| Re: Hardware on a 16 - which is better
[Re: Ron in MI]
#186092 07/24/09 03:53 PM 07/24/09 03:53 PM |
Posts: 160 North Carolina | I would say that since Hobie now uses all Harken blocks on their new boats, that Harken is better. Then again, can you have too many spare parts? I have a harken 6:1 mainsheet system, which you will eventually want as well if you don't have. I can send a pic if you'd like. I like the ratchet in high winds, in the lower stuff I turn it off.
James 1983 Hobie 16'
[Re: hobie1616]
#186122 07/24/09 09:32 PM 07/24/09 09:32 PM |
Joined: Jun 2009 Posts: 22 Grand Rapids, MI Ron in MI OP
Posts: 22 Grand Rapids, MI | Does the harken then have the rachet option? Maybe mine is off. What is the purpose of the rachet? sounds neat, but doesn't seem to be locking anything?
I think the Harken is a 6:1 it's pretty massive, sure - post a pic of yours. Pics are always a plus.
[Re: Ron in MI]
#187283 08/06/09 09:55 PM 08/06/09 09:55 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | If the ratchet is off, the block will spin freely.
This will allow you to either let the sail out really fast if the ratchet is off.
or
Will help with sheeting in if the ratchet is on. The block will only turn in one direction, so there is some friction on the line.
I can almost sheet one handed in light air, but then I run a slightly fatter line.
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
810
guests, and 32
