Rating: 5
Page 1 of 9 1 2 3 4 5 6 7 8 9
Kiwi F12 Build Pics #130505
02/02/08 10:52 PM
02/02/08 10:52 PM
NZ
RetiredGeek Offline OP
NZ
Hi all,
sorry for being quiet for a while, as stuff crawls to a stop around Xmas, but things are picking up now.
The attached pic's are from Billy & Grahame's project in the North of NZ and they are building 4 boats, 2 for each of their kids. Pictures should be pretty self explanatory and are in sequence. The first boat should hit the water in about 6 weeks....we hope ?
For those not familiar with the project, we elected to make foam/e-glass panels that will then be tabbed together in the jig rather than make it from plywood.
RG
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130506
02/02/08 10:55 PM
02/02/08 10:55 PM
NZ
NZ
another shot of the jig
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130507
02/02/08 10:57 PM
02/02/08 10:57 PM
NZ
NZ
Cutting the foam cores using templates
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130508
02/02/08 10:59 PM
02/02/08 10:59 PM
NZ
NZ
Cores joined together
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130509
02/02/08 11:03 PM
02/02/08 11:03 PM
NZ
NZ
Peel Ply and 1 layer of e-glass on melamine board (waxed)
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130510
02/02/08 11:07 PM
02/02/08 11:07 PM
NZ
NZ
wet out of first ply
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130511
02/02/08 11:09 PM
02/02/08 11:09 PM
NZ
NZ
Another ply added and resin applied
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130512
02/02/08 11:11 PM
02/02/08 11:11 PM
NZ
NZ
Roll up the 2nd ply
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130513
02/02/08 11:13 PM
02/02/08 11:13 PM
NZ
NZ
Place the cores on the 1st ply
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130514
02/02/08 11:16 PM
02/02/08 11:16 PM
NZ
NZ
roll out the 2nd ply
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130515
02/02/08 11:18 PM
02/02/08 11:18 PM
NZ
NZ
Add another layer of peel ply
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130516
02/02/08 11:21 PM
02/02/08 11:21 PM
NZ
NZ
Breather layer added, plastic sheet over the top, vacuum lines inserted (one either end), all edges sealed.
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130517
02/02/08 11:24 PM
02/02/08 11:24 PM
NZ
NZ
Vacuum turned on and and then you wait till its cured.
Will post more as the job progresses.
RG
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130518
02/02/08 11:55 PM
02/02/08 11:55 PM
japan
erice Offline
erice  Offline
japan
facinating!
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Kiwi F12 Build Pics [Re: erice] #130519
02/03/08 06:25 AM
02/03/08 06:25 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
WOW, excellent pictures RG...<img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> Kudos and big thanks for the posting...
Re: Kiwi F12 Build Pics [Re: Buccaneer] #130520
02/04/08 12:23 PM
02/04/08 12:23 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Hope you have a really flat floor with no humps or bumps...
Bob
Re: Kiwi F12 Build Pics [Re: Seeker] #130521
02/05/08 11:02 PM
02/05/08 11:02 PM
NZ
NZ
Another Update:
Roughly speaking, it has taken 1 day to cut the foam templates, cut the foam cores and join them and get 4 panels laid up (3 people). It took another 2 nights of 2-3 hours for 2 people to lay up another 4 panels per night. To separate and trim the panels took 2 people 1 day and get them ready to be tabbed in the jig. In total it took 4.6 sheets of foam to do all twelve hull panels for 2 hulls.
First pic is adding the cleats to the frames, these are hard wood so we can staple the hull panels in place. Do not staple into the MDF frames as after 2-3 boats the frames will start to fall apart.
RG
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130522
02/05/08 11:05 PM
02/05/08 11:05 PM
NZ
NZ
Dry Fitting the panels....note the slits in the bottom panel....more on this later
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130523
02/05/08 11:07 PM
02/05/08 11:07 PM
NZ
NZ
Dry Fitting the bow
Re: Kiwi F12 Build Pics [Re: RetiredGeek] #130524
02/05/08 11:10 PM
02/05/08 11:10 PM
NZ
NZ
Be sure to tape the frames before you create a bog cove for the panel tapes, makes sure it comes out of the jig.
0 registered members (), 338 guests, and 167 spiders.
