper castings are designated port and starboard. I can measure the distance of H16 rudders for you if you wish. You can e-mail me at [email] [email protected].[/email] Hope this helps, Brad Stephens Panama City Beach, FL
Thanks, Brad Stephens Panama City Beach, FL | | | Re: rudder alignment
[Re: Wrinkledpants]
#12971 01/15/03 01:05 PM 01/15/03 01:05 PM |
Posts: 54 Panama City Beach, FL | It sounds like your rudders are on backwards. Your rudder arms are supposed to bend in towards each other, The upper castings are designated port and starboard. This is a very common problem that cause people to do modifications to there system just to find out they messed them up more. Take off you cross bar, move the port rudder assembly to the starboard side on the starboard to the port, reinstall you cross bar, let me know if that helps, if not call me and I will see what I can do to help. If you don't want to remove you cross bar, there is a way to twist everything around to accomplish the same outcome, easiest way is the 1st way I suggested! Thanks, Brad Stephens 850-235-2281 www.sunjammers.cominfo@sunjammers.com Authorized Hobie/Vanguard Dealer
1,165
guests, and 16
Mod | | Forums26 Topics22,406 Posts267,060 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
