| Two Masts; One On Each Hull #16234 02/07/03 02:18 PM 02/07/03 02:18 PM |
Posts: 277 Baton Rouge, LA | Two hulls with a mast sprouting from each hull, 60'lg. When it comes to multihulls you have to admire the French. The Extraterrestrial's new boat with twin masts here at Yves Parlier's website. 1. http://www.parlier.org2. Near the top of the page click on "Le Bateau". 3. Then, on the drop down menu cliquez ici: "Les Characteristiques". 4. You can then click on the three thumbnails on that page for full screen renderings of le bateau du E.T. There are also some great shots of the vacuum bagging during construction. Makes me wish I had a BIG garage and bags and bags of Euros to spend. | | | Re: Two Masts; One On Each Hull
[Re: Dean]
#16240 02/10/03 07:59 AM 02/10/03 07:59 AM |
Posts: 2,844 42.904444 N; 88.008586 W | With the 'tom's speedsail', it looks as though we could finally 'fly a hull' -both of them! 'Check the Flaps'!!-Check We have ignition.........
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#16241 02/10/03 11:29 AM 02/10/03 11:29 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Also, pretty cool how they stay the outboard  side of the masts on the twin rig design, by staying the inboard side and using a static connection near the top of the mast for the windward side of the windward-most mast.
[Re: CharlesLeblanc]
#16244 02/25/03 05:10 PM 02/25/03 05:10 PM |
Posts: 12,310 South Carolina | After Kingfisher lost their mast yesterday, I think the designers and sailors will be taking another look at designs like that.
It sure looks like a reaching machine doesn't it?
Jake Kohl | | | Re: short term memory
[Re: majsteve]
#16246 02/25/03 10:25 PM 02/25/03 10:25 PM |
Posts: 12,310 South Carolina | yeah - but they were pushing the fine edge by trying a boat with unstayed masts.
#16247 02/26/03 07:54 AM 02/26/03 07:54 AM |
Joined: Jun 2001 Posts: 90 Québec, Canada CharlesLeblanc
Posts: 90 Québec, Canada | There are a few example of sucessfull boats with unstayed mast The more common example is the Laser 1 Another example is the wite wings the 36' trimaran by Dick Newick http://www.wingo.com/newick/ Finally, the Nonsuch boat http://www.nonsuch.org Let me ask you a question, if you board an airplane, would you feel more secure if the wings were held in place with steel wires... I feel that the unstayed mast are the thing to come on recreationnal boats. It will be much more difficult to install an unstayed mast on a beach catamaran and the extra reinforcements will likely weight more but it could be possible as well. The Team Philips experience was a disaster. The designer went against the trend of all the other race boat and they had little support in the communauty. Team Philips bashing became common. Also, their boat lack testing and ajustement. The concept worked for a while but the boat was lost. It would have been really interesting to see Team Philips in the first part of the race. My feeling is that in medium wind, it could have been faster than the other more conventionnal boats. In the 40th parallele, the situation could have been reversed because I think that the Team Philips boat would have been handicap in bigger waves That is my opinion
Charles Leblanc
Nacra 5.2 #26
| | | Team Philips
#16248 02/26/03 09:43 AM 02/26/03 09:43 AM |
Posts: 1,307 Asuncion, Paraguay | I will quote Bill Roberts on Team Philips: "The best project for the Race"
There was no problem with the project itself - apparently, the carbon construction was improperly executed and the required strength was not achieved.
The boat is good, but was not constructed correctly. Maybe Multiplast could give it a try.
Cheers,
Luiz
| | | Re: Team Philips
[Re: Luiz]
#16249 02/26/03 12:19 PM 02/26/03 12:19 PM |
Posts: 90 Québec, Canada | Luiz The team Philips was my favorite boat for the Race. Unfortunatly, it wasn't ready and it wasn't sailed safely on it's sea trial so the boat was lost. I think that they relied too much on numeric optimizaton of the structure and finite element design and that the boat was too light in many area. I do not think that Multiplast would have been able to get it right because most problems were caused by some design flaws by the architect or by the design team. I do not know if Multiplast would have refused some plans and taken the responsability of changing the desigh. However, the reputation of Multiplast in term on high performance raicing multihull should have been enough to get the designers to change their caiculations It happens when you design a boat out of high modulus carbon fiber. It lack the dampening effect of a softer construction and you can get into problems and faillure on certain structures. My opinion is that it is what happened on this design. The unstayed mast had alot of movement in the headaccording to the small video clips and every occillation was amplified at the base. A softer mast with a lower modulus would have been better and would have put less stress on the mast base. I am starting to work on the plans of my first cruising catamaran and I will try to have an unstayed mast on it. I am confident that it will do better than the Team Philips (well, maybe not in speed  )
Charles Leblanc
Nacra 5.2 #26
| | | Re: Team Philips
[Re: sail7seas]
#16252 02/26/03 07:02 PM 02/26/03 07:02 PM |
Posts: 58 Canberra, Australia | Yes they were out on the sea trials and the centre pod was smacked from underneath by some large waves causing the steering to damage/fail so they couldn't really do much. I read somewhere that they had reached a top speed of 38 knots and the boat felt really strong once the port bow had been stitched back on. Also, the other problem with the design was that the safety pod was in the middle of the vessel and above the hulls. In a capsize the safety pod would be underwater.
Taipan 4.9 AUS129 AlphabetSoup
| | | Another twin mast option
[Re: ABC]
#16253 02/27/03 07:34 AM 02/27/03 07:34 AM |
Posts: 545 Brighton, UK | I am currently reading "Sail Performance" by C. A. Marchaj, and he talks about the crab claw sail being the most efficient sail. This sail configuration also uses two masts. I also found a site which summarises Marchaj's findings and has a picture of a catamaran with this sail config. http://www.schachtdesign.com/proafile/volume_3/options_crab_claw.htmlit makes interesting reading | | |
1 registered members (Team_Cat_Fever),
361
guests, and 94
