Page 7 of 12 1 2 5 6 7 8 9 11 12
Re: Let's throw the N-20 under the bus thread! [Re: David Ingram] #178892
05/19/09 01:50 PM
05/19/09 01:50 PM
Originally Posted by David Ingram
Todd, what Brian and I tried to do was get a bit more control over the changes that were being released to an OD class, rudders, snuffer system and self tacker and we had zero success. What you guys are thinking about doing is a bit different and I'd think Rick Bliss would be a good source to tap into. Also one of the biggest hurdles you'll run into is apathy. I know the Tybee teams are quite passionate right now but you have a LOT of N20 owners that don't do the Tybee and they may not see the same urgency or any urgency at all. It is an OD class after all, who cares if the sails are dated you're OD and EP has stepped up and appears to be making right by you guys. What you have going for you right now is there isn't another 20 on the market. As Macca and Matt have hinted at if a new 20 hits the market the N20 is the new N6.0 and it will happen over night.
Is your goal in opening up the sail plan for development to sail better against F18’s in the tiny wind band of double trapped spin reaching? If that’s the case why don’t you just create T500 spin rule and leave everything else as is. You can use your sporty flat spins for the T500 and DPN races and your other sails for the OD events. Just keep in mind, if you open up the sail plan you then have the overhead of getting measurement certs, and unless you can work out some kind of in house certification it’s going to be a bit of a pain.
Keep in mind opening up an OD class for development can very much be a double edge sword.
I love this guy...but not in a man on man kind of way...not that there's anything wrong with that.
Re: Let's throw the N-20 under the bus thread! [Re: David Ingram] #178893
05/19/09 01:58 PM
05/19/09 01:58 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Be forewand it's going to be bit more work and frustration than being the Area D North rep.
Yeah, well its going to take a better personality than me to spearhead any change. I'm not saying I'm the right one for either of the jobs (as evidenced by that left jab there :P well played)
Re: Let's throw the N-20 under the bus thread! [Re: ThunderMuffin] #178895
05/19/09 02:20 PM
05/19/09 02:20 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
yeah what's a little boot in the nuts between friends :-)
F18 USA 242
http://www.solarwind.solar
Re: Let's throw the N-20 under the bus thread! [Re: David Ingram] #178897
05/19/09 02:28 PM
05/19/09 02:28 PM
Portland, Maine
Portland, Maine
I've had quite a few over the past week. Between you and Todd I'm worried about my ability to procreate at this point :P
Re: Let's throw the N-20 under the bus thread! [Re: ThunderMuffin] #178899
05/19/09 02:37 PM
05/19/09 02:37 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
Please don't....
Trey
Re: Let's throw the N-20 under the bus thread! [Re: NCSUtrey] #178906
05/19/09 03:19 PM
05/19/09 03:19 PM
Will_R Offline
Will_R  Offline
My thought (for what it's worth) is that IF they decide to push for a new suit of sails is that you specify ONE sail maker. Make sure you can get sails at or less than what PC or EP charges and that every suit that comes out of the loft is the same. Don't end up like the P19MX with everyone makeing their own sails and none of them measureing in.
Discussions with several lofts would have to happen and then settle on what's best for the class. Going to a completely open program would be terrible. This way you could eliminate measuring b/c you have a "certified" class sailmaker.
Re: Let's throw the N-20 under the bus thread! [Re: Will_R] #178937
05/19/09 06:22 PM
05/19/09 06:22 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline OP
Ding ,
Thanks for the help. I spoke with Jack Young today and he recognizes all of my worries, which mirror everything you said. So far on my list I started last night I've got 34 owners and there's many more. Jack said the same thing about sail updates, and thinks that many are content with their old sails. He seems willing to try and help invigorate the class. I'm unemployed (lack of construction work) right now and have a little time to devote to this. I'd love to be racing against you and all the other good F-18 guys ,but I'm not willing to give up my favorite boat ever, to learn a boat that I'd be at a disadvantage from the beginning, until I have zero options. I value your opinion and any help you want to give will be accepted graciously. This stuff ain't my bag, but somebody's gotta do it.
Todd
The new sailing Chinese acrobat.
Isak Dinesen
E. B. White
Re: Let's throw the N-20 under the bus thread! [Re: NCSUtrey] #178938
05/19/09 06:23 PM
05/19/09 06:23 PM
Please don't....
Ditto +10000
Isak Dinesen
E. B. White
Re: Let's throw the N-20 under the bus thread! [Re: Team_Cat_Fever] #178940
05/19/09 06:30 PM
05/19/09 06:30 PM
Clermont, FL, USA
Clermont, FL, USA
Ding ,
Todd
That's what makes you that guy.
F18 USA 242
Re: Let's throw the N-20 under the bus thread! [Re: ThunderMuffin] #178969
05/20/09 03:48 AM
05/20/09 03:48 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
How much difference do you think that it would make to the Inter18 if you put an Infusion rig on it?
It would go a bit better but still get slaughtered in an F18 fleet.
As much as i love it, I am afraid that the N20 is the same generation as the inter18.
Re: Let's throw the N-20 under the bus thread! [Re: TEAMVMG] #178972
05/20/09 06:23 AM
05/20/09 06:23 AM
You may be right, but I don't think it's even close to being maximized right now.
What are the main differences between the Infusion and the Nacra 20 (Hull shape and sail plan)? I know of the wingmast and know that is a benefit for sure, but I and many others would have a hard time taking off a good carbon mast to replace with a lightly tested aluminum mast, until a little more is known. What else? how do the rockers compare? The Infusion makes any boat look like an LR3 (skinny).
I'm just looking for some constructive help not pontification.I think re-building the wheel is fruitless but maximizing that wheel for performance is where we need to be. More importantly the sailors that own these need to sail them, this is the key to building the class.
I hope that anyone who reads this doesn't jump to the conclusion that this class is dwindling ,It's not. at all the big open regattas the N-20 as drawn more boats than any other spin boat.I'd just like to build on that momentum and bump it up a notch.
Todd
Isak Dinesen
E. B. White
Re: Let's throw the N-20 under the bus thread! [Re: Team_Cat_Fever] #178983
05/20/09 08:11 AM
05/20/09 08:11 AM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
Im away for 2 days and I missed the best topic in 5 years of catsailor....Bullswan and Hobie 1616 should take note that this is a sailing website, not a political website. But I bet they dont read the sailing stuff anymore smile
My .02 There is no "NACRA class", get whoever you want to buld your sails within a box rule. Jack's proprietary rule over the NACRA class has to stop somewhere so we can afford to sail the 20's for years to come. He is not going to stop selling you a a $1000 beam because you bought a sail from someone else. Nor is he goig to not sell you a $12000 mast.
The 20's are getting older, and the demand for parts are going to increase over the years, and he will keep selling you those parts at an overpriced rate.
Re: Let's throw the N-20 under the bus thread! [Re: Will_R] #178984
05/20/09 08:17 AM
05/20/09 08:17 AM
Northern Virginia
SoggyCheetoh Offline
Northern Virginia
As a Nacra20 owner, I'm surprised that no one else has broght this up, but my main compliant about the EP sails isn't an outdated sailplan or glued spinnakers blowing up (which sucks), it's the inconsistencies of the sails themselves. I've got 5 different spinnakers, two of which were bought together in 2007. These sails aren't just a little off from each other due to age and blowing out, they are radically different. The 2 new ones that we bought at the same time had luff lengths that varied by 5 inches, the clew positions were different causeing different sheeting angles, on top of that one has an incrediable amount of draft compared to the other. So when picking our spin for this years Tybee, it wasn't a matter of which one we liked best, it was a matter of which one sucked the least.
I've got 3 main sails, two of them are pretty close in size and shape, while the newest one (again bought in 07) has a ton of luff curve forcing me to retune the spreader rack/diamond wire tension everytime I switch sails.
If I could just get an outdated quality sail from EP that was the same cut as everyone else I'd be happy, but when I forced to buy sails from one loft who either doesn't seem to be able or want to deliver quality and consistency, I get rather frustrated.
Alec D.
Pirates of the Chesapeake www.teampiratesofthechesapeake.com
Nacra20 1057 - Crew
F16 Viper 152 - Uni
Re: Let's throw the N-20 under the bus thread! [Re: SoggyCheetoh] #179001
05/20/09 09:43 AM
05/20/09 09:43 AM
interesting you mention that...
I had sail #279 and replaced it with sail #501 about three years later. Sure, the 279 had a Worrell and a lot of other races on it, but would it really stretch that much?
I laid them on top of each other, and just the profile difference was notable. To say nothing of the luff profile.
Just a curious observation.
What methods do sail lofts use to verify tolerances? I've never done that sort of thing...
Re: Let's throw the N-20 under the bus thread! [Re: SoggyCheetoh] #179002
05/20/09 09:46 AM
05/20/09 09:46 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Interesting stuff.
Its a PITA in F18 getting a new sail measured and stamped before you can use it, but the upside is that if it is an odd shape/size, you get to know then and can chuck it back at the sail maker.
Re: Let's throw the N-20 under the bus thread! [Re: TEAMVMG] #179006
05/20/09 10:07 AM
05/20/09 10:07 AM
Portland, Maine
Portland, Maine
WB, Harry told us that the sail panels for the spin anyways, were computer cut.
Re: Let's throw the N-20 under the bus thread! [Re: ThunderMuffin] #179010
05/20/09 10:27 AM
05/20/09 10:27 AM
Southampton UK
NacraKid Offline
NacraKid  Offline
Southampton UK
Most sails are computer cut, the sail maker tells the designer all the details, where the depth and shape is, lengths, curves, roach, type of boat. Then the designer designs it and cuts all the panles out, sail maker then puts it together.
If not computer cut a template is used for each panel for large amount of sails.
Skilled sailmakers can also floor cut one of or the first ones of sails, but that requiers and very good sailmaker.
Re: Let's throw the N-20 under the bus thread! [Re: NacraKid] #179016
05/20/09 10:58 AM
05/20/09 10:58 AM
Will_R Offline
Will_R  Offline
Yeah, but look at the width of the seams. If the person assembling the sail overlaps a little too much or too little, the shape (and size) changes.
Re: Let's throw the N-20 under the bus thread! [Re: Will_R] #179023
05/20/09 11:13 AM
05/20/09 11:13 AM
Northern Virginia
Northern Virginia
BINGO!
Alec D.
Nacra20 1057 - Crew
F16 Viper 152 - Uni
Re: Let's throw the N-20 under the bus thread! [Re: SoggyCheetoh] #179026
05/20/09 11:22 AM
05/20/09 11:22 AM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
Alec
Kudo's to you and Keith.... Great Job!
Were you ever able to get a better shape in that main sail?
I hoped one of the Nacra experts down there had some great ideas.... (short of tearing the sail apart and starting over).
Mark
crac.sailregattas.com
0 registered members (), 671 guests, and 30 spiders.
