tilt trailer plans #211842
05/25/10 02:26 PM
05/25/10 02:26 PM
mikekrantz Offline OP
Anyone have a link or resource to tilt trailer plans?
I've found two versions on youtube, Dobb's tilt, and another on thebeachcats.com.
None of them give enough detail to work from. I would think that of all the tornados out there, someone would have a bullet proof version. Or better yet, know of one for sale...
Re: tilt trailer plans [Re: mikekrantz] #211846
05/25/10 02:46 PM
05/25/10 02:46 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
check out Darren Bundock's old Tornado web site. They had a very simple rig for use at home and published plans on their site.
A super delux set of plans for a Tornado Flip trailer that grabs the boat by the cross beams and flips it over are available from Greg Scace or Kevin Cook.
crac.sailregattas.com
Re: tilt trailer plans [Re: mikekrantz] #211851
05/25/10 03:22 PM
05/25/10 03:22 PM
TeamChums Offline
TeamChums  Offline
Mike,
I could build you a BADASS one. Dobb's trailer was pretty nice. I know it pretty well. Just depends on how much you want to spend. It really wont need to be that expensive. I could even start with an existing beach cat trailer and make it fit with a tilting frame.
Lee
Re: tilt trailer plans [Re: TeamChums] #211853
05/25/10 03:40 PM
05/25/10 03:40 PM
Annapolis, MD
Annapolis, MD
Hmm... you really want to use a powerboat trailer... the wheel base is too narrow on a cat trailer... it will flip over in a cross wind. Scace built his for a 60 mph cross wind... tramp on.
Re: tilt trailer plans [Re: Mark Schneider] #211866
05/25/10 05:32 PM
05/25/10 05:32 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Hey Mark,
PM Mike, Greg's number. I told him the other day that was probably the baddest tilt trailer there was. The ballast would be a pain, but there probably is no real way around that and be able to leave the tramp on.
Isak Dinesen
E. B. White
Re: tilt trailer plans [Re: Mark Schneider] #211881
05/25/10 11:39 PM
05/25/10 11:39 PM
TeamChums Offline
TeamChums  Offline
Who said anything about a power boat trailer chief?
Lee
Re: tilt trailer plans [Re: TeamChums] #211902
05/26/10 07:15 AM
05/26/10 07:15 AM
Annapolis, MD
Annapolis, MD
I did...
A beach cat trailer has the axle and wheels set to be inside an 8 foot cat beam.... not so good for 10 foot or whatever wide boat. A beach cat trailer is not a starting point for a tilt cat trailer that will remain right side up.
Re: tilt trailer plans [Re: Mark Schneider] #211914
05/26/10 08:36 AM
05/26/10 08:36 AM
TeamChums Offline
TeamChums  Offline
Wider axles are available.
Lee
Re: tilt trailer plans [Re: mikekrantz] #212178
05/28/10 12:45 PM
05/28/10 12:45 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
My tilt trailer uses a max width torsion beam axle...these can be bought for less than $200 shipped and retrofit to any standard trailer width...that means you can mod any existing trailer to be a stable tilt trailer. This saves money and effort.
FullTiltTrailer Site
My Tilt system uses pivoting cradles on one hull and a single lifting post with a hand winch on the other hull to lift at the mainbeam/hull point. Lifting is a trival matter, taking less than 40 secs once the all is in place. No electric power/hydraulics needs.
I built my trailer competely out of alu with no welds (which de-tempers alloy). Done ~20k miles on it in both tilted and fully disassembled modes. Had it tilted in 20 kt winds with tramp on with no issues.
I have detailed plans available for purchase...pm me if interested.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: tilt trailer plans [Re: Tornado] #248816
05/23/12 09:15 PM
05/23/12 09:15 PM
Tanner mair Offline
Tanner mair  Offline
Hey Mike. I am interested in some building plans for a tornado 20 tilt trailer. Do you still have some for sale??
Re: tilt trailer plans [Re: Mark Schneider] #248818
05/23/12 09:34 PM
05/23/12 09:34 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
I don't agree with that..I modified a standard cat trailer and it works fine. I wouldn't trailer in a 60knot wind anyway...or maybe just take the tramp off..
Re: tilt trailer plans [Re: mikekrantz] #248819
05/23/12 11:51 PM
05/23/12 11:51 PM
Will_R Offline
Will_R  Offline
I've spent a LOT of time towing trailers. Started two days after I got my license with dad teaching me on a trailer with a set of 35' long stainless handrails.
Most my tow time now is with a gooseneck horse trailer and we see plenty of accidents on the side of the road. Most of them are related to an under planned setup; usually too little truck or trailer.
Go with the larger frame.
I do know where a tilt trailer is for sale though.
Re: tilt trailer plans [Re: mikekrantz] #248823
05/24/12 05:39 AM
05/24/12 05:39 AM
jaybird1111 Offline
jaybird1111  Offline
Go here:
http://thebeachcats.com/pictures/?g2_itemId=11313
and see the Tilley tilting trailer. 1. Takes an ordinary cat trailer. 2. Cut the axle and insert piece for max width. 3. Build frame which bolts on. 4. Go wherever. Been using this for 10 or so years now. If it's blowing over 20 or so crosswind, Tami strips the trampoline but even then all the thing does is fishtail some, which is hard on the tires but not really that bad.
Re: tilt trailer plans [Re: jaybird1111] #248824
05/24/12 05:54 AM
05/24/12 05:54 AM
Tornado_ALIVE Offline
Re: tilt trailer plans [Re: mikekrantz] #248825
05/24/12 05:55 AM
05/24/12 05:55 AM
If you want higher res, pm me your email and I will send you.
Re: tilt trailer plans [Re: TeamChums] #248912
05/27/12 09:15 AM
05/27/12 09:15 AM
V
Ventucky Red Offline
V
Mike,
Build it first then sell it... Maybe Mike could distribute them for you.
Re: tilt trailer plans [Re: mikekrantz] #283666
10/20/16 09:28 AM
10/20/16 09:28 AM
G
Ghost Offline
Ghost  Offline
G
This is an old thread, but are the plans for the Tornado Flip trailer that grabs the boat by the cross beams and flips it over are still available? They were supposed to be available from either a Greg Scace or Kevin Cook. I understand there is a complete, detailed, set of CAD drawings for it. Any information would be appreciated, thanks!
Re: tilt trailer plans [Re: mikekrantz] #283668
10/20/16 02:40 PM
10/20/16 02:40 PM
Will_R Offline
Will_R  Offline
Funny, I was looking at the Yahoo Tornado site yesterday looking for them as well.
Re: tilt trailer plans [Re: mikekrantz] #283673
10/22/16 05:19 AM
10/22/16 05:19 AM
Lugoff, South Carolina
Mac McCallum Offline
I have the plans you're talking about I believe. Wanted to make a tilt trailer for my SC20, but didn't do it. Tracked them down from David Tilley. If you want me to forward you the email with them pm me your email address or post it on here.
'09 Viper F16 USA102
A Cat USA 366
0 registered members (), 190 guests, and 92 spiders.
Posts267,059
