by Karl_Brogger. 12/29/24 05:14 PM
fastest point of sail #191206
09/17/09 03:54 PM
09/17/09 03:54 PM
japan
erice Offline OP
erice  Offline OP
japan
interesting polar on the new multi23 trimaran at
http://www.multi23.com.au/
click specifications and then the image at the bottom right
interesting in that it shows 7 different wind speeds and shows that a 90degree beam reach is the most efficient/ fastest in light winds up to 12nts
but as the wind speed climbs over 12nts the fastest point of sail moves off to the 130degree broad reach
less efficient but higher overall speed as presumably as all the buoyancy from a 3 bows is needed to keep the boat from digging in and pitchpoling
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: fastest point of sail [Re: erice] #191211
09/17/09 05:22 PM
09/17/09 05:22 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Screaming reach!!
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: fastest point of sail [Re: erice] #191216
09/17/09 08:02 PM
09/17/09 08:02 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
180 degrees from hobie1616; doesn't matter the relative wind direction. My opinion from his web presence, I am sure he is a nice guy in real life.
Sailing without him, I'd say beam to broad reach. Depends on sails available, hull shape......
Re: fastest point of sail [Re: erice] #191230
09/18/09 01:14 AM
09/18/09 01:14 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
yes, that could imply that the boat is bit of a cow on a beam reach in a breeze!
Re: fastest point of sail [Re: TEAMVMG] #191242
09/18/09 07:31 AM
09/18/09 07:31 AM
On a windy beam reach the lee ama is going to be underwater, slowing the boat down I would think. When you get to that point, I think it would be faster to bear away and use the added lift/support of all 3 hulls, and get all the people to the back of the boat!
Re: fastest point of sail [Re: Timbo] #191259
09/18/09 09:23 AM
09/18/09 09:23 AM
I would think any point of sail in the upright position would be fast.
I know my sails never worked very well in the inverted (underwater) position. Even with the spinnaker up. smile
Re: fastest point of sail [Re: waterbug_wpb] #191270
09/18/09 11:14 AM
09/18/09 11:14 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
....Then you're not playing the current efficiently!!!!
Re: fastest point of sail [Re: ksurfer2] #191282
09/18/09 12:32 PM
09/18/09 12:32 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Haven't you heard of the fifth mode you bunch of donkies!
F18 USA 242
http://www.solarwind.solar
Re: fastest point of sail [Re: David Ingram] #191337
09/19/09 07:41 AM
09/19/09 07:41 AM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
Aaarrrgggg....Multi 23 made in China and the Farrier we do everything best wankers --- can't wait to get back to work on the TMS-20 come on shoulder heal faster!
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: fastest point of sail [Re: ksurfer2] #191492
09/21/09 02:34 PM
09/21/09 02:34 PM
Your sails worked pretty fast, even on their side. At least at Hiram's they did...
Re: fastest point of sail [Re: waterbug_wpb] #191501
09/21/09 03:08 PM
09/21/09 03:08 PM
claus Offline
claus  Offline
I would guess that this polar does not include the kite?
Re: fastest point of sail [Re: waterbug_wpb] #191505
09/21/09 03:16 PM
09/21/09 03:16 PM
andrewscott
andrewscott
Is that flying the tramp?
Re: fastest point of sail [Re: claus] #191518
09/21/09 06:21 PM
09/21/09 06:21 PM
Bet it does!
Roughly beam reaching is fastest. Putting the kite up for down wind means you can travel fast dpwn wind as this is where you want to go, but you also have a lot of drag up too!
The fastest point slowly goes more down wind as the wind increases as the Angle to apparent changes and the ability to use the power also changes!
Re: fastest point of sail [Re: scooby_simon] #191542
09/22/09 12:05 AM
09/22/09 12:05 AM
claus Offline
claus  Offline
The curves at 7 and 10 knots indicate that going dead downwind is fastest with this tri for these wind velocities, which should not happen with a kite (45 sqm!). There is no typical kite lobe, the small max at 130 degrees for 20 knots would be compatible with a genova going downwind.
Re: fastest point of sail [Re: claus] #191662
09/22/09 12:43 PM
09/22/09 12:43 PM
I could maybe see that DDW might work in light windspeeds on that tri. I think the old Nacra 6.0 with "spin-zilla" did great VMG at DDW in under 10 kts.
This strategy didn't work so well with the high aspect spins of the early N20, however.
Re: fastest point of sail [Re: claus] #191674
09/22/09 01:49 PM
09/22/09 01:49 PM
Looking at the curves; it looks like they do not go below 160!
Am I looking at the wrong polars?
Re: fastest point of sail [Re: scooby_simon] #191679
09/22/09 02:28 PM
09/22/09 02:28 PM
claus Offline
claus  Offline
Yes, they only go to 160, put the first derivative is practically zero in the case of 7 and 10 knots, so you expect a smooth behaviour towards 180. Even 160 is practically DDW for a cat/tri. Really thinking that this thing (300 kg and 45 sqm of kite) is only capable of going 5 knots downwind with 10 knots of wind??
Re: fastest point of sail [Re: claus] #191697
09/22/09 03:33 PM
09/22/09 03:33 PM
With an Asym kite; YES.
Re: fastest point of sail [Re: scooby_simon] #191702
09/22/09 04:16 PM
09/22/09 04:16 PM
claus Offline
claus  Offline
According to Bethwaite, this is about a Soling´s vmg speed downwind at 10 knots of wind (see page 333). I'd rather sail on the tri in a race wink
0 registered members (), 175 guests, and 87 spiders.
Posts267,059
