Adjustable trapeze set up. #154333
09/08/08 02:01 AM
09/08/08 02:01 AM
New Zealand
G
GoGecko Offline OP
GoGecko  Offline OP
G
New Zealand
When I am trapezing upwind I have the trapeze length set for optimum
( so I can line up both hulls across the boat )
BUT when the wind increases and I am trapping from behind the rear beam I am sailing too high on the boat so reducing control or heeling moment or does that not matter.??
Is it worth the extra spaghetti to make the lines longer??
Go Gecko
Re: Adjustable trapeze set up. [Re: GoGecko] #154334
09/08/08 03:44 AM
09/08/08 03:44 AM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Adjustable trapeze set up. [Re: GoGecko] #154335
09/08/08 05:18 AM
09/08/08 05:18 AM
Tornado_ALIVE Offline
Re: Adjustable trapeze set up. [Re: Tornado_ALIVE] #154336
09/08/08 05:33 AM
09/08/08 05:33 AM
Have you done any shopping at Marstrøm the last two years? Curious about your experience when buying stuff from them.
Re: Adjustable trapeze set up. [Re: Rolf_Nilsen] #154337
09/08/08 05:39 AM
09/08/08 05:39 AM
Ordered the adjustable trap set up more then 2 years ago. Ordered a T mast about 5.
Placed the order online, backed it up with email and phone call. Bit of hard work but got there in the end.
Re: Adjustable trapeze set up. [Re: Rolf_Nilsen] #154338
09/08/08 05:40 AM
09/08/08 05:40 AM
You can buy the same kit at Hobiecat Holland's webshop for a lot cheaper.
The aluminum set goes for €67.5 a piece, still a lot cheaper than Marstrom.
http://www.hobiecat.nl/catalog/product_i...v80kdlgpmhoc6u7
Re: Adjustable trapeze set up. [Re: Tony_F18] #154339
09/08/08 06:03 AM
09/08/08 06:03 AM
I believe NACRA also sell them. (Alloy also)
Re: Adjustable trapeze set up. [Re: Tornado_ALIVE] #154340
09/08/08 08:25 AM
09/08/08 08:25 AM
I LOVE my adjustable setup.
It does not cause any extra clutter... but it does leave my dog bones (actually loops) extra slack to flap around. Because of that i have put a plastic clip on the end of my bungee to secure them
Benefits:
i can lower myself (and hike harder) when there is good wind.
I can raise myself in lighter air when (I can save myself from being t-baged in a lull)
I can raise myself when a big wave is coming at me..
I can adjust the slack so I can sit on the tramp (at almost any part of the tramp) attached prior to getting on the wire and tighten the slack to ensure I don’t disconnect while getting out on the wire.
I built my own system and will try to find a picture of it
Re: Adjustable trapeze set up. [Re: ] #154341
09/08/08 08:30 AM
09/08/08 08:30 AM
Here is a pic of my setup.
I have added T handles on the adjuster for easier grip. I found most people use a little ball and that did not do it for me. I left the ball there so the handle doesn’t get jammed in (and out of reacg) if all the way released.
Re: Adjustable trapeze set up. [Re: Tornado_ALIVE] #154342
09/08/08 04:50 PM
09/08/08 04:50 PM
Dazz Offline
Dazz  Offline
I have two issues with this system.
The handle is up so high its almost unusable.
There are so many moving parts that increase the risk of failure.
I am still weighing up the pros and cons.
"Darph Bobo"
Re: Adjustable trapeze set up. [Re: Dazz] #154343
09/08/08 05:06 PM
09/08/08 05:06 PM
Will_R Offline
Will_R  Offline
I have the marstrom system and love it! The handle is the perfect height! the biggest problem is getting the bungie tension just right. if it's too loose the hoop comes off your hook.
Re: Adjustable trapeze set up. [Re: Dazz] #154344
09/09/08 03:34 AM
09/09/08 03:34 AM
Hey Dazz,
if we were trapping low and could not reach the handle, we would just grab the rope above the Marstrom carbon pulley and lift ourself up.
My crew was very tall and that was set up for him. My set up was just out of reach when fully down so had to grab as mentioned above. If you make up new trap lines, make them a little bit longer and take away some of the top end adjustment as you dont tend to use that much.
Re: Adjustable trapeze set up. [Re: Will_R] #154345
09/09/08 05:01 AM
09/09/08 05:01 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
So, what is perfect height for the handle. On my old Drat 18 it was perfect, because I had never to think about the height, unfortunately I didn't measure the height. With my new boat I found the handles to low to go back on the tramp fast. Now I have it about 1m above the deck. It feels unusual but good.
Cheers,
Klaus
Re: Adjustable trapeze set up. [Re: Smiths_Cat] #154346
09/09/08 06:51 AM
09/09/08 06:51 AM
Perfect hight is just in hand's reach when trapping at your lowest point. That comes with trial and error. this is where dyneema traps come in handy. You can make them over lenght and ajust up to what you are comfortable with.
Re: Adjustable trapeze set up. [Re: Tornado_ALIVE] #154347
09/21/08 02:04 AM
09/21/08 02:04 AM
Dazz Offline
Dazz  Offline
Ok...
Just finished making new trap lines that are 250mm longer for the crew and 300mm longer for the skipper (yeah the guy at the back need em longer)
One thing that seems odd, is the cleats are setup to face the boat rather than the crew. any reason for that?
"Darph Bobo"
Re: Adjustable trapeze set up. [Re: Dazz] #154348
09/21/08 07:22 AM
09/21/08 07:22 AM
No, they faced us. You may have to turn around the Marstrom double pully 180 degrees. Unthread the adjustable set up and rethread.
Re: Adjustable trapeze set up. [Re: Dazz] #154349
09/21/08 07:26 AM
09/21/08 07:26 AM
Dazz Offline
Dazz  Offline
you can see them in the photo! the cleats are facing away from your face!
they are all the same. but I will be turning them in that case.
cheers
"Darph Bobo"
Re: Adjustable trapeze set up. [Re: Dazz] #154350
09/21/08 07:47 AM
09/21/08 07:47 AM
LOL.... They are too.
Obviously does not make much difference as I never had any trouble with them.
0 registered members (), 1,276 guests, and 37 spiders.
