Help rigging a Nacra 5.8......!!! #143248
05/14/08 11:49 AM
05/14/08 11:49 AM
N
nacra58 Offline OP
nacra58  Offline OP
N
I have a Nacra 5.8 and I just purchased a 1/4" Bow Shackel to attatch my shrouds and roller furling jib...The roller furling will not fit on the Bow Shackle...any suggestions????
Thanks!!
Re: Help rigging a Nacra 5.8......!!! [Re: nacra58] #143249
05/14/08 12:02 PM
05/14/08 12:02 PM
Coral Gables, Fl
ferminj Offline
ferminj  Offline
Coral Gables, Fl
You can send a pix to see. Are the ends of the forestay and the bridle wires terminated in a loop?. Hows the RF attached?. Generally the bow shackle joins all 3 ends (forestay and 2 bridle wires).
Re: Help rigging a Nacra 5.8......!!! [Re: nacra58] #143250
05/14/08 12:14 PM
05/14/08 12:14 PM
Reno NV
Rhino1302 Offline
Rhino1302  Offline
Reno NV
Do you have an Original (bridle wires) or North American (bridle foil)?
Generally you do not attach shrouds with a shackle. Did you mean forestay?
Also what kind of roller furler do you have?
Re: Help rigging a Nacra 5.8......!!! [Re: nacra58] #143251
05/15/08 08:16 AM
05/15/08 08:16 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Part #56-9649. You can order it from a Nacra dealer or Murrays. It is called a tang plate, basically a 2" piece of SS with hole for the furling swivel and an oval hole for the shackle. It's like 6 bucks. See attached . . .
Philip
USA #1006
Re: Help rigging a Nacra 5.8......!!! [Re: P.M.] #143252
05/18/08 10:57 AM
05/18/08 10:57 AM
N
nacra58 Offline OP
nacra58  Offline OP
N
Here are some photos of my set up, I would like to know how to attatch the forestay to the tang. My problme is that my roller furling connection will not fit onto the shackle....any input would be appreciated ...Thanks!
Re: Help rigging a Nacra 5.8......!!! [Re: nacra58] #143253
05/18/08 11:10 AM
05/18/08 11:10 AM
N
nacra58 Offline OP
nacra58  Offline OP
N
The above picture needs to be attatched to the mast via...?????...
Re: Help rigging a Nacra 5.8......!!! [Re: nacra58] #143254
05/18/08 11:21 AM
05/18/08 11:21 AM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
It looks like you have 2 different swivels and only need one. Get rid of the old style swivel and use the Nacra plate that Philip gave you the part number to. You can also make your own plate at a different length if you need to.
Re: Help rigging a Nacra 5.8......!!! [Re: Dlennard] #143255
05/18/08 12:14 PM
05/18/08 12:14 PM
Lake Lanier, Georgia
hobiesailor Offline
hobiesailor  Offline
It doesn't look like the bow shackle at the mast would fit either one. My Hobie 18 had a "pigtail" that connected the bow shackle to the swivel. Just a 6" or so section of forestay with loops swedged on both ends to bridge the two.
Re: Help rigging a Nacra 5.8......!!! [Re: hobiesailor] #143256
05/18/08 02:47 PM
05/18/08 02:47 PM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
That appears to be a Harken swivel, it is not 2 seperate swivels. Turn it over (end for end) and the attach it. It should work just fine. The bow shackel will attach the swivel to the forestay and the other end should connect to the shackel on the mast tang by using the clevis pin in that end.
Re: Help rigging a Nacra 5.8......!!! [Re: Hullflyer1] #143257
05/18/08 07:14 PM
05/18/08 07:14 PM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
The lower one is a Harken swivel and should be turned around. The swivel he is holding in his fingers old style should be removed. He can use a pig tail or plate like the nacra style to finish hooking up the top.
0 registered members (), 332 guests, and 120 spiders.
