| Re: Rudder gantry
[Re: Rolf_Nilsen]
#159967 11/09/08 04:21 PM 11/09/08 04:21 PM | Scarecrow
| Scarecrow
Unregistered | Yes the DS16 is definately intended to be F16 complient. However, at present it is being designed for sailing single handed. By this I don't just mean sail shapes and systems etc but the actual hull form is designed for one person only. | | | Re: Rudder gantry
[Re: Rolf_Nilsen]
#159975 11/09/08 05:16 PM 11/09/08 05:16 PM | Scarecrow
| Scarecrow
Unregistered | Altered is definately the closest comparison. However I suspect it suffered from being cut down and operating at a higher than designed displacement. A one up boat will definately look more A class inspired than the current boats. | | | Re: Rudder gantry
[Re: scooby_simon]
#159980 11/09/08 08:15 PM 11/09/08 08:15 PM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | can also act to increase the effective waterline,
And how does this benefit small, light and fast boats like the 14 and F16 which are well beyond the displacement speed range? Helps to prevent pitchpoles T-foils may/do help to prevent pitchpoles but the question relates to the comment about increasing the effective waterline length claim for T-foils. Waterline length really only helps for vessels in the displacement speed regime. ie. for a 16 foot boat that is speeds less than about 5.5 knots. To clarify, I believe the claim about T-foils near the surface increasing the effective waterline length is too simplistic. A shallow T-foil will have these influences: - Change the wave pattern around the transom - Change the vessel trim (which will also change the wave pattern generated by the boat) - Add drag - Increase pitch, heave and roll motion damping. | | | Re: Rudder gantry
[Re: ncik]
#159985 11/09/08 09:01 PM 11/09/08 09:01 PM | Scarecrow
| Scarecrow
Unregistered | When the 14's were moving to t foils (as against T foils) Bieker who pioneered these foils argued that the foils effected the flow at the transom which was like lengthening the waterline. I've never really looked to closely at it but if you could lengthen the "hole" left by planning this might result in a boat the acted like it had a longer waterline, it would definately increase the "hull speed"
What I have seen in practice is that the boats are generating lift with the rudders up wind and as a result the crews are standing well back. This then allows the bow to become finer and therefor faster through the water. Down wind the finer bow isn't the risk it used to be beacuse the foil can be used to keep the bow up. This is why the foils (or the cases) are made adjustible, so you can get lift upwind (and in low wind down wind) and down force in a blow. | | | Re: Rudder gantry
[Re: ]
#159987 11/09/08 10:09 PM 11/09/08 10:09 PM |
Joined: Dec 2003 Posts: 244 Central Coast NSW Australia TonyJ
Posts: 244 Central Coast NSW Australia | Yes the DS16 is definately intended to be F16 complient. Cool, very cool indeed. Look forward to seeing another F16 in Aus.
Teach them how to think.
Not what to think.
Aus
Blade 002
| | | Re: Rudder gantry
[Re: TonyJ]
#159989 11/09/08 11:03 PM 11/09/08 11:03 PM | Scarecrow
| Scarecrow
Unregistered | Yes the DS16 is definately intended to be F16 complient. Cool, very cool indeed. Look forward to seeing another F16 in Aus. You'll have to be patient Tony, it won't be this summer | | | Re: Rudder gantry
[Re: Stewart]
#160129 11/11/08 07:27 PM 11/11/08 07:27 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | the I14 foils sits below the waterline.. So doesnt increase the actual waterline length.. what it does is theoretically reduces the stern wave.. but how effective it is is debatable. True, the I14 foils are just below the waterline; but point is they are designed to alter/modulate/modify the hull-induced wave pattern. I don't think it's a stretch to envision a design where a long gantry and specialized foil on a rudder can make the water think the boat is longer than it is. I find the concept intriguing. Question is whether on not the class wants to allow boats to go in that direction. And of course how effective such designs are on sailing around a course fast is debatable.
1 registered members (nutsy),
297
guests, and 31
