| Re: Storm Sail for an A-Class?
[Re: mayhem]
#155069 09/15/08 07:30 AM 09/15/08 07:30 AM |
Posts: 1,226 Atlanta | I doubt this would be class legal Anything less than class max on sail area is indeed legal. You can always go less, at least on the Aclass. The question is would you want to? I dont think I would want to risk a 4k mast on a 25-30knt day, when it gets that windy, its usually choppy and gusty, and the risk of a crash is high. I wouldnt risk my boat. Now, I have taken the HT out when its blowing 30knts sustained, off shore wind and we were ripping upwind. I have a Kevlar main for that boat the Peter Cogan made and I can flatten that thing like a board. You can pull on every string and the sail gets to a certain point and wont move, its flat. We go upwind like a rocket, and its a good time for a reaching run. Randy made an HT main that was reefable, with a wire that attached to the top of the mast, so it could be downhauled. It was a Worrell experiment, he used it once during Midwinters at Rick and Mary's. I dont think it was especially fast, but I cant remember exactly how it sailed. Bill | | | Re: Storm Sail for an A-Class?
[Re: bvining]
#155070 09/15/08 08:57 AM 09/15/08 08:57 AM |
Joined: Sep 2006 Posts: 613 New Hampshire, USA windswept
Posts: 613 New Hampshire, USA | I have a cut down main for my tornado with a wire halyard extension. I have only used it a couple of times in winds above 20 knots. It works well as far as having an under-powered sail, but the downhaul wasn't that effective. I tend not to go out in that much wind, so it was more of an experiment than something to actually race with. I had wanted to be able to go out in heavier winds without worrying about sailing on the edge of control 100% of the time. So if it is blowing above 25 knots, the boat stays ashore now.
Tom Siders A-Cat USA-79 Tornado US775
[Re: mayhem]
#155073 09/17/08 07:58 AM 09/17/08 07:58 AM |
Posts: 1,226 Atlanta | I don't believe it is legal to use two different sails in a regatta series The Acat rule set doesnt have any rule against changing equipment during a regatta, and I've never seen it on any Acat NOR. I think you can change whatever you want, as long as its within the rule set, and its been measured and weighed. http://www.mathran.nl/acat/files/A_Class_Measurement_Guidelines.pdf | | |
1,466
guests, and 43
