| Hobie 18 traveler #19374 05/06/03 10:04 PM 05/06/03 10:04 PM |
Posts: 12 Madison, WI | I am sick of the crappy Hobie traveler  on my old Hobie 18 so I am thinking about modding the boat. I don't race so class legality has no relevance. I am considering a Harken low profile track affixed to the top of the aft crossbeam and a Harken 1250 Small Boat CB Car w/Pivoting Fixed Sheaves to handle the load. Can anyone comment as to the working load of 1250 lbs and the breaking strength of 2500 lbs? Adequate?? Or should I look at larger components. Anybody else tried this before? Our 18 has the wings and we use it to blast around out midwestern lake. The standard setup is basically useless as a traveler and has taken a lot of the fun out of sailing as it is more of a fight with cranky old gear..... Thanks in advance.........Nelson | | | Re: Hobie 18 traveler
[Re: rotorhead]
#19375 05/07/03 12:13 AM 05/07/03 12:13 AM |
Joined: Dec 2002 Posts: 312 Memphis, Tennessee Damon Linkous
Posts: 312 Memphis, Tennessee | What kind of problems are you having with the stock traveler? It just sounds like you may be fixin to spend a lot of money where you don't have to.
If your traveler doesn't "travel" like it should, find out why. Check the track for debris, corrosion, or build up of gummy residue if you've ever tried to lubricate it. Use some acetone or laquer thinner to clean it, then make sure it is smooth. Inspect your traveler car, the plastic ball and slug can get gummed-up or jagged, they should be clean and smooth. The plastic parts can be replaced. You should not need any lubricant if everything is in good condition, but if you do lube, use only something dry like Sailcote. | | | Re: Hobie 18 traveler
[Re: rotorhead]
#19377 05/07/03 08:11 AM 05/07/03 08:11 AM |
Posts: 12,310 South Carolina | That's a pesky unit - I agree. I have an old TheMightyHobie18 that doesn't appear to have any 'ball' in it. Is there a newer replacement unit?
I'm not sure you can bend the harken track over the curved rear beam of the TheMightyHobie18 without problems with the traveler car.
Jake Kohl | | | Re: Hobie 18 traveler
#19378 05/07/03 08:39 AM 05/07/03 08:39 AM |
Posts: 1,459 Annapolis,MD | No new unit - there's a place for two delrin pieces that fit into the track. The combination that seems most usual is one ball and one slug/slider. Depending on what you want, you could swap the delrin bits for two balls for less friction, or two slugs for more. It's just a matter of getting the bits and taking things apart.
Supposedly the idea was to be able to sheet without causing unwanted movement in the traveler.
I ran one slug one ball. If there was any load on the sheeting system you couldn't travel out easy without first unloading the sheet some. Hearing people talk about playing the traveler on other boats was fun - it was never an option on my 18.
I often thought about putting a track on top of the crossbeam. I think it would work fine. And, because you could always just use the old track and car, you could easily revert to class legal.
I have to admit that on the 20, I have to get used to the free movement of the traveler. That, and the cleat is on the traveler instead of fixed... | | | Re: Hobie 18 traveler
[Re: MutleyCrew]
#19380 05/12/03 11:29 PM 05/12/03 11:29 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | First of all make sure the track has no ruff spots in it. Some times when the delrin wears out and they 're not replaced soon enough the pins will start scaring the track. Lighty sand the track with 400wet and dry paper,then with 600. Then use a alum. polish or a polishing compound and polish the track until it's smooth.
This does two things, makes the thing slide better but more imporantly the smoother surface doesn't wear the delrin as fast. Then you can use the two slugs. One other thing I did with mine was to use a smaller line for the traveler and using a sheet bend attached it to the mainsheet. The smaller line runs through the system much easier.
Have Fun Mike
[Re: h17windbtch6333]
#19383 05/13/03 01:32 PM 05/13/03 01:32 PM |
Posts: 12,310 South Carolina | Yeah, I tie a figure eight knot in my traveler control line to just stop the traveler car from banging the end stopper on the track - it wears the swivel cleat a bit more but those are a lot cheaper. I keep envisioning the stopper being knocked off and the car, complete with all the uncontained bearings, flying off the end of the track.
However, The way I've recently been pushing the sails across just before they would go normally has been resulting in some relatively soft gybes even in serious air.
Jake Kohl | | |
462
guests, and 41
