| Re: reefing points
[Re: h17windbtch6333]
#15295 01/13/03 09:20 AM 01/13/03 09:20 AM |
Joined: Apr 2002 Posts: 349 Fort Loramie, Ohio jmhoying
Posts: 349 Fort Loramie, Ohio | Hello, I'm also thinking of adding reefing points. My question to the experts concerns the haylard. Do you add a wire haylard on top of the sail which is the same length as the amount of sail that you have reefed? If so, does the ring connect and release from the mast hook easily when you want to raise and lower the sail? I'm want it on my Prindle, but I think the hook and ring is used on many other cats also. Thanks, Jack Hoying Fort Loramie, Ohio Prindle 18 #1645 http://www.bright.net/~jmhoying/sailing/prindle.htm
Jack Hoying
Fort Loramie, Ohio
| | | Re: reefing points
[Re: dave taylor]
#15308 01/13/03 05:08 PM 01/13/03 05:08 PM |
Posts: 1,459 Annapolis,MD | I've thought a bit about the problem of the lower hook messing with the sail when it is fully raised. I think a hook that pivots could be created to fix this.
Think of a hook that can rotate, and has a stop to keep if from rotating further down than 90 degrees to the mast. It could be spring loaded to keep it rotated up against another stop, parallel to the mast and away from the sail when not in use. A small line from it down the mast would be all that would be needed to rotate it down so the ring could hook it - the pressure of the sail would then keep it against the stop. Let off the deployment line, pull the halyard to raise the sail and the hook would return to its position out of the way. If the spring idea is too much trouble, a second line could be added to stow it.
This wouldn't be a hard thing to create, and would make it easier to reef. If you make 'em to sell give me a split of the action...
Another thing I've thought of relates to the functionality of windsurfing sails sold by Multi-Sail (Randy Reynolds' company), in which the lower panels of the sails can be removed via zipper to make a smaller sail. On catamarans with full battens, this would seem to be an easy thing to do - zip off the lower panel leaving a smaller sail that could still have a proper downhaul and outhaul attachment. Roll up the zipped off portion and stow it on the tramp, or in a sail bag tube under the tramp.
I've always felt that it is a huge mistake that our boats don't have the capability to easily reduce sail area. I know we have all these wonderful technics for de-powering and tuning to handle the heavy stuff, but these things often create drag, and if you put a foot wrong you're in trouble. A sail plan properly configured for the conditions at hand would be faster and safer. I'm sure some purists will flame me on this one, so be it. I'll keep my belief that all cats should be able to roller furler their jibs and reef their mains (even if mine can't). | | | Re: reefing points
[Re: thouse]
#15310 01/13/03 10:30 PM 01/13/03 10:30 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | The Hobie 21SC has a roller furling main( it rolls up on the boom). I believe the sail is held up by only the haylard. How do they keep that sail in the track when it's reefed?
Though pricey that system would be nice for cruising.
| | | Re: reefing points
#15313 01/14/03 11:07 AM 01/14/03 11:07 AM |
Posts: 833 St. Louis, MO, | If you have a comptip don't bother trying to use the top hook with an extention. It will definitely pull out. The only time I've seen this work is with all aluminum masts. And even then I wouldn't make any promises.
Mike Hill H20 #791
Mike Hill N20 #1005
267
guests, and 179
