Prindle 16 Rudder Repair #18372
04/06/03 11:34 PM
04/06/03 11:34 PM
SW Florida, USA
Andrew2003 Offline OP
SW Florida, USA
After about a year of use, the control lines for the rudders on my (wonderful) Prindle 16 are just about cut through in a few places. May I ask three questions? 1. Is this a normal situation? 2. What sort of abrasion resistant lines should I use? and most importantly, 3. Is there a simple way of threading the lines through the internal part of the rudders, something that looks like a difficult task. My manual simply states "thread lines through." Your help would be appreciated!
Re: Prindle 16 Rudder Repair [Re: Andrew2003] #18373
04/07/03 11:11 AM
04/07/03 11:11 AM
Socal
nesdog Offline
nesdog  Offline
Socal
It sounds to me like something is rubbing a bit too much if you went through the lines that fast...unless you are lucky enough to sail everyday and just plain wore them out! I haven't replaced the lines on my P-18 in a looooong time.
To thread the line, I use a straightened out wire hanger. It goes through the end of the tube easily.
Sheldon
P-18
Re: Prindle 16 Rudder Repair [Re: Andrew2003] #18374
04/07/03 09:38 PM
04/07/03 09:38 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
If your old line is not broken ,sew the new line to the old line and pull it through.
Todd A. Hart
Isak Dinesen
E. B. White
0 registered members (), 242 guests, and 29 spiders.
