| Re: Bottom of Hull Repair
[Re: WillNicholson]
#142335 05/09/08 04:58 PM 05/09/08 04:58 PM |
Posts: 757 japan | doesn't look so bad to me most important thing is to do some kind of repair before sailing again if i were you i'd dry it out thouroughly, maybe use a heat gun on low, or good sunshine clean it up as much as possible with acetone, the solvent for uncured polyester resin pick out as much debris from the crack as possible cut of a small strip of glass fibers and then pull a few threads from the ends mix up the smallest amount of polyester resin you can, for me that's 100mls as my catalyst dropper's minimum is 1ml paint the mixed resin over the bare area and then using a toothpick stuff as manny glass threads as you can into the crack take time to keep brushing on resin carefully so the threads all get soaked when crack full and threads sticking out continue brushing thick coats of resin onto bare area while trying not to pull threads out of crack with brush leave it alone overnight next day it should be hard enough to cut the long fibers off and then grind down to just raised if crack not fully filled, repeat until filled finish off with another thick coat of polyester resin, but don't try to make it so thick that it runs down the hull, you just want it to puddle on top, (easy to do on a nacra base maybe harder on the hobie knife edge) when you have a good thick cured layer of resin over all the fibers smooth it all out with a big file but don't file it all off ago over it with 2 or 3 coats of white gelcoat and then you should be good if you' got your temp/catalyst mix right stuff as many of those threads that you could into the crack
[Re: erice]
#142336 05/09/08 06:15 PM 05/09/08 06:15 PM |
Posts: 11 | Hum, I don't know how to insert an image, but if you would like to see the damage I am going to repair, here is a link: http://willnicholson.com/media/IMG_7071.JPG I have decided to use polyester resin for sure. I bought some 3” glass tape. I think I’m going to just lay down a few layers, fold the tape in half, and lay a few more down. Any thoughts? | | | Re: Bottom of Hull Repair
[Re: HMurphey]
#142339 05/13/08 12:46 PM 05/13/08 12:46 PM |
Posts: 11 | Ok, so ill keep everyone informed, and thanks for all the help. So far, I have mixed up half a quart of resin, taped the bottom where the leak is, and poured it in the hull. I then rocked it very slowly to let it coat the inside. Seemed to work well and I could tell it got down in the crack from the color the tape turned. Next step is to get it flipped over, give it a good sand, and strip off a quarter to half an inch of gelcoat with my sanding disc on an angle grinder. Then im going to lay down layers of glass tape, sand and even it out. I figured that since I'm going to all this trouble, while I'm at it, i'm going to sand out all the scratches and dings, bondo them, and then I'm going to attempt to gelcoat both pontoons by myself. I've got a wagner paint sprayer that I dont care about. Wish I could find my circular sander, I'm thinking it's going to be hard work. Any more advice? | | |
1 registered members (FredL),
505
guests, and 97
