Rudder Cross Bar #209464
04/25/10 03:01 AM
04/25/10 03:01 AM
Melbourne
Nic M Offline OP
Nic M  Offline OP
Melbourne
Hi all,
Nothing as interesting as wrong yardsticks here.....
I am needing to replace the rudder cross bar on the boat, the old one was too flimsy. Can someone please let me know the diameter and wall thickness that has been found to be best.
Many thanks to all.
Nic Maan
Sanity 1815
Re: Rudder Cross Bar [Re: Nic M] #209466
04/25/10 03:51 AM
04/25/10 03:51 AM
Gippsland Lakes
mitchellsailor Offline
Gippsland Lakes
Normal bar;I.D 22mm O.D 25mm which if I'm correct equates a wall thickness of 3mm. Not even Nick Baglioni has been able to break one this size... "Make a spare at the same time then you'll never need it" (Gary Maskiell) smile
If you have the plastic ends with pins on the rudder boxes then drill the holes in the bar as well as the plastic inserts.
*Sligtly different topic, what's everyone's tally of crossbars and tiller extensions this year? I've broken the tips off 2 and today not carrying a spare did the whole shebang. should of listened to Gary
Mosquito 1750 Bonnie-GLYC / Peninsula
The plan was simple.... Like my brother in law Phil, except this plan just might work!
Re: Rudder Cross Bar [Re: mitchellsailor] #209467
04/25/10 06:42 AM
04/25/10 06:42 AM
G
Got Wood Offline
Got Wood  Offline
G
Don't mean to pick at your suggestion but wouldn't it equate to 1.5mm wall thickness? Anyway the stuff you buy from the likes of Goodall, etc.. is 'drawn' aluminium which is a bit stronger than the normal hardware store aluminium. I think the Goodall type tube must be around 1.2mm wall thickness and hardware shop stuff 1.5mm. So I suppose they'd fairly equal at the end of the day, although the hardware stuff is heavier.
Taipan AUS329 'Got Wood'
Mosquito 752 'Sticky Finger'
HARDWOOD RACING TEAM
Re: Rudder Cross Bar [Re: mitchellsailor] #209468
04/25/10 07:21 AM
04/25/10 07:21 AM
Simon C Offline
Simon C  Offline
3 extensions for me blush Alu. of various dimensions. Sat on 1, other 2 went in big McCrae chop, bending at the elbow when getting out on the wire... the ends get caught in a wave and see ya later!
I have gone back to the very attractive orange conduit. Bent one to about 45deg. pulled up, bent it back and still going 2 months later. It has the added advantage that when you find it on the wrong side of the shroud at an inconvenient crazy moment, you can just bend it back round. It gives a slightly sloppy feel to the steering but once you get used to it you don't really notice. Works for me anyway. smile
Simon
Taipan AUS341
Re: Rudder Cross Bar [Re: Got Wood] #209469
04/25/10 07:22 AM
04/25/10 07:22 AM
Melbourne
Nic M Offline OP
Nic M  Offline OP
Melbourne
Many thanks gents.
Best regards.
Nic Maan
Sanity 1815
Re: Rudder Cross Bar [Re: Nic M] #209495
04/25/10 09:59 PM
04/25/10 09:59 PM
Matt_Stone Offline
Matt_Stone  Offline
i have a cross bar that is 1.6 mm wall alloy 1" tube what gary and mitch use, i have put a plastic flush in the end of the tube maybe 3 to 5 mm hanging out and drill in the center of the plastic and put in a Riley swivel and pop rivet it in, to line up rudders ajust the plastic or the swivel till you have measurements right, i found its better to use the riley fittings cos they flex, if you happen to lean on them. plastic cant handle the weight.
Matt
Re: Rudder Cross Bar [Re: Matt_Stone] #209501
04/26/10 02:49 AM
04/26/10 02:49 AM
Adelaide South Australia
ratherbsailing Offline
Hi,
The secret is to get drawn tube not extruded. ask for it. costs the same. difference is that it bends a lot before it breaks. they use this style of tube at AHPC. I have used it for years. Highly recommend for cross bars and spinnaker poles. My last spinnaker pole broke the wire holding the front pole just bent like spaghetti but never broke. Just bent back and used for the rest of the season.
Re: Rudder Cross Bar [Re: ratherbsailing] #209504
04/26/10 03:44 AM
04/26/10 03:44 AM
thricebitten
thricebitten
Hi all,
I guess you can be lucky, but I have broken the 2 AHPC alloy cross bars I have used cry . But I haven't broken the tubes I have been buying pre anodised from my local alloy tube supplier grin , which as was stated has a thicker wall than the AHPC but doesn't bend as much smile (happy to take the weight penalty) crazy , not sure about if it is drawn or not confused .
Re: Rudder Cross Bar [Re: ] #209507
04/26/10 06:38 AM
04/26/10 06:38 AM
Gippsland Lakes
Gippsland Lakes
haha by all means correct the person who is obviously wrong! my bad.... If we're getting picky about weight why not carbon smile
Re: Rudder Cross Bar [Re: mitchellsailor] #209779
04/29/10 05:19 AM
04/29/10 05:19 AM
Cape Town, South Africa
Steve_Kwiksilver Offline
"If we're getting picky about weight why not carbon".
Did that.
Broke that.
grin
Re: Rudder Cross Bar [Re: Steve_Kwiksilver] #209859
04/29/10 04:56 PM
04/29/10 04:56 PM
To windward of you!
Sixth Element Offline
To windward of you!
Did that.
Broke that."
Ive have carbon cross tiller and extension tiller on both my mossies now so like 6 seasons or so and havent had a problem with breakage and have been left hanging off cross tiller several times when pitch poling.
"Sixth Element"
1782 MK2 w/spinnaker.
Lake Bonney Y.C.
National Sec. / S.A President / S.A Measurer / Commodore LBYC
Re: Rudder Cross Bar [Re: Nic M] #217791
08/18/10 06:32 PM
08/18/10 06:32 PM
DickenCider 1777 Offline
JUst a point I found. Dont drill the fitting at the centre, cast or make a block that surrounds the bar. Any hole will corrode and weaken. Never broken a cross bar thats not drilled.
AJ
Re: Rudder Cross Bar [Re: DickenCider 1777] #217924
08/20/10 10:34 PM
08/20/10 10:34 PM
Lake Bonney, SA
dkd Offline
dkd  Offline
Lake Bonney, SA
Aj was mentoined by Nat Prog. we have had carbon cross beams and carbon extension tiller for many years and they have been truly tried and tested, breakages nil, zero, zip, nada
And interestly, fitting attached by bolts with holes drilled straight thro' (opposite to AJs thoughts) and still no breakages.
Sometimes the small extra expense pays dividends in the end.
Salpicon de Resplandor
Mk2 1744, LBYC
Re: Rudder Cross Bar [Re: dkd] #217929
08/21/10 02:43 AM
08/21/10 02:43 AM
Melb. Aust
Trevor Offline
Trevor  Offline
Melb. Aust
... Not to mention that carbon also looks very cool! cool
Mozzie 1828
Sugarloaf Sailing Club
Melbourne
0 registered members (), 223 guests, and 41 spiders.
