| Re: New Nacra sailor
[Re: bombhills415]
#151994 08/08/08 10:41 AM 08/08/08 10:41 AM |
Posts: 976 France | does anyone have a mast ball for this boat? the seller said i will needa new one before sailing it. What size of mast ball? The old 1.25" or the new 1.5"? If it is a '76 model and it was never upgraded you have the 1.25" ball. The easy way to check is to see if there is a retaining pin, if you have one, it's a new 1.5" ball, if you don't it's the 1.25". The problem is that the 1.25" ball is no longer manufactured, you will have to upgrade the whole mast base: an upgrade kit is available from Nacra to retrofit old boats and include everything you need (casting, base, pin, ball...) You may want to look at this thread where I went through the same problem: Tami suggested some other alternatives. Or I can send you Tami's well used balls as soon as I install the new setup on my boat (probably this week-end).
[Re: pepin]
#151995 08/08/08 11:04 AM 08/08/08 11:04 AM | Anonymous
| Anonymous
Unregistered | there are several differences in the 2 boats but both should suit you well...
the hobies have curved hulls and handle surf very well... I THINK the 5.2 doesn't have curved hulls but i dont know about its ability to sail through surf/waves
i have heard (never sailed one) the 5.2 is heavier, and the mast in much heavier (harder to step)...
since there are so many hobie's there are usually more parts available (or at least easier to find) | | | Re: New Nacra sailor
[Re: pepin]
#151996 08/08/08 11:15 AM 08/08/08 11:15 AM |
Posts: 182 Appleton, WI | Or I can send you Tami's well used balls <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> C'mon people. What is this forum turning into? Some of us skim this while we're "working" <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Just kidding. Obviously it's Friday and the week is about done. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> | | | Re: New Nacra sailor
[Re: blockp]
#151997 08/08/08 12:18 PM 08/08/08 12:18 PM |
Posts: 9 Midwest | The nacra does not have curved hulls.
Converting the mast base is an easy remove and replace part but youll need to get a blind rivet tool ( TO-GH-39031). You should have this anyway as it could mean the difference between an easy 1 hour repair and back to sailing, or going home. Remember to use silicone liberaly to prevent the mast from leaking.
Ive had the H16 and now the nacra 5.2 and there are differences obviously. The 5.2 is more boat and is more technical (I haved tons of questions) but both are a blast.
I recommend joining a fleet in your area that sails similar boats and crew for awhile and or skipper your own boat! Stay safe
"Bite off more than you can chew, then chew it" Ella Williams
1983 Nacra 5.2
[Re: bombhills415]
#151999 08/10/08 09:22 PM 08/10/08 09:22 PM |
Posts: 976 France | its the 1.25" ball, any one have one? Well my plan was to install the upgrade kit this week-end, which would have liberated the old 1.25" ball. Turns out it rained all day saturday and most of the day sunday so I gave up. So I'm afraid the usable 1.25" inch ball sitting under my mast is going to stay there until at least mid september (I'm going on vacation soon) | | | Re: New Nacra sailor
[Re: DennisMe]
#152002 08/12/08 05:16 AM 08/12/08 05:16 AM |
Posts: 757 japan | wow thanks for the old pics Don
will print a couple off for the wall of the cabin
i'm guessing that those other nacras with the alpha sail markings in the 2nd pic are the 18foot alpha cats that tom rolland was making before the 5.2
does the line drawing on the last pic show cascading blocks on the boom or an alternate block position?
and to answer the original question
the nacra 5.2 is a bit more race than the hobie 16, lots more ways to tweak the sails for the last bit of speed and the big daggers means it will go upwind lots better than a hobie
as i sail on a smallish deep lake with an island pointing ability is GOOD and big daggers not a problem. even the weight isn't an issue as i can leave the boat on the beach for most of the year
generally for solo sailing though i pretty much leave everything at it's middle setting as there is too much running around to do changing all 6? settings every change from upwind to downwind
i haven't sailed a hobie but have found the 5.2 a very stable platform for solo trapezing, very forgiving on where you can have your feet and gives lots of warning about leeward hull getting too low in the water, like in the 3rd pic
for a surf beach a board less boat like a hobie would be much easier
484
guests, and 33
