How to reef the main of a Nacra 20 #215706
07/10/10 06:20 PM
07/10/10 06:20 PM
Paulo Offline OP
Paulo  Offline OP
Hello, I live in Brazil and own a Nacra 20. Sometimes I sail alone and I was wondering if there is a "system"to reef the main?! Thanks
Re: How to reef the main of a Nacra 20 [Re: Paulo] #215731
07/11/10 08:47 AM
07/11/10 08:47 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Get a sailmaker to put second tack and clew eyes/d-rings where you want the reef, and some across the new foot so that you can tidy the sail with elastic. just like a Hobie 16 mainsail has got
Make up a wire strop the right length to add in between the headboard and the halyard shackle so that it still hooks over the lock at the masthead. You may need to capsize the boat to get it to hook up.
Don't use the spinnaker if you are reefed
Don't singlehand a 2-hander if you can't right the boat after a capsize
Re: How to reef the main of a Nacra 20 [Re: TEAMVMG] #215929
07/15/10 12:26 PM
07/15/10 12:26 PM
Biggie Offline
Biggie  Offline
If you have the carbon mast,do not increase the load on the carbon luff track.
Re: How to reef the main of a Nacra 20 [Re: Biggie] #216403
07/23/10 01:18 PM
07/23/10 01:18 PM
TeamChums Offline
TeamChums  Offline
I'm puzzled by what you mean by this. How would reefing the main increase the load on the luff track...not to mention the fact that the carbon one is probably stronger than the aluminum one.
Lee
Re: How to reef the main of a Nacra 20 [Re: TeamChums] #216428
07/24/10 12:32 PM
07/24/10 12:32 PM
Biggie Offline
Biggie  Offline
In this arrangement the maisheet load will not be on the halyard hook. But on the luff track, sheet in & the first thing will be OOPS.
Yes, if lay up was a little thicker.
Re: How to reef the main of a Nacra 20 [Re: Biggie] #225793
12/21/10 07:23 PM
12/21/10 07:23 PM
FL
sail7seas Offline
sail7seas  Offline
FL
One could loop a line around the mast and through the grommet in the head of the sail, to prevent pulling out of the track?
Re: How to reef the main of a Nacra 20 [Re: sail7seas] #226370
01/07/11 06:42 AM
01/07/11 06:42 AM
Tasmania
daniel Offline
daniel  Offline
Tasmania
the A class cats use a carbon sleeve around the mast with a 2nd halyard shackle clip on it and a wire strop from this to the top of the mast. they cant reef on water with this system, they have a smaller heavy weather main to use it with.
From Daniel
Miss Beast 1730
Re: How to reef the main of a Nacra 20 [Re: daniel] #226985
01/18/11 10:31 AM
01/18/11 10:31 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
get a recut main that has the top two panels cut off but still attaches to the hook.
0 registered members (), 305 guests, and 46 spiders.
