Shrouds HOW TIGHT? #182913
06/24/09 07:34 PM
06/24/09 07:34 PM
Grand Rapids, MI
Ron in MI Offline OP
Grand Rapids, MI
I bought a used 16- I know little to nothing about them. I have had a blast the last 2 days on it.
My question this time. I have steped the mast, and tightly attached the front line (forestay?) to the adjuster in front between the bridles (to the two tips of the hulls).
I then snugged up the two shrouds. All three look FAIRLY tight at rest. Now when sailing, the down wind shroud looks VERY LOOSE - (of course the mast is being pushed that way) so I assume this IS normal? Just checking to be sure it's safe.
The mast seems snug, but rotates in the receptical easily.
Or should both shrouds be SNUG/TAUGHT all the time while sailing?
Re: Shrouds HOW TIGHT? [Re: Ron in MI] #183064
06/25/09 01:57 PM
06/25/09 01:57 PM
California
mmiller Offline
mmiller  Offline
California
The forestay should be slack. The jib halyard is what creates rig tension. Jib luff wire holds the forestay load. The jib halyard has a purchase ratio to add significant rig tension.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Shrouds HOW TIGHT? [Re: Ron in MI] #183129
06/25/09 11:14 PM
06/25/09 11:14 PM
No matter how tight you get the jib halyard, the leeward shroud will always be loose when sailing upwind.
It's perfectly normal.
Re: Shrouds HOW TIGHT? [Re: mbounds] #186098
07/24/09 04:06 PM
07/24/09 04:06 PM
Grand Rapids, MI
Grand Rapids, MI
okay - great thanks
0 registered members (), 327 guests, and 197 spiders.
