| Nacra 5.0 #165501 01/21/09 04:15 AM 01/21/09 04:15 AM | Elfish
| Elfish
Unregistered | Hello there
I'm new here and from Switzerland. Unbeatable combo for a very poor english. Please excuse me...
Well, I just got a Nacra 5.0 (mid eighties) for free from my uncle. The boat is in a good condition.
Now I got a few questions because I want to tune my boat up a little bit.
- Is it possible to add a spi with snuffer? - Ist it possible to add a Nacra 500 Squaretop Mainsail? Is it possible to add the new jib form the Nacra 500? - Is there a rigging guide? Or a sail tuning guide?
Thanks in advance for your help.
Cheers from Switzerland
Elfish | | | Re: Nacra 5.0
[Re: ]
#165529 01/21/09 09:56 AM 01/21/09 09:56 AM |
Posts: 168 San Diego | 1. Yes you can add a spin 2. The Nacra 500 main will work but may not be optimal (this has been discussed on the forum), to make the jib work you would need to reposition the fairleads to the main beam (the 500 jib is smaller and non-overlapping). 3. There is a basic rigging guide on the performance catamaran website, and lots of rigging and tuning advice can be found by searching the forums or asking.
Good luck with your new boat. | | | Re: Nacra 5.0
[Re: hokie]
#165808 01/22/09 10:42 PM 01/22/09 10:42 PM |
Posts: 217 | Very old NACRA 5.0 had straight spreaders - I know, I used to have one. So did the old 5.2s. NACRA changed to swept sometime before 87.
| | | Re: Nacra 5.0
[Re: ]
#165823 01/23/09 06:56 AM 01/23/09 06:56 AM |
Posts: 246 Kiel, Germany | Hallo Elfish,
ich hatte ebenfalls einen NACRA 5.0 mit Spi, aber ohne Snuffer. Anstatt dessen hatte ich eine Tasche auf dem Trampolin - keine besonders tolle Lösung. Wenn ich mich recht erinnere hat der NACRA 5.0. die Fockholepunkte auf den Rümpfen - der NACRA 500 aber auf den Beams. Die neue Fock passt nur, wenn Du die Fockholepunkte verlegst: ein ziemlicher Aufwand!
Bezüglich neuem Groß könntest Du den deutschen NACRA-Vertrieb anrufen: +49 40 5249538. Sven kennt beide Boote UND ist Segelmacher, dort solltest Du eine kompetente Antwort bekommen.
Wie auch immer: Du hast da ein tolles Anfängerboot und ich wünsche Dir viel Spaß damit, Kai
F18: C2 / A-Cat: Minelli
| | | Re: Nacra 5.0
[Re: David Parker]
#165851 01/23/09 09:55 AM 01/23/09 09:55 AM | andrewscott
| andrewscott
Unregistered | ????? Don't be so COY Dave! | | | Re: Nacra 5.0
[Re: bobcat]
#165877 01/23/09 11:23 AM 01/23/09 11:23 AM |
Posts: 1,203 uk | The 500 sport uses prebend
| | | Re: Nacra 5.0
[Re: ]
#165939 01/23/09 05:21 PM 01/23/09 05:21 PM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | ????? Don't be so COY Dave! I sail a Nacra 5.0 and I never knew about the Fockholepunkte. I speak fair German but that one is new to me. Andrew, instead of yelling "Starboard!" at you, next time I'll try "Fockholepunkte". | | | Re: Nacra 5.0
[Re: David Parker]
#165946 01/23/09 07:12 PM 01/23/09 07:12 PM |
Posts: 757 japan | [/quote] I sail a Nacra 5.0 and I never knew about the Fockholepunkte. I speak fair German but that one is new to me. Andrew, instead of yelling "Starboard!" at you, next time I'll try "Fockholepunkte".  [/quote] i think it will be more effective as FOCKHOLE.............punkte!
| | | Re: Nacra 5.0
[Re: erice]
#165949 01/23/09 07:33 PM 01/23/09 07:33 PM |
Posts: 3,293 Long Beach, California | I think we just got punkte.
| | | Re: Nacra 5.0
[Re: John Williams]
#165969 01/24/09 08:26 AM 01/24/09 08:26 AM |
Posts: 246 Kiel, Germany | ... okay, okay - I got the message ... German is always good for a joke since we tend to combine several nouns into one word. But since he said he is swiss and his english not that good ... Segelmacher =>sail maker (that one should have been obvious ...) Rümpfe => in this context: hulls
| | | Re: Nacra 5.0
[Re: Baltic]
#165997 01/24/09 05:57 PM 01/24/09 05:57 PM |
Posts: 3,348 | | | | Re: Nacra 5.0
[Re: Baltic]
#166323 01/27/09 12:09 PM 01/27/09 12:09 PM | Elfish
| Elfish
Unregistered | Thanks guys. I've found now mostly all the answers I was looking for...  | | | Re: Nacra 5.0
[Re: David Parker]
#166325 01/27/09 12:38 PM 01/27/09 12:38 PM | andrewscott
| andrewscott
Unregistered | Andrew, instead of yelling "Starboard!" at you, next time I'll try "Fockholepunkte". How about next time you want cut me off and yell "starboard" at me, you wait until we are racing... How about next time you want cut me off and yell "starboard" at me, don't do it infront of a channel marker, so i dont have to put it in reverse to avoid hitting the channel marker How about next time you want cut me off and yell "starboard" at me, you dont do it in front of a channel marker so you don't hit the channel marker.... OR you could just not cut me off..... but that would be boring! ;p | | |
376
guests, and 148
