Taco Metals - Poly Sheet Lumber #136242
03/13/08 12:07 PM
03/13/08 12:07 PM
Crofton, MD
Chris9 Offline OP
Chris9  Offline OP
Crofton, MD
Have you ever heard of this stuff -Taco Metals - Poly Sheet Lumber?
http://www.tacomarine.com/item--Marine-Lumber--Marine+Lumber.html
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Taco Metals - Poly Sheet Lumber [Re: Chris9] #136243
03/13/08 12:11 PM
03/13/08 12:11 PM
Never heard of it. But, I'm sure gonna look into it.
Thanks!
Re: Taco Metals - Poly Sheet Lumber [Re: fin.] #136244
03/13/08 12:19 PM
03/13/08 12:19 PM
how much $?
Re: Taco Metals - Poly Sheet Lumber [Re: PTP] #136245
03/13/08 12:53 PM
03/13/08 12:53 PM
Neat stuff, but pricey:
Taco Marine Board Prices
That sheet weighs 36 lbs - about the same density as red cedar - maybe a little lighter than plywood.
$350 for a 1/2" x 54" x 96" sheet.
Re: Taco Metals - Poly Sheet Lumber [Re: Chris9] #136246
03/13/08 08:48 PM
03/13/08 08:48 PM
I always had the impression that that material was a derivative of Dupont Corean (sp?).
Re: Taco Metals - Poly Sheet Lumber [Re: Jake] #136247
03/14/08 11:39 PM
03/14/08 11:39 PM
Hollister CA, Plano TX
avalondarlyn Offline
I used it to make a winch platform. it replaced the 3/4 in marine ply that was original. i use the 3/4 as a straight replacement of 3/4 in plywood. it worked well . no problems. it looked much better. easy to maintain. use a router on the edges. when you cut it with a regular saw the edges can be sharp. this is the best pic i can find right now of it. upper right picture before i cut the sharp corners off of it.
Re: Taco Metals - Poly Sheet Lumber [Re: avalondarlyn] #136248
03/14/08 11:42 PM
03/14/08 11:42 PM
after looking at the post. lower right picture. sideways opps sorry.
Re: Taco Metals - Poly Sheet Lumber [Re: Chris9] #136249
03/15/08 12:09 PM
03/15/08 12:09 PM
H
hoofhearted Offline
hoofhearted  Offline
H
This stuff is also known as "Starboard". West Marine sells it, but at a really hig price. Boater's World sells it as well at a better price. Last year Bass Pro Shops had it at half the price of West Marine's yet exact same product (same UPC code). Many of your cabinet makers can order it for you. Cool stuff, to make really neat stuff use the adhesive compound that can be purchased for it.
0 registered members (), 347 guests, and 219 spiders.
