Hooter block location #14449
12/19/02 12:15 PM
12/19/02 12:15 PM
Galveston
jgrady Offline OP
jgrady  Offline OP
Galveston
I am installing a hooter on my P-19 and am curious about the best spot to install the ratchmatics. I have seen photos of a base attached to the cross beams in front of the outer bolt. Can I not simply attach them to the bolts themselves with a tang of some sort or are they not able to take the extra stress? I would prefer to drill as few holes as possible. Any help from P-19 folks out there who have dealt with this would be great.
Thanks
JGrady
JGrady P-19 #1115 w/Hooter Galveston
Re: Hooter block location [Re: jgrady] #14450
12/19/02 04:15 PM
12/19/02 04:15 PM
Fulshear, TX
SGalway Offline
SGalway  Offline
Fulshear, TX
Do you have the jib blocks on wires or attached directly to the tramp? I have the jib going directly to the tramp, therefore I also attach the spin block in the same location. The forward turning block is on the front crossbeam. I drilled into it to attach. Better to drill in that than the hull...
Shannon Galway
Fulshear, TX
YoNav! Flying Phantom
www.yonav.net
Re: Hooter block location [Re: SGalway] #14451
12/19/02 11:35 PM
12/19/02 11:35 PM
Galveston
jgrady Offline OP
jgrady  Offline OP
Galveston
The jib blocks are on wires (stock) but the hooter blocks need to go on the rear cross beam. What I would like to do is attach each to the outer bolt that holds the hull. I know the Nacra folks have done this but those have a metal strap held by two bolts. The P-19 bolts straight through the beam. Just don't want to stress a weak spot.
JGrady
Re: Not a Hooter, but [Re: jgrady] #14452
12/22/02 01:56 AM
12/22/02 01:56 AM
Andrew Offline
Andrew  Offline
I sheet my chute to blocks shackled to eyestraps riveted to the front of the rear beam, about 2" in from the endcap. Good luck
0 registered members (), 403 guests, and 156 spiders.
