Mast Dimesions #1650
08/15/01 09:19 PM
08/15/01 09:19 PM
Anonymous OP
Anonymous OP
I'm asking some of the Nacra owners to do a favor....could one of you ( some actually) measure your mast and give me the total length as well as the main shroud attachment point lengths......the diamond wire attachment points would help as well.
<br>
<br>I'm looking to re outfit a Trac 16 and can not find an original mast.....
<br>
<br>Anyone who has a mast around 26 -27 ft tall with diamond wires could help out.
<br>
<br>I appreciate the help
<br>
<br>James Long<br><br>
1658- (19 downloads)
Re: Mast Dimesions #1651
08/16/01 07:28 AM
08/16/01 07:28 AM
Arkansas, USA
Kirt Offline
Kirt  Offline
Arkansas, USA
James-
<br>Why do you want a mast with diamond wires? The only close masts from Nacras would be the 5.0 (perfect fit likely) or 5.2 (a little longer, more common, fitted for boom while 5.0 is boomless). Prindle 16's, Hobie 16's (don't get a comp tip IMO), G-cat 5.0's should all be close to the right length but will be without diamonds. I thought I remembered the Trac 16 w/o diamonds?? I have seen an old (abandoned?) one at Lake Lanier in GA long ago, might check-
<br>
<br>Good luck!
<br>Kirt
<br>(If you need some rudders I've got a brand new set sitting @)<br><br>Kirt Simmons
<br>Taipan #159, "A" cat US 48
1665- (22 downloads)
Kirt Simmons Taipan #159, "A" cat US 48
Re: Mast Dimesions #1652
08/16/01 07:48 AM
08/16/01 07:48 AM
Anonymous OP
Anonymous OP
I have a H17-SE, and the mast is 27'. No diamond wires though. It has a ball-&-socket joint at the attachment to the forward crossbar.
<br>
<br>Andy
<br>H17-SE #284<br><br>
like apples? #1653
08/16/01 12:01 PM
08/16/01 12:01 PM
Sailortect Offline
Sailortect  Offline
stop looking for oranges. I've found you an apple for your apple.
<br>
<br>dunno where you are, but there's an old trac 16 (in nice shape, actually) been sitting on a trailer in the yard at Branford Landing (branford CT) for a few years now. hasn't moved an inch that I've seen. If I pass through there this weekend I'll stop and measure the mast for you. to my recollection, it does have diamond wires.<br><br>
1671- (16 downloads)
Re: Mast Dimesions #1654
08/16/01 03:38 PM
08/16/01 03:38 PM
Québec, Canada
CharlesLeblanc Offline
Québec, Canada
My Nacra 5.7 has a 29'2"mast (exclusing the mast base and the mast head.
<br>
<br>The diamond wires start at 18" from the base, there are 108" to the spreaders and 108" from the spreaders to the top end of the diamond wires
<br>
<br>The shroud are located at 21'2" (20" above the top end diamond wires)
<br>
<br>My suggestion is the following:
<br>
<br>If you have the mast base, simply order the proper length of extruson for your sail and find a mast head that fits. Most mast repair shop can order the anodize mast extrusion of the proper lenght and they could even build one for you.<br><br>Charles Leblanc [color:blue] Nacra 5.7 #123 </font color=blue>
1678- (18 downloads)
Charles Leblanc Nacra 5.2 #26
Re: Mast Dimesions [Re: Kirt] #1655
08/16/01 05:21 PM
08/16/01 05:21 PM
Anonymous OP
Anonymous OP
If you're close to Lake Lanier.....I would give you a finders fee to find a mast (original). Also if the rudders are original...I would be greatly interested.
<br>
<br>James<br><br>
Re: like apples? [Re: Sailortect] #1656
08/16/01 05:23 PM
08/16/01 05:23 PM
Anonymous OP
Anonymous OP
I'll give anyone a finders fee .....for a original mast for sell in the US......So check...and let me know.....
<br>
<br>James<br><br>
Re: Mast Dimesions [Re: CharlesLeblanc] #1657
08/16/01 05:25 PM
08/16/01 05:25 PM
Anonymous OP
Anonymous OP
Charles,
<br>
<br>I've tried that.....Rigright...can't even find the extrusion......They don't know where it was even made at.....I'm tired of waiting on them to get back to me....so I'll go with a used mast.....original or not.
<br>But I appreciate the suggestion.
<br>
<br>James<br><br>
Re: Mast Dimesions #1658
08/16/01 05:28 PM
08/16/01 05:28 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
there are 3 Trac 16's at my club in Columbia SC, and a very nice 16 for sale(1500) at Western Carolina Sail Club in Anderson SC, on Lake Hartwell. Contact aclub member about the boat for sale, I think the webaddress is www.wcsc.org, or . com
<br>Hope this helps, BTW;\
<br>we are having a long distance race around Lake Murray on Sept. 21st. Check out our local sail clubs website for more info.
<br>Dave Mosley,
<br>www.SEACATS.org<br><br>
1683- (19 downloads)
Re: Mast Dimesions #1659
08/16/01 05:45 PM
08/16/01 05:45 PM
Anonymous OP
Anonymous OP
I guess I should let you all know a little about my story.
<br>
<br>I bought this cat with a broken mast...I've owned it about 3 weeks. I have exhausted all avenues (other than the few people here) on finding an original mast or extrusion.
<br>
<br>The cat is not in the best of shape...it has been abused. I got the cat for a steal. I thought I would be able to find the extrusion.....I figured a complete mast to be impossible to find.
<br>
<br>This cat is a 1987 Trac 16 which was boomless. It had diamond wires. ( I have the broken mast)
<br>
<br>The mast sits on a ball.....the mast base is a female socket. Not captive....wish it was.
<br>
<br>All the hardware is Harken and seems to be in pretty good shape. The main looks older.......but seems ok.....the jib is brand new. The main halyard is new.
<br>
<br> It has some blisters near the aft edge of the left hull. Both rudders have been ground off from the road. The hinges for the tiller bar are deteriorated (rubber hinges ....real strange) I'm making delrin hinges now for the tiller bar. ( I build automated machines for a living)
<br>
<br>I would like to make it look good again.....( I'm just that way) It would be great to have something different.
<br>
<br>James
<br>
<br><br><br>
1685- (18 downloads)
Re: Mast Dimesions [Re: dave mosley] #1660
08/16/01 06:56 PM
08/16/01 06:56 PM
Anonymous OP
Anonymous OP
Dave,
<br> Thanks for the info...but I really don't want to buy a whole cat....I greatly inter3ested in fixing the one I got. But what you said is very inspirational. I'm actually in Greenville, SC ....so I'm looking forward to seeing the others locally.
<br>
<br>Thanks for the info anyway.
<br>
<br>James<br><br>
1686- (14 downloads)
Mast extrusions? #1661
08/17/01 10:04 AM
08/17/01 10:04 AM
Serge L. Offline
Serge L.  Offline
So is it possible to find a stock extrusion that would fit H16 mast ends? Any sources for such? I have two bowed masts and have plenty of hardware but no straight stick.
<br>
<br>Thanks,
<br>S.<br><br>
Rubber Hinge #1662
08/17/01 10:23 AM
08/17/01 10:23 AM
Anonymous OP
Anonymous OP
The new Nacra 500 series and Inters use rubber hinges
<br>for the tiller.
<br>You might see if it is the same size first. I payed about
<br>7 bucks for one.<br><br>
1709- (14 downloads)
Re: Mast Dimesions #1663
08/17/01 06:27 PM
08/17/01 06:27 PM
My Nacra 5.2 mast is 28' 0.5" overall (not including the castings). Diamondwires (spreaders are not raked) start 16" from the base and finish at 18' 8.5" from the base. Main eyelette for trap and stay attachement is 8' from the top of the mast.
<br>
<br>I'm also in Greenville, SC - there's a bunch of us out here! We should band together!<br><br>[color:blue][b]Jake
<br>[color:blue][b]Nacra 5.2 (2112)
<br>[color:blue][b]Hobie 18 (???)
1728- (15 downloads)
0 registered members (), 297 guests, and 169 spiders.
