| Re: Opinions on how to improve today's cat- designs
[Re: dacarls]
#160967 11/20/08 07:03 AM 11/20/08 07:03 AM |
Posts: 1,669 Melbourne, Australia | RE: Tornado Alive--- This is keeping it simple? WOW! Brain damage has been documented!
"No boards, Huge trailer box, 2 complete rigs, inverted mount on trailer..., 2 or 4 mains to choose from" Thanks Carl.... Appreciate your comments  ....... Unit! I an looking at a big beam cat with a lot of horsepower that can be driven very hard off the breeze, un rig and de-rig quickly and be a pleasure to sail on the water. "Keep it simple" ie clean deck layout quick release beams. - so you can have a big beam cat but de-rig quickly. Big trailer box = all your gear can fit in easily and quickly including spin pole. (can mount racks inside for all gear) Quick clap down "no tie" trailer No boards (I did not say that) - Low profile boards so you dont have to keep rasing and lowering like on the F18. Taipan 4.9 and 5.7 have low profile boards as with the Tornado. You do not lift them when you turn downwind on a spinnaker run. Time wasted rasing and lowering would be better served getting the boat up to max speed and maintaining it for as long as possible. Also cleans the deck up not having boards protruding out top. All this in aid of speeding up rigging and derigging. Dismantled = less windage trailering and narrower beam, Rig combinations do take it to another level but imagine a cat you can race when it is cranking 30+ sustained. Perhaps best idea would be just 2 mains. The modern cat rig can depower so efficiently compared to it's monohull couterparts, more than 2 rigs would be unnecessary. Others may have different ideas in what they would like to see in their beach act...... But this would be my ideal ride. I am very fond of the Big T. | | | Re: Opinions on how to improve today's cat- designs
[Re: ThunderMuffin]
#161070 11/21/08 12:20 PM 11/21/08 12:20 PM |
Posts: 235 | A sarcastic cat list: 1. More pitchpoling! 2. Longer daggerboards/centerboards. Whacking sandbars and sea turtles -- and tearing up a $15K investment by simply cracking a sandbar ONCE. Two thumbs up! 3. The heavier the mast, the worst mast-raising setup! 4. Rope everywhere! 5. Vague trailer and beach wheel designs. Crack up the boat in the parking lot while off-loading onto beach wheels! 6. Nothing under 400 lbs! Undecided, cat sailors who are experienced, want this: Make further strides in uncluttering the running rigging. Overtime, my N20 tramp has gone from simple, to spaghetti central. There are two wish lists "to create a new and better cat design". Both wish lists are for performance cats. One is for experienced, the other at an entry level performance boat that will sell in volume and make bigger dealers. No doubt for me that it is something in the 16' range, as I harp.
[Re: bvining]
#161199 11/23/08 10:25 AM 11/23/08 10:25 AM |
Posts: 297 |
But since you brought it up, making hulls out of standard production materials that weigh much less than the current f18 hulls would be easy.
There is no doubt this is true.
The guys from Madison, CT took an old Rorche Acat mold and made a f18, and they had a HARD TIME making it weigh enough. Overbuilt doesnt add anything.
Well, the kids did a great job on that boat. Very impressive. However, one of the hulls did crack about the second time out-repairable. That could be design, or build issue, or just bad luck. I have spent my like sailing in rugged water, and there is something to be said for a weighty designs affording a bit of durability that can lead to longevity. To wit, last year I got caught in too close between the committee boat on a start, and had to bear off, and was T-boned on the starting line (grrr!), but my Infusion was only dented (cosmetic). By contrast, some of those Acats look to be and many are, easily banged up, I don't think that a light design helps there.
Nacra F18 #856
[Re: rexdenton]
#161202 11/23/08 10:45 AM 11/23/08 10:45 AM |
Posts: 1,226 Atlanta |
Well, the kids did a great job on that boat. Very impressive. However, one of the hulls did crack about the second time out-repairable. That could be design, or build issue, or just bad luck. I have spent my like sailing in rugged water, and there is something to be said for a weighty designs affording a bit of durability that can lead to longevity. To wit, last year I got caught in too close between the committee boat on a start, and had to bear off, and was T-boned on the starting line (grrr!), but my Infusion was only dented (cosmetic). By contrast, some of those Acats look to be and many are, easily banged up, I don't think that a light design helps there. yeah, there's a lot of differience between an Acat and a F18. My A is dinged up from racing and its all happened when I was just sitting around between races or when launching. My F18HT has held up pretty well and it sits on the beach full time and gets used by a couple differient people, but yes, I do agree that having a more well built hull is nice. | | | Re: Opinions on how to improve today's cat- designs
[Re: Mary]
#161230 11/23/08 09:53 PM 11/23/08 09:53 PM |
Posts: 1,307 Asuncion, Paraguay | Well, I figure if a planing powerboat can go 240 miles an hour before it disintegrates -- and it does not even dig in and pitchpole -- we are doing something wrong with sailboats.
We should be able to get our center of effort and weight and power back far enough to go faster without pitchpoling.
So if the goal is SPEED, my idea is to have a fore-and-aft track for the mast, so we can move the power back as the wind increases. It's not enough to just rake the mast back farther. Mary, The problem with pitchpoles is related to CE height, not to fore and aft position. Powerboats have their CE just below the waterline level and its CE lever arm is small, so the torque generated is also small. Their problem is the reverse of ours: the propelller's low position actually raises the bow. If you want more speed by means of reducing pitchpoles, it is necessary to add hull buoyancy as far forward as possible and to lower the CE height, but then, for the same area, the sail's aspect ratio is worse, so windward performance is sacrificed.
Luiz
[Re: Luiz]
#161231 11/23/08 10:17 PM 11/23/08 10:17 PM |
Posts: 6,049 Sebring, Florida. | So what about hydrofoils to lift the bows? Luiz has some of those!
Blade F16 #777
[Re: Cheshirecatman]
#161237 11/24/08 04:48 AM 11/24/08 04:48 AM |
Posts: 431 Netherlands | So I mention the "weight" word and all h3ll breaks loose? Some of you guys need to chill out some.
This is from the OP: "I know all the F16 guys will say "make it 70 kilos lighter, and being able to sail one or two up". That's not the point here, I wanna hear propositions that can be applied to all cat designs and sizes..."
So where does my general comment not apply to all cat designs and sizes? I didn't launch an attack on the F18 specifically, and I don't even own an F16 (keep the overreactions up and just might get one though!) If the OP didn't want weight comments, he could have announced that clearly, but that would seem to indicate major prejudice, wouldn't it. I can understand people not wanting their class destroyed by progress, but in the long run, the buck has to stop somewhere to let any real progress take place. Now hold your horses, I'm not saying we should dump F18! its hugely popular in the Netherlands and lots of my buddies are having a great time sailing their fine boats. I don't have a problem with that. My comment about keels is that what is happening here, ie: the thinking, is very much like the way mono hull sailors reacted to cats in the beginning! What I'm saying is you can't talk about progress without considering weight, it's just not logical! Everyone needs to be honest about this AFAIC. Don't worry, I won't mention the W-word again in this discussion, it would obviously be pointless. | | | Re: Opinions on how to improve today's cat- designs
[Re: jimi]
#161247 11/24/08 10:29 AM 11/24/08 10:29 AM |
Posts: 4,119 Northfield Mn | I don't think that anyone would argue that the F18 class is both succesfull, and that the boats are heavy. Making things lighter would be number one on my list of things to do for all boats. Would slowly lowering the weight over 10 years, (or pick a time frame), allow the any of the classes a chance to lower the weight, while keeping older boats competitive through their usefull lives? I don't think we'll be seeing too many 40 year old F18's like we do with the H14/16. Lowering the weight slowly, year one 1 lb, year two 1.5 lbs, year three 2.5lbs, etc. Take 20-25 lbs off gradually as it becomes more viable, then start the process over. I don't think would really render anything obsolete that wouldn't follow that path in due course anyhow. As technology progress's some of the build techniques, and materials may be cost prohibitive now, but what about down the road? Ten years down the road how many of the semi serious teams will be campaigning a vintage boat anyway? | | | Re: Opinions on how to improve today's cat- designs
[Re: Karl_Brogger]
#161265 11/24/08 12:38 PM 11/24/08 12:38 PM |
I still remember the fight we had over the ready to sail F16 weight before we fixed it at 104kg/107kg.
I'm so glad that at that time I made the decision for these weights and stuck to it. For there is one thing I now realize to the fullest extend. There is no way to alter this weight at a later time without getting yourself in a heap of trouble and probably destroy the class at the same time.
#161270 11/24/08 12:47 PM 11/24/08 12:47 PM |
Posts: 3,116 Annapolis, MD | Great Point Cheshire..
I would add . Racing (class building/maintenace) or Sailing coupled to each of your factors.
crac.sailregattas.com
1 registered members (Team_Cat_Fever),
361
guests, and 94
