Spinnaker Nesting Unit #172045
03/17/09 04:16 PM
03/17/09 04:16 PM
JACKFLASH Offline OP
On my SX the new chute is a little large for the Nacra hoop and sock and makes launching/retrieving a chore. I was thinking about buying one of the SNU's from Dennis only with a slightly longer bag than an F18. Anybody here care to share their experiences with the SNU or if you other ideas I should consider. Currently I am using a midpole system with three patches. I know I sail a Hobie but it is the snuffer and sock from the Nacra F18 (not infusion). Maybe the new ones are bigger I don't know. Any ideas are appreciated.
Collin Casey
Re: Spinnaker Nesting Unit [Re: JACKFLASH] #172047
03/17/09 04:24 PM
03/17/09 04:24 PM
Love it. Great design. Since it is just a half-ring, it works particularly well for rigs with the separate tack line. I had one on a 2006 Capricorn and will be putting it on the 2009 when it arrives.
Full disclosure: I'll be sailing with Dennis this season. We've teamed up for Nationals.
Re: Spinnaker Nesting Unit [Re: JACKFLASH] #172048
03/17/09 04:24 PM
03/17/09 04:24 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
I love my SNU. My crew is 5' and 100 lbs.. She loves the ease of use. I can also snuff it as I sail. Great product and very nice to use and the manufacturer, Dennis is a sailor Tiger and A cat. I moved my snuffer out 6" past the called for instilation point snuffs easier if you round up a little that way.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
R.Vilvens@yahoo.com
Fairfield, Ca
F-18 5150
Re: Spinnaker Nesting Unit [Re: John Williams] #172055
03/17/09 04:38 PM
03/17/09 04:38 PM
andrewscott
andrewscott
Is that legal in f18 class racing? Just curious... not busting your chops
Re: Spinnaker Nesting Unit [Re: ] #172056
03/17/09 04:41 PM
03/17/09 04:41 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Yes its legal Its not carbon its glass. Its even legal for some one design racing. I race mine in Hobie Tiger all the time. [Linked Image]
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
R.Vilvens@yahoo.com
Fairfield, Ca
F-18 5150
Re: Spinnaker Nesting Unit [Re: F-18 5150] #172062
03/17/09 06:07 PM
03/17/09 06:07 PM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
SNU is great.
Re: Spinnaker Nesting Unit [Re: BLR_0719] #172065
03/17/09 06:48 PM
03/17/09 06:48 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
Collin,
I'm sure you may have, but if not, be sure to check it while it's on land as to all the turning blocks good and all lines moving freely, and nothing bound up anywhere.
Seems like the slightest resistence somewhere can make it real hard to launch/snuff.
good luck
F-18 Infusion
#626- SOLD it!
Re: Spinnaker Nesting Unit [Re: ] #172079
03/17/09 09:38 PM
03/17/09 09:38 PM
Absolutely! F18 is really not that restrictive. They only pick and choose some materials in an attempt to keep cost low and competition among manufacturers high.
Re: Spinnaker Nesting Unit [Re: Jake] #172086
03/17/09 11:19 PM
03/17/09 11:19 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I have a SNU on the HT, and I'm very pleased with it, and Dennis.
Dave
Re: Spinnaker Nesting Unit [Re: davefarmer] #172087
03/17/09 11:56 PM
03/17/09 11:56 PM
F18_VB Offline
F18_VB  Offline
The SNU is awesome. It is the only thing I have done to my F18 that I know has actually changed the result of a race.
Re: Spinnaker Nesting Unit [Re: JACKFLASH] #172106
03/18/09 07:58 AM
03/18/09 07:58 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
When you tie the retreival line to the top patch, do a large bowline or put stopper knot down the line a bit so that all 3 patches don't bunch together and try to go throught the hoop a once.
This will make the snuffed sail longer so sock length may be an issue
Re: Spinnaker Nesting Unit [Re: TEAMVMG] #172122
03/18/09 08:33 AM
03/18/09 08:33 AM
andrewscott
andrewscott
Originally Posted by TEAMVMG
When you tie the retrieval line to the top patch, do a large bowline or put stopper knot down the line a bit so that all 3 patches don't bunch together
I tie a bowline in my top patch, but i also put a stopper ball in the line otherwise my bowline know will pop through the back of the snuffer bag (through the small grommet hole the retrieval line runs through) and i will not be able to pull the spin back out.
Re: Spinnaker Nesting Unit [Re: BLR_0719] #172137
03/18/09 09:29 AM
03/18/09 09:29 AM
Austin, TX
BoK Offline
BoK  Offline
Austin, TX
SNU isn't legal for N20 is it?
9.2a Any Snuffer is considered class legal if purchased through P.S. I., Inc., The spinnaker tack distance from the front beam must remain the same.
Bo Kersey
Corsair 31-1D 276
Re: Spinnaker Nesting Unit [Re: BoK] #172138
03/18/09 09:32 AM
03/18/09 09:32 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
the SNU is not legal for the N20.
Re: Spinnaker Nesting Unit [Re: ThunderMuffin] #172156
03/18/09 10:47 AM
03/18/09 10:47 AM
Unless Performance sells it to you - then it is legal.
Re: Spinnaker Nesting Unit [Re: John Williams] #172172
03/18/09 12:23 PM
03/18/09 12:23 PM
Austin, TX
BoK Offline
BoK  Offline
Austin, TX
Right... I'll have to get a receipt from PSI. I'm sure everyone else has their receipts from PSI for their mid-pole snuffers.... LOL
Bo Kersey
Corsair 31-1D 276
Re: Spinnaker Nesting Unit [Re: BoK] #172173
03/18/09 12:26 PM
03/18/09 12:26 PM
Portland, Maine
Portland, Maine
its fairly obvious when you show up in a N20 in a non-class hoop. They all look, feel, and act the same way.
Re: Spinnaker Nesting Unit [Re: BoK] #172181
03/18/09 01:52 PM
03/18/09 01:52 PM
I have yet to see a Nacra 20 without a factory snuffer...seriously...and I see more than my share of them. Well, that's actually not true...there was that time Larry showed up with a galvanized pipe.
Re: Spinnaker Nesting Unit [Re: Jake] #172190
03/18/09 02:37 PM
03/18/09 02:37 PM
Flesh rocket Larry? Doesn't suprise me..
I think galvanized pipe is slightly heavier than the carbon one?
Re: Spinnaker Nesting Unit [Re: waterbug_wpb] #172198
03/18/09 03:19 PM
03/18/09 03:19 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
My brother has a galvanized pipe "the fence post" for a spin pole too. Oh and get this... it has a spreader bar, you know how delicate the galvanized pipes can be! Yes it's a frankenboat and he loves his multipliers.
Oh, and we don't talk about open class vs. OD/Formula racing at family gatherings anymore.
F18 USA 242
http://www.solarwind.solar
0 registered members (), 622 guests, and 42 spiders.
