H20 Tiller Connector #18510
04/11/03 12:26 PM
04/11/03 12:26 PM
Nigel Offline OP
Nigel  Offline OP
Hi, I've got a H20 style Tiller Connector setup on my H17. Can someone please tell me on which side of the boat the screw-in/out adjuster on the tiller goes. I seem to remember reading somewhere that is only should go on one side or the other due to interference or something...it's just that it "seems" to work OK on either end.
Nige H17 6424
Re: H20 Tiller Connector [Re: Nigel] #18511
04/11/03 12:48 PM
04/11/03 12:48 PM
SE Virginia
D Wilkins Offline
D Wilkins  Offline
SE Virginia
Nigel,
Either side will do. It's primary function anyway is just to square the rudders. When I crewed on a H20 we just put it on without really caring.
Good Luck,
Doug W
Re: H20 Tiller Connector [Re: Nigel] #18512
04/11/03 03:39 PM
04/11/03 03:39 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
It doesn't really matter. The only reason to change sides with it is to angle the tiller attachment toward the front or toward the back. Typically people angle the attachment toward the front so that would put the adjuster on the Starboard side.
Mike Hill
H20 #791
Mike Hill
N20 #1005
Re: H20 Tiller Connector [Re: Nigel] #18513
04/13/03 05:14 AM
04/13/03 05:14 AM
trappinout Offline
trappinout  Offline
I use a quick release pin instead of a screw. It works quite nicely.
Tim Imlah Trappinout H20 - 670 G30 - 242
0 registered members (), 297 guests, and 182 spiders.
