Re: Evolution of the soft shackle [Re: pepin] #211447
05/19/10 05:52 PM
05/19/10 05:52 PM
Hillsborough, NC USA
I
Isotope235 Offline OP
I
Well, I finally got around to making some jib bridles based on Pepin's design:
[Linked Image][Linked Image]
This one is sized for a Flying Scot (heresy, I know) which is a growing fleet in my area. I haven' really changed much. I put in a triple brummel in the center eye (so it won't slip no matter which ends you pull), a locking brummel at the button (so it won't slip either), and used a chinese button knot.
Thanks for the idea!
Eric
Re: Evolution of the soft shackle [Re: Isotope235] #211478
05/20/10 07:48 AM
05/20/10 07:48 AM
Daytona Beach
Jeff_Bowers Offline
Jeff_Bowers  Offline
Daytona Beach
Why not just tie the blocks and use the loop/knot arrangement at the jib? Only one atachment point. I have been doing this for 16 years. Never had it come apart, easy to hook up. It can be done with a few knots and no splicing.
Jeff Bowers
Mystere 6.0(sometimes XL)
Re: Evolution of the soft shackle [Re: Jeff_Bowers] #211494
05/20/10 10:13 AM
05/20/10 10:13 AM
But is it sexy?
Re: Evolution of the soft shackle [Re: Jake] #211497
05/20/10 10:23 AM
05/20/10 10:23 AM
andrewscott
andrewscott
But is it sexy?
I just made mine like Jeff suggested but with splices onto the blocks. I think it's pretty sexy smile. was thinking about going into business selling jib tails on the beach smile but i gotta learn how to make that button knot
Re: Evolution of the soft shackle [Re: Jeff_Bowers] #211500
05/20/10 10:52 AM
05/20/10 10:52 AM
I
I
The advantage of having soft shackles at the ends of the pigtails (instead of being tied or spliced directly to the blocks), is that you can remove the jib without having to unreeve the sheets. For those who like to keep their boat as close to rigged as possible, this reduces the effort of setting up and breaking down the boat.
Eric
Re: Evolution of the soft shackle [Re: Isotope235] #211508
05/20/10 12:44 PM
05/20/10 12:44 PM
andrewscott
andrewscott
Eric
I am sure Jeff meant, why not use the soft shackle at the clew vs the blocks (only 1 shackle vs 2)
this is the one i made last weekend.
Re: Evolution of the soft shackle [Re: ] #211539
05/20/10 05:47 PM
05/20/10 05:47 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Ok if the line is Vectran.
If it's UHMWPE (Dyneema/Spectra) chances are that the luggage tag "knot" will slide.
Luiz
Re: Evolution of the soft shackle [Re: ] #211541
05/20/10 06:11 PM
05/20/10 06:11 PM
France
pepin Offline
pepin  Offline
France
this is the one i made last weekend [...]
Because if like me you remove all your jib hardware from the boat if you use your method you need to rethread the jib sheet to go around the mast.
Re: Evolution of the soft shackle [Re: Luiz] #211542
05/20/10 06:26 PM
05/20/10 06:26 PM
vectran sucks IMO unless it is covered and stays covered. uncovered, it Frays and gets fuzzy too quickly
Re: Evolution of the soft shackle [Re: ] #211544
05/20/10 07:07 PM
05/20/10 07:07 PM
I
I
Like this one? I decided to have a little fun and make it from different colors.
As pepin points out, you'd have to make sure the pigtails were in front of the mast before stepping, and you can't remove all the hardware with the mast up (unless you unreeve the sheets).
Eric
Re: Evolution of the soft shackle [Re: Isotope235] #211564
05/20/10 10:44 PM
05/20/10 10:44 PM
andrewscott
andrewscott
Eric
Love it! love the 2 colors!
i plan to remake the soft shackle with either a brummel or eye splice and plan to learn some button ends this week while on vacation.
Pepin makes sense if you remove your hardware
I have used this system for a few years. Yes you have to remember to have your pig tail in front of the mast pre-step, but it's rare l forget, and i can untie 1 line, and correct it in 20-30 seconds or so.. no huge deal
0 registered members (), 1,448 guests, and 26 spiders.
