Adjustable Outhaul #166125
01/26/09 08:46 AM
01/26/09 08:46 AM
Pensacola, FL
C
Cab Offline OP
Cab  Offline OP
C
Pensacola, FL
Recently, I crewed on an infusion and it did not have an adjustable outhaul. It just had a short piece of line at the end of the boom that you would loop through the clew. You could adjust it while on the beach or between races but probably not while racing. I was thinking of changing to this system because it was so easy to use. Is anyone adjusting the outhaul when changing from upwind to downwind on a spin boat?
Chris
Trident F16
Re: Adjustable Outhaul [Re: Cab] #166126
01/26/09 08:54 AM
01/26/09 08:54 AM
I always adjust it from upwind to down unless it's really nuclear out (since it could power up the boat more and when surviving is worth more than 1/100th a knot in speed)...I can't really speak for how effective it is - I just have always done it.
Re: Adjustable Outhaul [Re: Cab] #166127
01/26/09 08:54 AM
01/26/09 08:54 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
we do it on every downwind leg. once we go around the A mark, that outhaul goes loose, along with the board up a bit, the mast over rotated, downhaul off, jib out, spin up of course.
Re: Adjustable Outhaul [Re: Cab] #166128
01/26/09 08:55 AM
01/26/09 08:55 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
I quit adjusting the outhaul shortly after I switched to spin boats.
F18 USA 242
http://www.solarwind.solar
Re: Adjustable Outhaul [Re: ThunderMuffin] #166129
01/26/09 09:01 AM
01/26/09 09:01 AM
I dont really see why you would want to adjust it when going downwind with the spin up except for extreme lowwind conditions maybe.
The mainsail doesnt know if its going upwind or downwind, with the apparent wind angle at almost 90°.
Seems like another thing to forget resetting before going upwind. wink
Re: Adjustable Outhaul [Re: Tony_F18] #166136
01/26/09 09:31 AM
01/26/09 09:31 AM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
I used to adjust it until several sailors that know what they are doing explained to me how much releasing the downhaul affects the foot and that they never touch their outhaul.
As you crank your downhaul, the foot will tighten, if you release that tension for downwind your foot will loosen (pretty significantly).
I came to the conclusion that this gave me enough extra shape to not bother with spending time on the outhaul.
Re: Adjustable Outhaul [Re: wildtsail] #166139
01/26/09 09:48 AM
01/26/09 09:48 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
When I used to sail boats like my Prindle 18-2, stock, no spin, it was a must. Outhaul, downhaul, boards, rotator, barberhauler....., every a or c mark. (remember when they had a 'b' mark?)
But with a more recent, spin rigged boat, it's been said.
F-18 Infusion
#626- SOLD it!
Re: Adjustable Outhaul [Re: Cab] #166232
01/26/09 07:24 PM
01/26/09 07:24 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
But on my new raked rig the downhaul stretches the outhaull very quickly so not so much.
But I still adjust to loosen in light for bigger belly.
Re: Adjustable Outhaul [Re: Cab] #166259
01/27/09 01:42 AM
01/27/09 01:42 AM
I can see the reason to have it be set, but sometimes I think it is helpful to really flatten it if you get caught in high winds.
Re: Adjustable Outhaul [Re: Cab] #166269
01/27/09 06:59 AM
01/27/09 06:59 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Outhaul is released automaticaly when the down haul is released because the foot of the sail is angled down at the front.
To set the fixed outhaul right, release it fully,apply max downhaul then set the out haul to firm.
Some guys set the outhaul too tight then go out and gun the downhaul and pull the bottom of the sail out of the track!
Re: Adjustable Outhaul [Re: TEAMVMG] #166277
01/27/09 09:07 AM
01/27/09 09:07 AM
Agreed.
0 registered members (), 1,496 guests, and 28 spiders.
