| Re: The RAZOR
[Re: phill]
#163817 01/01/09 12:52 PM 01/01/09 12:52 PM |
Posts: 4,451 West coast of Norway | Blade, Taipan, Stealth, Viper and now the RAZOR which I presume will be the "easy build but still good performance" F16. Things are good! We also have one-offs like the boat Ncik did (if it is F16 compliant and sailed as an F16, I dont know for sure?), Altered and the rumours of two other designs coming as well (one from Europe/Germany(?)) and one from a well known marine architect and member of CS.
With so many designs to choose from, both from manufacturers and building plans, the biggest issue now is having parts like masts and beams shipped around the globe.
Phill, way to go! Eagerly waiting for more news about the RAZOR build, and not the least, how it sails when it is done! | | | Re: The RAZOR
[Re: phill]
#163967 01/04/09 01:55 PM 01/04/09 01:55 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | I'm interested in a smaller cat for my kids. Nothing available here really suits--in fact, I sold my Hobie 14 turbo because I just hated it and it was still very heavy for my kids. Building a light 14 footer for them is an option; keep us apprised.
| | | Re: The RAZOR
[Re: phill]
#164032 01/05/09 05:53 AM 01/05/09 05:53 AM |
Posts: 9,582 North-West Europe | Phill and others, The idea behind a 14ft version would be not only quick and easy but cheap. I may even end up building a 14ft for myself.
Over the last months, while playing about with landyachts, I again renewed my desire for a simple small catamaran with a unstayed rig. Just a single sail craft that is easily fully assembled and disassmebled. I'm convinced that a market is to be found for such a craft if its hulls look pleasing enough. Both for kids and adults alike. I too would love to own such a craft fro the small spare hours that I'll be getting in the next years. Not having complex systems like a spi or trap are actually benefits in this concept. Anyway, take this thought as a general reply not as say advice or anything. Best of luck ! Wouter
| | | Re: The RAZOR
[Re: Wouter]
#164093 01/05/09 08:25 PM 01/05/09 08:25 PM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | My mate and I have been building a foiling moth design of his over the holidays. Flat-pack cnc-ed carbon and foam sandwich panels put together in a female mdf jig, with the inside joins taped and frames and bulkheads installed in about 3 hours. Started a week ago and he is fairing the external hull join tapes today, with plenty of mountain biking, missed days and sleeping-in breaking up the build. I estimate about 40 man hours of build time.
Only items left to install are the wand push-rod guide tube and foredeck, should be water-tight and maybe launched by the end of the week, assuming some small parts have been ordered. All other parts are complete from another boat.
The hull build is extremely quick with this method and produces so little dust and fumes. Will definitely consider it, or a modification of this method, for future builds. Maybe flat panel sides and frames with a moulded bottom. There are some big boats being done this way.
Glass or carbon versions of your hull could be popular. | | | Re: The RAZOR
[Re: ncik]
#164120 01/05/09 11:33 PM 01/05/09 11:33 PM |
Posts: 6,049 Sebring, Florida. | Ncik, could you build up two of those moths, join them together and have a foiling cat?
Blade F16 #777
| | | Re: The RAZOR
[Re: Wouter]
#164126 01/06/09 12:30 AM 01/06/09 12:30 AM |
Posts: 1,449 | Just a single sail craft that is easily fully assembled and disassmebled. I'm convinced that a market is to be found for such a craft if its hulls look pleasing enough. Wouter, A 14ft version will essentially be a single sail craft although may have a hooter option. Hooter as opposed to spinnaker for easy of rigging and the ability to use upwind in light air. The hulls seem pleasing enouh to the eye on my PC. I expect the real life one to also look good. However with the amount of sail area I'd want to put on a 14ft version it won't have an unstayed rig. I hope to take some pics of progress on Thursday or Friday. Ncik, I'm beginning to realise how quick this build would be if the parts were CNC cut and it is quite surprising. I have a friend nearby building a CNC machine. I'll have to get on his case and get him to finish it before a 14ft version is built. Regards, Phill
| | | Re: The RAZOR
[Re: phill]
#164128 01/06/09 01:20 AM 01/06/09 01:20 AM |
Posts: 951 Brisbane, Queensland, Australi... | Timbo, it could be done, but easy enough to design dedicated cat hulls. The time consuming to build, or expensive to buy, part is the foils, more than the hulls now-days. And I'm not convinced T-foils are quicker on cats. L'hydroptere dihedral style is the way to go, simpler all-round and probably faster too.
Only problem with CNC is that the larger machines are rarer. We were lucky that the moth fit perfectly on ATL's standard panels and cutter. Larger hulls would require scarfing, but ATL have a system for that too. | | | Re: The RAZOR
[Re: phill]
#165182 01/16/09 08:31 PM 01/16/09 08:31 PM |
Posts: 1,037 Central California | Just a single sail craft that is easily fully assembled and disassmebled. I'm convinced that a market is to be found for such a craft if its hulls look pleasing enough. A 14ft version will essentially be a single sail craft although may have a hooter option. Hooter as opposed to spinnaker for easy of rigging and the ability to use upwind in light air. The hulls seem pleasing enouh to the eye on my PC. I expect the real life one to also look good. However with the amount of sail area I'd want to put on a 14ft version it won't have an unstayed rig. I hope to take some pics of progress on Thursday or Friday. Ncik, I'm beginning to realise how quick this build would be if the parts were CNC cut and it is quite surprising. I have a friend nearby building a CNC machine. I'll have to get on his case and get him to finish it before a 14ft version is built. Regards, Phill any update?
| | | Re: The RAZOR
[Re: phill]
#165196 01/17/09 09:05 AM 01/17/09 09:05 AM |
Joined: Jan 2004 Posts: 196 Arkansas, USA CaptainKirt
Posts: 196 Arkansas, USA | Phill- Don't forget to get some sailing in too!! About the joints- What about utilizing a "step" as in the hydroplane floats, speedboats and some cats at the joint? If you had a bulkhead there it would be even easier if you wanted a significant step, ie more than just the thickness of the hull material.
Kirt
Kirt Simmons Taipan, Flyer
1 registered members (nutsy),
490
guests, and 31
