| Performance Mid-Winters.. #171128 03/10/09 02:28 PM 03/10/09 02:28 PM |
Joined: Jul 2007 Posts: 439 Memphis, TN mikeborden OP
Posts: 439 Memphis, TN | Anyone going to this? CAB? I'm thinking about going, but I won't know for sure if I can go until the last moment, Wednesday. There's other things that I should be doing, but I would like to make it to this regatta. Is there anywhere close and cheap to stay? Or does anyone mind someone crashing? Mike
Viper USA 132
1984 Hobie 18
| | | Re: Performance Mid-Winters..
[Re: mikeborden]
#171176 03/10/09 07:40 PM 03/10/09 07:40 PM |
Posts: 1,246 Orlando, FL | My previous tripsB to Pensacola Beach, I stayed at at condo 3/2 full kitchen for $125 / night .... look at www.vrbo.comoVacation Rentals By Owner. Works great.
USA 777
[Re: mikeborden]
#171392 03/12/09 07:15 AM 03/12/09 07:15 AM |
Posts: 118 Pensacola, FL | Hi Mike, I was going to crew for Andy on his infusion. I think he has found someone else that can crew so I hope to sail my boat. I know Steve is coming over. I think Andy was also considering sailing the viper instead of the infusion. You can stay at my house if you want. I am about 10-15 minutes from the beach.
Chris Trident F16
[Re: Cab]
#171431 03/12/09 10:54 AM 03/12/09 10:54 AM |
Posts: 439 Memphis, TN | Cool, I'm going to send you a pm with some details.
Viper USA 132
1984 Hobie 18
[Re: smiller]
#171567 03/12/09 11:05 PM 03/12/09 11:05 PM | Scarecrow
| Scarecrow
Unregistered | drill them out and replace with rivnuts, that way you'll be able to easily remove them later. | | | Re: Performance Mid-Winters..
[Re: ]
#171906 03/16/09 01:13 PM 03/16/09 01:13 PM |
Posts: 439 Memphis, TN | OK guys, It looks like I'm a go!!!
Anyone else up for it?
Viper USA 132
1984 Hobie 18
[Re: Andy Humphries]
#172002 03/17/09 09:52 AM 03/17/09 09:52 AM |
Posts: 3,116 Annapolis, MD | A rivinut is a special hybrid rivet with a nut at it's core. It requires a special tool to install. It's tough to find a stainless or monel rivnut so it corrodes in the Alu beams. If possible fishing a nut and washer gooped with anticorode on a stick with a wrench is a better long term solution... all be it a huge pain in the butt to install.
crac.sailregattas.com
[Re: Mark Schneider]
#172004 03/17/09 10:48 AM 03/17/09 10:48 AM |
Just use blind rivets and drill them out when you need to replace a part or use stainless steel screws (parkers). The latter are surprisingly strong and the little corroding that does happen between the stainless steel screw and the alu beam prevents further corrosion and locks the screw tightly in place.
Have used the screw option on my spi halyard cleat on my mainbeam. I'm pushing 5 seasons now and no troubles with either loads or corrosion.
359
guests, and 33
