| Re: Aluminum Alloy used in Hobie Masts?
[Re: MauganN20]
#16615 02/25/03 02:57 PM 02/25/03 02:57 PM |
Posts: 465 FL | | | | Re: Aluminum Alloy used in Hobie Masts?
[Re: MauganN20]
#16617 02/25/03 05:14 PM 02/25/03 05:14 PM |
Posts: 12,310 South Carolina | Yeah - but that's simply brazing a joint just like with copper plumbing...I ~might~ believe their claim to "be stronger than the metal" in a tight tolerance bonding situation but I really doubt it will be in a gap filling scenario.
Jake Kohl | | | Re: Aluminum Alloy used in Hobie Masts?
[Re: MauganN20]
#16621 02/27/03 06:32 AM 02/27/03 06:32 AM |
Posts: 12,310 South Carolina | If you're going to do a job that's worth doing, it's worth doing right (man, I sound like my father).
Seriously though - if you call Hobie, they will advise you against welding on the mast because of the liability. The heat treating process on aluminum is particular and the material properties will be changed for the worse by welding. If you MUST - you should really consider cutting the damage off and riveting a sleeved section back on.
[Re: carlbohannon]
#16624 02/27/03 10:51 AM 02/27/03 10:51 AM |
Posts: 3,114 BANNED | I'd probably rivet it on as well, just to be safe. Thanks for all the suggestions guys. When it comes down to it, I've got two masts. One is this punctured one. The other one is the one I use, its got a slight dent and bend just below the tang. It straightens out under shroud tension, but if I can repair the damaged punctured one, I'd rather do that, because its straighter. Again, thanks for the suggestions. When I called hobie, they wanted to sell me a new mast. | | | Re: Aluminum Alloy used in Hobie Masts?
[Re: MauganN20]
#16625 02/27/03 06:38 PM 02/27/03 06:38 PM |
Posts: 344 Arkansas, USA | Well, I'm surprised no one's mentioned it yet but it's quite common to have tapered Aluminum masts that are purposely cut and welded back to provide the taper. Admittedly this is common at the top of the mast (like on the 30' Sori wingmast I have on my old woodie A-cat from the 80's) where the loads may be lower but that also needs to be the most flexible and still be strong. Don't know where you are but you might try looking for a welder familiar with that technique (there are also some good marine grade welders who fabricate the fishing towers for powerboats or aluminum frames for tops, also some good welders who fabricate/repair the expensive bikes- I know, they are all CF now but the skills should still be around) - Just a thought-
Kirt
Kirt Simmons
Taipan #159, "A" cat US 48
[Re: MauganN20]
#16627 02/28/03 08:48 AM 02/28/03 08:48 AM |
Posts: 344 Arkansas, USA | If he's a certified aircraft welder, and they trust those welds in airplanes- Don't you think they'd be adequate on a sailboat where if the weld fails you might get hurt or your day would be ruined (vs if they fail in a plane more than the rest of your day will likely be ruined!).
Kirt
Kirt Simmons
1,174
guests, and 41
