Older Hobie 16s OK? #152826
08/16/08 12:34 PM
08/16/08 12:34 PM
Phoenix, AZ
Cousin_Eddy Offline OP
Phoenix, AZ
Getting ready to go look at a 1976 hobie and a 1982 hobie to buy. Are there any significant disadvantage to the older Hobies compared to the newer ones other than condition? Thanks!
Re: Older Hobie 16s OK? [Re: Cousin_Eddy] #152827
08/16/08 03:09 PM
08/16/08 03:09 PM
If you are interested in racing (sounds like you are from your post in the Open Forum), get a '95 or newer.
There are a lot of little upgrades that have been made over the years that make a '76 much different than a '95, even though they are superficially identical.
Probably the biggest difference will be weight. Older boats are heavier - sometimes much heavier.
Re: Older Hobie 16s OK? [Re: mbounds] #152828
08/16/08 11:34 PM
08/16/08 11:34 PM
Phoenix, AZ
Phoenix, AZ
Are the upgrades hardware that I can buy? Or is it design changes like hull materials and stuff?
Are the old ones heavier because they are waterlogged? Or different hull and spars?
Thanks!
There aren't many choices around here for used ones.
Re: Older Hobie 16s OK? [Re: Cousin_Eddy] #152829
08/17/08 10:24 PM
08/17/08 10:24 PM
Eddy,
You can buy parts to upgrade. Contact these folks Phoenix Hobie Fleet 66 before you buy.
0 registered members (), 456 guests, and 37 spiders.
