More, more, MORE newbie questions. #153056
08/20/08 06:10 AM
08/20/08 06:10 AM
Winter Garden, FL
I
Iskedarian Offline OP
I
Winter Garden, FL
Still looking our recently acquired H16 over and a couple of other questions come up. Royce's Sailing (GREAT book, by the way) shows a 16 with a cable bridle between the two hulls in front. Our boat has an aluminum bar with a jib reel in the center. Is this an aftermarket add-on or what?
Second question- Several of our sail battens appear to be broken. What's the best replacement material? Polycarb? Aluminum? Marine Ply? I have some nice clear mahogany that I could fashion some out of. Good idea?
Thanks,
Re: More, more, MORE newbie questions. [Re: Iskedarian] #153057
08/20/08 10:28 AM
08/20/08 10:28 AM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
Sounds like a h14 with jib and roller furler(sp)to me. H16s have bridle wires for the jib the h14 uses a spreader bar to help with the forces.
Not sure about using wood for battens, but you can get new fiberglass ones from your Hobie dealer.
[b] Sail Like you have a Pair
Re: More, more, MORE newbie questions. [Re: Iskedarian] #153058
08/20/08 10:28 AM
08/20/08 10:28 AM
Yes - never seen one like that before.
The stock battens are made of fiberglass. I wouldn't use wood. Unless you live on the North Pole, there's no reason not to use what comes with the boat - contact a Hobie Dealer or look on eBay (there's a full set of battens up there now).
0 registered members (), 826 guests, and 42 spiders.
