Page 11 of 11 1 2 9 10 11
Re: Another F16 Blast. .. Very Well Done ! [Re: Wouter] #196884
11/18/09 08:37 PM
11/18/09 08:37 PM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
Fair enough Wouter. I hope your right.
I heard from a reliable source that there Is going to be a more affordable PBO rigging option being released in the very near future. This could be good as well . It will still be more expensive than stainless wire tho.
Aido
Viper 288
Re: Another F16 Blast. .. Very Well Done ! [Re: Aido] #196886
11/18/09 08:50 PM
11/18/09 08:50 PM
Thanks Aido,
Lets leave it at that.
With respect to PBO
Where I am stainless steel rigging is CHEAP ! So stuff like PBO will remain "more expensive" a whole lot longer I'm afraid.
However, "more expensive" does not necessarily equate to "expensive", right ?
Fair winds to you !
Re: Another F16 Blast. .. Very Well Done ! [Re: Wouter] #196892
11/18/09 09:23 PM
11/18/09 09:23 PM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
You should be thanking macca for breathing some life into this forum. And I look forward to hearing about more f16s taking on f18 s and coming out on top. It's getting quite boring here in australia they win all the mixed regattas.
Aido
Viper 288
Re: Another F16 Blast. .. Very Well Done ! [Re: Wouter] #196893
11/18/09 09:23 PM
11/18/09 09:23 PM
The thing that attracts me to rope rigging instead of stainless, is that it doesn't kink. I think I'm going to try making new sidestays for my boat using rope.
Originally Posted by Wouter
If anybody is wondering what I meant earlier by rudder stocks made from bending high grade aluminium tube.
It looks like this :
and it is simple, strong, light and cheap.
(even some non-F16 builder has seen the light in this respect, as this boat is not an F16)
Should've been an F16.
What about billet aluminum? Machine it out of a solid chunk?
Re: Another F16 Blast. .. Very Well Done ! [Re: Karl_Brogger] #196896
11/18/09 09:58 PM
11/18/09 09:58 PM
taipanfc Offline
taipanfc  Offline
Rope is great. Just when packing up found best to do each stay or trapeze separately as the knots can be really annoying to undo when you have 2 or 3 or more lines all tangled together.
Re: Another F16 Blast. .. Very Well Done ! [Re: taipanfc] #196900
11/18/09 10:13 PM
11/18/09 10:13 PM
I think I'd bungee them to the bottom of the mast and leave them on the mast. Right now I strip the forestay, and sidestays off the boat for trailering. I don't like how they rub on the mast, or the tramp when going down the road, but I leave my rope trap lines on and secure them this way.
Re: Another F16 Blast. .. Very Well Done ! [Re: pgp] #196910
11/19/09 02:20 AM
11/19/09 02:20 AM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
I would suggest 4 at a minumum.. in no order.. Blade, Falcon Stealth & Viper and Im guessing with a good crew dont dismiss the Tiapan.. Watch the space more to come I suspect.. crazy
All does look good for the class... If we dont fukc it up with rule changes..
Re: Another F16 Blast. .. Very Well Done ! [Re: Stewart] #196912
11/19/09 04:12 AM
11/19/09 04:12 AM
Netherlands
Hans_Ned_111 Offline
Netherlands
An 80 kg F16 double handed is not possible at this moment, it will be not strong enough even in full carbon.
The loads on A-class are far more different than on a 2 man boat.
Hans
Re: Another F16 Blast. .. Very Well Done ! [Re: Karl_Brogger] #196913
11/19/09 04:14 AM
11/19/09 04:14 AM
Netherlands
Netherlands
The stocks are from the Hobie
Best regards,
Hans Klok
Web : http://www.catamaranparts.nl
Blog : http://catamaranparts.blogspot.nl
Mail : info@catamaranparts.nl
Raptor F16 and A-class builder
Re: Another F16 Blast. .. Very Well Done ! [Re: Wouter] #196915
11/19/09 06:06 AM
11/19/09 06:06 AM
Marcus F16 Offline
Marcus F16  Offline
Simon,
You know what is also missing in those pictures ?
Excessive waste !
Like large drops or rims of resin and filler.
Have you ever looked inside some of the big builder boats.
I must say that Australian Formula Catamarans builds some tidy hulls. This attention to detail and clean working sort of hints at a very high standard of quality control.
Yes - you could eat your breakfast off the inside of our hulls. These hulls are built by a professional, experienced shipwright - not $2/hr labour where quality control does not really exist.
Marcus Towell
Re: Another F16 Blast. .. Very Well Done ! [Re: Wouter] #196916
11/19/09 06:11 AM
11/19/09 06:11 AM
Marcus F16 Offline
Marcus F16  Offline
My FCA blade weighs in at 1.5 kg over minimum with the only carbon being in the foils. You don't need an all carbon boat to reach minimum, that's a myth.
Well done FCA !
I remember the prototype Aussie Blade to be 112.7 at the Global challenge 2007. To see it come down to 108.5kg or just 1.5 kg over minimum without carbon hulls, beams or even a carbon mast is great !
I assume this doesn't include the jib sail and track ?
Put a carbon mast on there and you'll have to carry lead !
For all you forum readers out there, The Aussie Blade F16 hulls are indeed very close in freeboard and volume to the Viper F16 hulls, not to mention the platform is at full F16 width. The same points that are given as the cause for favouring raising the min. class weight.
Wouter - Aus 405 weighed 105.5kgs cat rigged ready to sail.. Only carbon is in the foils
Marcus Towell
Re: Another F16 Blast. .. Very Well Done ! [Re: Hans_Ned_111] #196917
11/19/09 06:13 AM
11/19/09 06:13 AM
Correct, as seen on their iCat.
I now had some time to dig up a pic of the F16 version my huge database of pictures.
The sterns are undoubtably of a VWM Blade F16
Re: Another F16 Blast. .. Very Well Done ! [Re: Karl_Brogger] #196918
11/19/09 06:33 AM
11/19/09 06:33 AM
Karl,
See my post above. I was too lazy yesterday to look for a pic with the F16 version of these stocks.
In short, too heavy and too expensive. Lots of alu waste and owning such a CNC machine costs too. The square tubes come standard and all that is needed is a less expensive bending machine. There is no waste and the tubes are hollow which makes them both strong, stiff and lightweight. I think catamaranparts is welding them and that is a skill, but I've personally made 3D alu objects using aluminium glue and (monel) rivets and that seems to work very well too.
The rivets (or bolts) prevent the glue from being broken by a force splitting/leveraging the components apart, while glue handles all shear force and takes care of all play. If the contact surface is large enough then the glue can handle quite alot of "pulling apart" force as well. It can hold 160 kg per square cm. and that translats to 2279 lbs/sq inch.
My Australian friends told me that home builders used to make such stocks by hand over a hand made timber jig. I think one pours sand in the tube to prevent it from collapsing and just slowly bend it around a curved shape. One that is adjusted for the elastic spring-back.
Re: Another F16 Blast. .. Very Well Done ! [Re: Stewart] #196926
11/19/09 09:09 AM
11/19/09 09:09 AM
M
mini Offline
mini  Offline
M
Yes it does.
The 2 biggest selling points in the f16 class are weight and versatility. Jacking the boat weight does nothing for the growth of the class.
If weight is that important to the Viper owners, then let Greg know. If buyers stop purchasing or push enough, he will build to minimum. His only motive to build as he does now is so he can have 2 models using similar parts, and have cheap Asian builders doing the dirty work. Soon as sales dropped on the Cap - hey we have a new design on the water.
As far as a split to 1 design, there is a long way to go till they have numbers. The Tiger pulled it off for a while, but they had many times more boats and even that has died as the formula concept became stronger and more accepted. Look at the Unicorn in the A class, same deal. yes there were more Vipers at the GC, but those were pre-sold Alter cup boats that the owners had to bring back for that event. Not too many were sailed by their owners. None of the chartered Viper teams is a regular F16 campainer, (Except maybe Brett) There are roughly 60 Blades, 10 Falcons and 20 some Taipans sailing in the US. Pulling a 1 design on a regular basis for the 13 or so Vipers is tough go. Yes France has a lot a cat sailing, but that is not 1 design either. There is a drive for 104, but no one can agree what the rules should be as each manufacturer is trying to make it fit theirs, so it doesnt even exist in form yet. It may or may not ever take off in France, and no where outside of there have I ever read anything about anyone taking up that torch.
The F16 class is a semi-developmental class. There are 3 builders capable of making min or near min weight boats now. 1 builder for economic reasons has elected to show no inovation, even to the point of properly sizing foils, so now there are a few vocal individuals who want to force the class rules to fit them - I do not understand the logic. The Viper is a nice boat and as proved, given the right drivers, weight is somewhat secondary.
So why the push to F-up the class?
Re: Another F16 Blast. .. Very Well Done ! [Re: mini] #197004
11/19/09 01:48 PM
11/19/09 01:48 PM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
What do you mean that no one can agree what te rules can be for 104. Its simple the boat must rate 104. Doesn't get simpler than that.
The F16 that is the long lost topic of this thread was racing as a 104. So although the boat is class compliant f16, its really a victory for the C104. Let me assure you that is does exist. I can see a split down these lines occuring in Euroland very easily. Anyway we can "hopefully" remain ignorant to it and it may go away.
IMO changing the class wieght should have been done when we were talking about it the first time. Its too late now. Just for my own intrest i would like to see the wieghts of the boats at the global challenege published so we have something to aim for.
Aido
Viper 288
Re: Another F16 Blast. .. Very Well Done ! [Re: Aido] #197021
11/19/09 03:16 PM
11/19/09 03:16 PM
Memphis, TN
M
mikeborden Offline
mikeborden  Offline
M
Memphis, TN
I'm not trying to sturr the pot, but I was there at the GC and have some ideas of the boats weighed...
The only boats that I can remember that made the minimum was the Taipan and the Blades....
All other boats were a little over, while the Falcons being closer to the min than the Vipers....
My boat weighed right at 129kgs...Viper 132.
In my opinion...
I think the minimum weight should be left alone...As you can see I have one of the heavier boats and I don't care how much the boats weigh, of course that's within limits here. smile
The box rule is there and this is a semi development class, more so than the F18, but not quite the A-class...
Now, if it starts to turn out like the A-class where something becomes astronomically expensive or something new that makes the boat a whole shitload faster, then maybe we need to rethink the rules. But, even the A-class hasn't made any astronimical strides in the last few years. Hec, even the banana boards haven't made the "older" boats obsolete. Hell, you can get a good A-class that's a few years old, throw a new sail on it, and be competitive....
I was the only singlehander Viper there and I was slow...So tell me, is it the heavy boat or the skipper?
I might just sell my boat and get an older Taipan so I can be faster on the course, cause it's lighter......I should be in the front of the pack, right? cause it's lighter? Right?
Or maybe, just maybe, it's the skipper?
smile
Viper USA 132
1984 Hobie 18
Re: Another F16 Blast. .. Very Well Done ! [Re: Aido] #197036
11/19/09 04:33 PM
11/19/09 04:33 PM
In that case hop over to this thread
http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=197034#Post197034
Re: Another F16 Blast. .. Very Well Done ! [Re: Marcus F16] #197109
11/20/09 07:26 AM
11/20/09 07:26 AM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
I suspect if Jim Boyer was building the Viper then she would be far lighter..
Re: Another F16 Blast. .. Very Well Done ! [Re: mikeborden] #197114
11/20/09 08:13 AM
11/20/09 08:13 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
For a singlehander I have to agree as the Viper is a just a MUCH bigger/ heavier boat then the Taipan. cool Also those dagger boards are always getting in the way (as evident) but this is not an issue with the Taipan. grin
In my opinion...
smile
0 registered members (), 873 guests, and 44 spiders.
