| Trampoline is pulling out of casting #146798 06/25/08 06:30 PM 06/25/08 06:30 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll OP
Posts: 224 Cincinnati, Ohio | I know i've seen threads about it somewhere, but my search-fu isn't brining them up. Suggestions? ![[Linked Image]](http://i19.photobucket.com/albums/b161/Tri_X_Troll/Boat/DSC01898.jpg)
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
| | | Re: Trampoline is pulling out of casting
[Re: buyer]
#146800 06/26/08 10:58 AM 06/26/08 10:58 AM |
Posts: 224 Cincinnati, Ohio | Not yet. I was hoping someone who had used them knew if they would work for this application.
Ryan - H16
[Re: Tri_X_Troll]
#146801 06/26/08 01:56 PM 06/26/08 01:56 PM |
Posts: 99 Virginia Beach | Not yet. I was hoping someone who had used them knew if they would work for this application. I didn't have much luck with them on a vinyl tramp several years ago. You have to loosen the tramp, insert them and hope they don't fall out while you are re-lacing. | | | Re: Trampoline is pulling out of casting
[Re: Tri_X_Troll]
#146802 06/26/08 03:09 PM 06/26/08 03:09 PM |
Posts: 321 Albuquerque NM | If you have the "Wide" part of the rail slot in the front, and that is where you are loosing your tramp, you could take the tramp off and flip the rail 180. There are those that caution against it but... Plus it is a fair bit of work.
[b] Sail Like you have a Pair
[Re: Banzilla]
#146803 06/27/08 08:34 AM 06/27/08 08:34 AM |
Posts: 224 Cincinnati, Ohio | I'm much too lazy to flip the bars, so I suppose I'll try the tramp clamps. They're only $10.
I could probably use masking tape or something to hold them in place while I relace my trampoline.
Ryan - H16
[Re: mmiller]
#146805 06/27/08 06:04 PM 06/27/08 06:04 PM |
Posts: 224 Cincinnati, Ohio | Guilty as charged. Fairly happy with my amish tramp so far. Pinching my pennies until I can afford a muuuuuuuch newer, used boat.
Ryan - H16
410
guests, and 29
