| Re: water in hull
[Re: Ron in MI]
#186374 07/28/09 03:33 PM 07/28/09 03:33 PM |
Posts: 1,252 California | With that much water.. has to be coming in from a worn keel I would think. Take a look at our FAQ on leak detection. That would help find the cause. http://www.hobiecat.com/community/viewtopic.php?f=18&t=169Main and Jib sheet rigging varies on year / model, so the manual only shows the current main 6:1 and jib systems. Here are two main systems: ![[Linked Image]](http://www.hobieco.com/linked_images/6to1mainsheet.jpg) The H16 Manual The jib system is pretty basic. One continuous line. Starts tied to the jib car. Pass to the clew block and back to the same car, pass through the cleat and then across the trampoline. Pass forward through the cleat, to clew block and back to tie off at the car. | | | Re: water in hull
[Re: tx246]
#186697 08/01/09 06:05 AM 08/01/09 06:05 AM |
Posts: 1,884 Detroit, MI | You can find any major leaks by lightly pressurizing the hull with a compressor (5 lbs or so). NO, NO, NO, NO!Using an air compressor is a good way to blow up your hull. I've seen the results, and there's no fixing it once it's blown. Use a shop vac set on "blow". Do not connect the hose directly to the drain plug hole. Lightly pressurize the hull - it's way less than 5 psi. You want to blow bubbles, not blow up the hull. | | |
297
guests, and 182
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
