| F12 sail area #148576 07/05/08 07:09 PM 07/05/08 07:09 PM | Anonymous
| Anonymous
Unregistered | Current values (I think)
DS12 7.0 sq.m Vudu 7.0 sq.m Wouter 7.0 sq.m Phill 5.6 sq.m
Please chip in with other numbers if these are incorrect or if you've developed another design.
If you vote no please add a recommendation and we'll create a new poll when necessary.
Yes |
94%, 15 Votes
No |
6%, 1 Votes
| | | | Re: F12 sail area
[Re: ]
#148577 10/01/08 02:22 AM 10/01/08 02:22 AM |
Posts: 1,383 Kingston SE South Australia | Is there a design for these sails yet? I watched that sailrite making your own sails thread with interest, is it possible to order sails to sew together myself and if so is it worth the effort? regards
| | | Re: F12 sail area
[Re: Gato]
#148581 10/01/08 06:20 PM 10/01/08 06:20 PM |
Posts: 1,383 Kingston SE South Australia | Did that include them doing the development on the sail or did you supply the specs on what you wanted? Im mainly asking this as not only do I need two mains for the F12's but as I build more cats I would also like to have various size sails to suit different crews at the club regards
| | | Re: F12 sail area
[Re: JeffS]
#148582 10/02/08 12:13 AM 10/02/08 12:13 AM |
Posts: 435 Finland | What I did was to go to the lokal sailmaker (North Sails)with the drawing that Scarecrow supplied. He designed the sail from that for no extra costs. I got the first sail for half of the price mentioned above. As they do everything by special computer programs there is no big deal to make a set of differents sizes. If there is a local sailmaker working with North Sails you could try to contact him and tell him that there is a design i North Finland, maybe he can get the specs from there.
| | | Re: F12 sail area
[Re: Gato]
#148583 10/02/08 06:33 PM 10/02/08 06:33 PM | Anonymous
| Anonymous
Unregistered | That price is in the ball park but a little high. I would have hoped for a bigger discount on second generation sails.
Jeff the sail plan in your plan set is enough for any experianced sail maker to build your sail to. A good sail maker will take the dimensions supplied on the sail plan, combine it with data for your boat and produce the sails. | | | Re: F12 sail area
[Re: Gato]
#148585 10/03/08 07:43 PM 10/03/08 07:43 PM | Anonymous
| Anonymous
Unregistered | The best Australian quote I've had to date is AUS$650 including battens. I won't pass on details here but people can feel free to contact me for details. | | | Re: F12 sail area
[Re: Gato]
#148588 10/04/08 05:09 PM 10/04/08 05:09 PM |
Posts: 1,383 Kingston SE South Australia | Thanks guys I cant really match the sails to a mast yet as I'm going to use ali masts I already have then if the minimum weight goes down build some carbon ones regards
| | | Re: F12 sail area
[Re: ncik]
#148589 10/04/08 07:16 PM 10/04/08 07:16 PM | Anonymous
| Anonymous
Unregistered | Gato, have you measured the bend of your carbon mast yet? Any comparisons with an equivalent aluminium mast? Ncik designed bend numbers with mast supported at step and hounds were: 10kg at head. 38.3mm fore-aft deflection 114mm side deflection 10kg midway between supports 16.4mm fore-aft 49mm side ways From memory Gato nailed the transverse numbers, but ended up a little stiffer longitudinally due to his double barrel sail track. I kept the rig reasonably soft sideways to help it lay off a little in gusts to auto-depower, however, from Gato's experience I believe we could get away with a little more stiffness. I've been meaning to re-engineer to remove the spreaders but payed work keeps getting in the way. | | |
305
guests, and 46
