Re: TMS Update 1/2 + 1/2 = hull [Re: TheManShed] #208794
04/18/10 02:54 AM
04/18/10 02:54 AM
Palm Beach County
TheManShed Offline OP
Palm Beach County
My old long board was falling apart and was not stiff enough so I made a new one today. Another problem was the sandpaper strips were peeling off of the ends from flex in the board. Initial test today was good. I used a 3 ply sheet of 1/8” plywood and covered it with one layer of 200 gram carbon uni on one face. This made a stiff board but it had enough flex in it to conform to the shape and spring back straight after I was done. I made it wide enough for three strips of standard air file paper, tacky backed it comes in a roll.
Handles to fit your hands in.
Carbon face
Stiff but it has flex
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: TMS Update 1/2 + 1/2 = hull [Re: TheManShed] #208795
04/18/10 02:58 AM
04/18/10 02:58 AM
Palm Beach County
Palm Beach County
Tested it out with some hand faring on the foam - started to bog the deck.
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: TMS Update 1/2 + 1/2 = hull [Re: TheManShed] #208799
04/18/10 07:39 AM
04/18/10 07:39 AM
This is what you use to fair a hull. Power sanders are nice for getting it into the ballpark - but you can't beat a good long board and a little elbow grease.
Correct stiffness is key and that can change depending on what kind of hull you are working on. You can make a long board out of anything - I managed to find some 4" wide plastic extrusion in a "C" shape (used for conveyor rails) and I placed a piece of 1/8" aluminum inside with some tubing bolted in place (through the aluminum - not the plastic). The UHMW plastic takes sticky back sandpaper well and releases it very well too. You can get rolls of sticky back sandpaper at Lowe's and it's a very economical method...$9 to $12 per roll and they last forever.
Re: TMS Update 1/2 + 1/2 = hull [Re: Jake] #208806
04/18/10 08:18 AM
04/18/10 08:18 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
I used to long block ENTIRE offshore fishing boats when we built them. It is def. the best way to get a fair surface , but for getting out the bulk before it matters that airfile looks sweet, and trust me, after doing one of these you don't want to look at a long block for a long time, if ever.
Running-98 (Small).jpg (186 downloads)
Isak Dinesen
E. B. White
Re: TMS Update 1/2 + 1/2 = hull [Re: Team_Cat_Fever] #208821
04/18/10 04:12 PM
04/18/10 04:12 PM
Palm Beach County
Palm Beach County
You are both right! The in-line air sander is great for rough cutting and shaping, and then you pull out the long board. I'll switch between the two to check fairness. In a small job even the bottoms of a cat you can do a good job with power tools if you have the skill. One thing about power tools a little wobble and a mistake becomes a big problem really fast. But in composites it’s no big deal, an expensive sports car that’s different. I started out doing body work and show cars as a hobby, so I'm very comfortable behind a power tools doing delicate work. I've been faring and sanding for many years. Some people can fair and some cannot – me I can’t sing worth a shoot so I don’t try but I can play a radio!
Tod Nice boat what is it?
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: TMS Update 1/2 + 1/2 = hull [Re: TheManShed] #208822
04/18/10 04:25 PM
04/18/10 04:25 PM
That's a Paul Mann Custom. I didn't work on that exact one ,but built a few just like it while working for Paul Mann Custom boats and Sonny Briggs of Briggs Boatworks.Check out some of the interiors.
http://www.paulmanncustomboats.com/
Isak Dinesen
E. B. White
Re: TMS Update 1/2 + 1/2 = hull [Re: Team_Cat_Fever] #208824
04/18/10 05:03 PM
04/18/10 05:03 PM
Here's this weeks project.
DSCN0118 (Small).JPG (147 downloads)
Isak Dinesen
E. B. White
Re: TMS Update 1/2 + 1/2 = hull [Re: Team_Cat_Fever] #208832
04/18/10 08:11 PM
04/18/10 08:11 PM
Palm Beach County
Palm Beach County
The old bottom job! Looks like just paint and no glass that is good. Yep the in-line air sander would have made it easier.
Today I cut in the bow and faired the decks some more. I need to locate and fit the deck lids so I can cut holes to get forward of the main bulkhead. I need access to finish attaching the bulkheads and tape the hull seams.
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: TMS Update 1/2 + 1/2 = hull [Re: TheManShed] #208876
04/19/10 12:23 PM
04/19/10 12:23 PM
andrewscott
andrewscott
when does she get wet?
Re: TMS Update 1/2 + 1/2 = hull [Re: Team_Cat_Fever] #208877
04/19/10 12:44 PM
04/19/10 12:44 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Todd - that a Hatteras?
Pops used to have a 52' Hatteras.
Re: TMS Update 1/2 + 1/2 = hull [Re: ThunderMuffin] #208880
04/19/10 01:35 PM
04/19/10 01:35 PM
4 posts up.
Isak Dinesen
E. B. White
Re: TMS Update 1/2 + 1/2 = hull [Re: ThunderMuffin] #208891
04/19/10 05:34 PM
04/19/10 05:34 PM
Palm Beach County
Palm Beach County
It started to rain into the shop last night - but that doesn't count. If I can stay unemployed I'm hoping for the end of summer.
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: TMS Update 1/2 + 1/2 = hull [Re: TheManShed] #208905
04/19/10 08:10 PM
04/19/10 08:10 PM
andrewscott
andrewscott
haha.. thats funny.. well you are teaching me tons, and its real cool to see the progress.
Re: TMS Update 1/2 + 1/2 = hull [Re: ] #208913
04/20/10 01:19 AM
04/20/10 01:19 AM
Palm Beach County
Palm Beach County
Thanks!
Andrew I don't suppose everybody wants to stay unemployed but right now the job market sucks so the boat building thing is keeping me going and who knows it may pay off in the future. I get several Email each week on people asking me for help, hints, and questions. The corporate job I had started to get pretty bad and I was getting to the point I did not like to travel. Last year was really good so I'm enjoying the break.
Mike Shappell
www.themanshed.com
TMS-20 Builder
1 registered members (nutsy), 338 guests, and 102 spiders.
