How do I adjust mast rake for H16 #185611
07/20/09 02:56 PM
07/20/09 02:56 PM
Southern Illinois
rfarson Offline OP
rfarson  Offline OP
Southern Illinois
I have a Hobie 16 ('86) with stock lines and setup. How can I best adjust mast rake to go a bit faster and tack better. I don't race....
~~~Ron
Re: How do I adjust mast rake for H16 [Re: rfarson] #185622
07/20/09 04:04 PM
07/20/09 04:04 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Move the side stays to a lower hole in the chainplates.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: How do I adjust mast rake for H16 [Re: hobie1616] #185704
07/21/09 01:35 PM
07/21/09 01:35 PM
California
mmiller Offline
mmiller  Offline
California
Rake as far aft as possible for best performance. This helps the boat point higher and the bows from digging in as much.
Set the shrouds lower and tension the jib halyard. Check the main sheeting tension. Repeat until you get the main sheeted hard with little or no gap between the boom and main blocks. Too far aft and the main can not be properly sheeted.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: How do I adjust mast rake for H16 [Re: mmiller] #186034
07/23/09 09:35 PM
07/23/09 09:35 PM
Southern Illinois
rfarson Offline OP
rfarson  Offline OP
Southern Illinois
Thanks I will give it a try....
Ron
~~~Ron
0 registered members (), 411 guests, and 34 spiders.
