| Interesting paper on the foiling moth #172785 03/25/09 04:49 AM 03/25/09 04:49 AM |
Posts: 545 Brighton, UK | | | | Re: Interesting paper on the foiling moth
[Re: grob]
#172803 03/25/09 08:32 AM 03/25/09 08:32 AM |
Posts: 6,049 Sebring, Florida. | Thanks for posting that! Very interesting data and I think we can apply it to our cats. The windward rig leaning for one thing. Do you have any contact information for these guys? I have some questions I'd like to ask them.
Blade F16 #777
[Re: Timbo]
#172889 03/25/09 08:58 PM 03/25/09 08:58 PM |
Posts: 805 Gainesville, FL 32607 USA | Contact John Ilett, Perth. Use International Moth website.
[Re: dacarls]
#172895 03/25/09 10:24 PM 03/25/09 10:24 PM |
Posts: 6,049 Sebring, Florida. | Thanks Dave. Since you have already done some foiling cat work, do you think a V type foil instead of their T foil might work, without all that moveable flap stuff? I was thinking about how the T foil has to be able to shed lift or risk a pop up and crash. A V type foil should self limit as the top of the V comes up through the surface, lift is reduced, right?
Blade F16 #777
[Re: Timbo]
#172901 03/26/09 04:19 AM 03/26/09 04:19 AM |
Posts: 545 Brighton, UK | Sorry for not replying sooner, new baby is preventing a quick response. I didn't have a contact as I got the paper form the boatdesign.net site. John Illet can also be contacted through his website http://www.fastacraft.com/contact.htmlAll the best Gareth | | | Re: Interesting paper on the foiling moth
[Re: grob]
#172915 03/26/09 08:51 AM 03/26/09 08:51 AM |
Posts: 6,049 Sebring, Florida. | Thanks for that, and congrats on the new baby! Now, get some sleep.
Blade F16 #777
[Re: Timbo]
#172976 03/26/09 03:11 PM 03/26/09 03:11 PM |
Posts: 1,307 Asuncion, Paraguay | ...do you think a V type foil instead of their T foil might work, without all that moveable flap stuff? I was thinking about how the T foil has to be able to shed lift or risk a pop up and crash. A V type foil should self limit as the top of the V comes up through the surface, lift is reduced, right? The Moths use T foils because the V foils (Bruce foils) were virtually prohibited by a rule saying that foils could not be attached to the tramps. Besides providing lift, Bruce foils may also increase stability, so the boat could be faster and easier to sail. A good thing about those foils is the smoth ride. They dampen roll, yaw and (depending on the setup) pitch.
Luiz
[Re: Luiz]
#172981 03/26/09 03:52 PM 03/26/09 03:52 PM | Scarecrow
| Scarecrow
Unregistered | Interesting,
using their numbers and the back of an envolope..
if you fitted 2 moth rudder foils upside down to an F16's rudders you'd increase the total drag by about 6% but it would be the equivalent of having another crew member trapping off the transom. This would mean a boat sailing single handed would have a similar top speed to a conventional double hander but maintain it's acceleration advantage. | | | Re: Interesting paper on the foiling moth
[Re: ]
#172982 03/26/09 03:56 PM 03/26/09 03:56 PM |
Posts: 3,528 Looking for a Job, I got credi... | Interesting,
if you fitted 2 moth rudder foils upside down to an F16's rudders you'd increase the total drag by about 6% but it would be the equivalent of having another crew member trapping off the transom. This would mean a boat sailing single handed would have a similar top speed to a conventional double hander but maintain it's acceleration advantage. I've been here before; and firmly believe this to be correct. Loss of job prohibited the build of said boat. Initial discussions were already taking place. Project shelved.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Interesting paper on the foiling moth
[Re: ]
#173000 03/26/09 05:07 PM 03/26/09 05:07 PM |
Posts: 1,307 Asuncion, Paraguay | ...if you fitted 2 moth rudder foils upside down... Ok, negative lift in the rudder works just as well as crew's weight to avoid pitchpoles. I prefer positive lift in a forward placed and smaller area daggerboard, together with a bigger rudder blade, to keep the CLR where it was. Avoid pitchpoles and reduce wet surface, probably with lower total drag.
Luiz
[Re: Luiz]
#173005 03/26/09 05:44 PM 03/26/09 05:44 PM | Scarecrow
| Scarecrow
Unregistered | It's a good argument Luiz, and one I'd be far more likely to use on a boat than the over complicated rudder foil system discussed above. The problem from a practical point of view is that the application is limited by pretty much all the cat classes's rules.
A 20 degree canted dagger board is going to produce approx 30kg of lift at 15 knots but will probably be within 0.5m of the LCF so this is the equivalent longitudinal righting moment of just 7.5 kg at the transom. The 30kg is 20% of an A cats sailing weight, 16% of a one person F16 or 12% of a two person F16 (canted boards are not allowed on F18). The wetted area reduction on the one up F16 will be about 10% however both the dagger boards and the rudders are now bigger than was necessary without canted foil and as a result have increased their drag diminishing the return.
So whats the net result...(on an F16 because there are more options).
Hull and foil drag at down wind (less to more)
one up with canted foils. one up conventional. one up adjustable rudder foils = two up conventional.
Resistance to pitch pole (safest to most dangerous) One up adjustable rudder foils = two up conventional One up Canted dagger boards. One up conventional.
The above is supported by the move in A cats to canted and/or curved foils as it shows a definate advantage in that setup.
The next question becomes what is more important top speed or resistance to pitch pole? As that will decide the future direction of the F16 under its current rules.
[Re: ]
#173190 03/30/09 07:34 AM 03/30/09 07:34 AM |
Posts: 6,049 Sebring, Florida. | Well we could always change the rules, just like the Moths did. But I am not in favor of that as it would start an expensive arms race that would only make the F16 class less attractive to any new members, I think.
What if you put two boards in each hull, both canted inward at what ever angle works best, so they form a lifting V type setup, front and rear, and maybe even add the T foils to the rudders, I wonder if all of that would be enough lift to get the F16 solo up out of the water.
Doing the boards would be the easiest, cheapest mod, then adding the T foil lifting rudders, but all of it could be done without the adjustable flaps they use on the Moth, and you could still pull them all up when you approach the beach. I am not a fan of the T foils on a cat, since we already have the width for stability, I think the V would work better.
I am also trying to figure a way we could tilt our masts to windward as they do on the Moth (with heal), we might be able to do it with dyneema shrouds that go from the tang, down through a block, across the tramp (under it?), through another block and back up to the mast. Just need to figure out how to adjust it and keep it from slipping!
Blade F16 #777
[Re: Timbo]
#173206 03/30/09 08:53 AM 03/30/09 08:53 AM |
Posts: 3,528 Looking for a Job, I got credi... | Well we could always change the rules, just like the Moths did. But I am not in favor of that as it would start an expensive arms race that would only make the F16 class less attractive to any new members, I think.
AS you say, class rules would need to change, currently only one pair of plates on the platform; so one per hill (or two in one hull): [i]1.6 Daggerboards and rudders 1.6.1 The platform shall be equipped with a pair of rudders. 1.6.2 In addition to the rudders, the platform may also be equipped with a pair of daggerboards or centerboards.[/i] Doing the boards would be the easiest, cheapest mod, then adding the T foil lifting rudders, but all of it could be done without the adjustable flaps they use on the Moth, and you could still pull them all up when you approach the beach. I am not a fan of the T foils on a cat, since we already have the width for stability, I think the V would work better.
I am also trying to figure a way we could tilt our masts to windward as they do on the Moth (with heal), we might be able to do it with dyneema shrouds that go from the tang, down through a block, across the tramp (under it?), through another block and back up to the mast. Just need to figure out how to adjust it and keep it from slipping! Tilting the rig is not too difficult. All you need to do is have multi purchase on each shroud base with stoppers to prevent the rig going over the side. Been done on a few boats overhere, catapault being one.
[Re: scooby_simon]
#173208 03/30/09 09:12 AM 03/30/09 09:12 AM |
Posts: 6,049 Sebring, Florida. | I've got to wonder why the A cats haven't done the tilting mast thing yet. As you say, it would be easy to do with a simple block system on each side stay, like an adjustable trap, as long as you put a stopper ball at the end to keep it from going too far out, probably that split forestay would also need to be adjusted? But you could also lead those back to the main beam through blocks, so maybe their rules prevent it?
Dave has already done a foiling A cat, but now with all the carbon stuff, it could probably be done lighter, and faster, but way more expensive, no doubt. And, would it work on the present courses we sail? Would a foiling A cat point upwind as well as a regular A cat? How well do the Moths point? I've never seen one except on You Tube and that wasn't racing upwind.
Blade F16 #777
[Re: ]
#173220 03/30/09 11:14 AM 03/30/09 11:14 AM |
Posts: 1,307 Asuncion, Paraguay | It's a good argument Luiz, and one I'd be far more likely to use on a boat than the over complicated rudder foil system discussed above. The problem from a practical point of view is that the application is limited by pretty much all the cat classes's rules. This configuration is used downwind by ORMA 60s, BMW Oracle, Hydroptere and the like. I just put the concept in words. My boat is far from their leagues, but the configuration is similar. Note that they are all trimarans, not quite the same as beach cats. Still, Bill Robert's ARC20 features smaller daggerboards forward of the main beam and slightly larger rudders. He says that both the increased distance between the foils and the smaller difference between their areas result in lower total drag (besides shalollower draft, naturally). Turbulence / interference between daggerboard and rudder are not an issue in trimarans, so I guess a beach cat benefits more from this configuration. Rules suck. Show up with improvements that result in significant increase in performance or seaworthiness and the rules will follow eventually.
Luiz
[Re: Luiz]
#173222 03/30/09 11:34 AM 03/30/09 11:34 AM |
Posts: 6,049 Sebring, Florida. | I'm with you Luiz on the rules thing, or we would all still be sailing wooden rowboats. Make it faster, and easier to sail fast, and then make the rules to race it!
Blade F16 #777
[Re: Timbo]
#173229 03/30/09 12:09 PM 03/30/09 12:09 PM |
Joined: Jan 2004 Posts: 196 Arkansas, USA CaptainKirt
Posts: 196 Arkansas, USA | The A cats are currently voting on the "hydrofoil" rule- if you look at the"explanation" with the accompanying vote it is stated that at present, with the new rule, allowing canted or curved boards, it is not possible to develop an A cat that will "fly" all the way around the course and this is what the class is trying to prevent. As for the canting mast- if you are asking about "A"'s- What about "C" class cats? I am sure it's been tried in the "A"'s- they have tried everything else- but currently, as pointed out in the A explanation, all the major championships have been won on fairly standard platforms and rigs. One thing one must always remember is there is always a price to pay for any "benefit"- ie a particular setup that may be blazingly fast in 10-15 may be unsailable over that and slower in lighter air- this is apparently proving to be the case with the A's. Canting rigs may be quicker in a long straight line, but less reliable, heavier, slower to tack, etc. Look at Ben Hall's "winged" A-cat- much faster in certain conditions on certain points of sail but not faster over all and much more expensive/harder to rig/etc.
Kirt
Kirt Simmons Taipan, Flyer
[Re: CaptainKirt]
#173293 03/30/09 07:55 PM 03/30/09 07:55 PM |
Posts: 805 Gainesville, FL 32607 USA | A lot of "Stuff" on this post! "V" foils lift the hydrofoiler's lee hull, allowing near vertical mast position. They probably won't go to weather well.
Canting an A-class mast is probably not necessary- they are awfully efficient the way they are today. And who is going to do it by hand? Glen Ashby? Naw.
T-foils are difficult to use to cause lift, needing flaps- hand held at the last best version. I went out last fall with my modern A-cat vs Doran Oster sailing his Rave with hand-held joysticks which did very well in their last National Championship: Fresh breeze- 13-16 mph. I ran all over the Rave while it was reaching on foils. And Raves don't go to weather on foils either. Then I put Rave T-foils on my wooden A-cat- and found the vehicle heavy, but it did come out of the water.
External carbon foils? Interesting idea. You have just described a Palatka-Jacksonville Mug Race boat! Or Randy Smyth's 2-year old Scissors trimaran built on an 20 foot A-cat hull- that is faster than a Tornado.
[Re: ]
#173294 03/30/09 08:01 PM 03/30/09 08:01 PM |
Posts: 805 Gainesville, FL 32607 USA | What? This seems upside down to me. If you want to lift the lee hull to make better speed- just lift the lee hull with a forward-placed lifting foil. (inward canted or new curved A-cat foil) But to hold down a lee hull by putting downforce on the rudder? Insanity!
[Re: dacarls]
#173296 03/30/09 08:09 PM 03/30/09 08:09 PM |
Posts: 6,049 Sebring, Florida. | So when the boat is up on the foils, it doesn't go upwind very well? I was wondering about how well it could point if most of the boat is out of the water, and most of the boards/rudders too. Not much left in the water to keep it from side-slipping. Now that leads to the next issue, if a foiling cat were to be developed, would it need a new type of race course? Instead of upwind, downwind, maybe reach back and forth over a longer course?
Blade F16 #777
1 registered members (nutsy),
490
guests, and 31
