| Crew weight corrector weights? #214029 06/17/10 08:16 AM 06/17/10 08:16 AM |
Posts: 887 Crofton, MD | This past Tuesday night I raced with my 10 yr old son and the conditions were such that we double trapped upwind and just walked away. I need to add corrector crew weights since our combined weight is 285#s. Class rules show I need to add 32.5#s. I was thinking of using dive belt weights. The class rules specifiy location and attachment and this may be difficult to acheive. Thoughts? Better yet pictures?
Class Rules: 7.1a Minimum Sailing Weight shall be the weight of the crew at registration, dressed in shorts / t-shirt or swim suit, and barefoot. Normal undergarments may also be worn with the aforementioned clothing. 1. The NACRA 20 Minimum Live Weight shall be 275lbs. consisting of a minimum of two (2) persons. 7.1b Minimum Sailing Weight shall be the Minimum Live Weight plus corrector weights if necessary. 1. The NACRA 20 Minimum Sailing Weight shall be 325lbs; however, for crews requiring more than 25lbs. plus 1/2 of the additional weight required need be carried. 7.1c Corrector Weights; corrector weights shall be attached to the outside of the main beam or within 1 foot aft of the main beam on or in the hulls or trampoline. Weights shall be securely attached to the boat and shall not be moved while racing. Attachment shall be with tape, or by tying with line led thru the weights. Screws, rivets, nuts and bolts are not allowed. Weights must be easily accessible and easy to remove for check-weighing.
| | | Re: Crew weight corrector weights?
[Re: Dlennard]
#214268 06/21/10 08:14 AM 06/21/10 08:14 AM |
Posts: 3,224 Roanoke Island ,N.C. | So you carry weight and still don't have to make minimum? I don't get the logic.
[Re: Dlennard]
#214318 06/22/10 07:30 AM 06/22/10 07:30 AM |
Posts: 887 Crofton, MD | Thanks Dave. Connection suggestions? I was thinking of putting the pieces of lead in pvc pipe and sticking them inside the front beam. After re-reading the rules it appears that this is not allowed since "...outside of the main beam..." is used.
Would the earlier suggestion of attaching to the dolphin strap still be considered the main beam? I could wrap that with tape, not very elegant.
[Re: Chris9]
#214348 06/22/10 10:27 AM 06/22/10 10:27 AM |
Posts: 396 Annapolis Md. | Chris. Add Bella to the crew. She should weigh in at 32 lbs I would think? Or would that create a disruption in the universal harmony of the team? Ed
Still hazey after all these beers. F-16 Falcon #212
[Re: orphan]
#214395 06/22/10 04:23 PM 06/22/10 04:23 PM |
Posts: 3,224 Roanoke Island ,N.C. | 325 - 285 = 40 35 - 25 = 15 / 2 = 7.5 40 + 7.5 = 47.5 pund corrector weight. Crew + corrector (285 + 47.5) = 332.5 Best place in the hull just behind the main beam(if you have access) half the weight in each hull. Attach with line to dagger board well. Second best is at the mast base attached to the from cross bar. Soft Dive weights are best. Cheap alternative is lead shot gun shot. These will not damage body or boat. What's this part? 35 - 25 = 15 / 2 = 7.5
[Re: Team_Cat_Fever]
#214402 06/22/10 07:17 PM 06/22/10 07:17 PM |
Posts: 602 Wilmington,NC | 325 - 285 = 40 35 - 25 = 15 / 2 = 7.5 40 + 7.5 = 47.5 pund corrector weight. Crew + corrector (285 + 47.5) = 332.5 Best place in the hull just behind the main beam(if you have access) half the weight in each hull. Attach with line to dagger board well. Second best is at the mast base attached to the from cross bar. Soft Dive weights are best. Cheap alternative is lead shot gun shot. These will not damage body or boat. What's this part? 35 - 25 = 15 / 2 = 7.5 I like his math. I get used tire weights from the tire dealer ( it is getting harder to get them) melt them down and pull out the steel clips. I melt them down with a propane cooker and a propane torch using a ss pot. Make a mold out of wood or metal and you can cover with tin foil. I make mine about 1 1/2" wide and as long as I need to get the weight I need. You can also do different thicknesses. I tape mine to the dolphin striker strap and have never had a problem. | | | Re: Crew weight corrector weights?
#214445 06/23/10 08:44 AM 06/23/10 08:44 AM |
Joined: Jun 2005 Posts: 302 Daytona Beach Florida orphan
Posts: 302 Daytona Beach Florida | Plus half the weight over 25 pounds. I've got about 40 pound of shoot and lead from when I used to solo the 18. Free to anybody who want to come get it.
[Re: Dlennard]
#214484 06/23/10 12:38 PM 06/23/10 12:38 PM |
Posts: 606 Maryland | 32.5# with or without torn chute....bad news last evening.
Kris Hathaway | | | Re: Crew weight corrector weights?
[Re: Dlennard]
#214512 06/23/10 02:50 PM 06/23/10 02:50 PM |
Posts: 302 Daytona Beach Florida | I interpret the rule to say that if you need to carry more than 25 pounds you will be penalized an additional 1/2 of the weight over 25 pounds. But I may be reading it wrong.
[Re: Kris Hathaway]
#214525 06/23/10 04:14 PM 06/23/10 04:14 PM |
Posts: 396 Annapolis Md. | Chris. Did you make Murph shave his head to save weight or did he botch a rugby match? Ed
[Re: orphan]
#214533 06/23/10 05:29 PM 06/23/10 05:29 PM |
Posts: 3,224 Roanoke Island ,N.C. | I interpret the rule to say that if you need to carry more than 25 pounds you will be penalized an additional 1/2 of the weight over 25 pounds. But I may be reading it wrong. That makes more sense to me.
1,653
guests, and 20
Mod | | Forums26 Topics22,406 Posts267,060 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
