Hull repair cover up #226663
01/11/11 10:52 PM
01/11/11 10:52 PM
Brandon, FL
JonT82 Offline OP
JonT82  Offline OP
Brandon, FL
Hello all..I aquired a 79 H16 for free from a customer of mine and I followed the steps for the epoxy injections for the soft spots. I was wondering whats the best way to cover the holes from the repair? Planing on painting the hulls as well when I have the money. Also I was wondering about the shroud cables. The cable itself seems to be in good shape but the outer coating has broken in some places. Is that a sign to be replaced? Love the forums and all the information from this site!!
Re: Hull repair cover up [Re: JonT82] #226693
01/12/11 03:40 PM
01/12/11 03:40 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
You probably mean the plastic covering on the shrouds. The plastic is there to protect the main sail from wear. You can get snap on replacements.
That said if you don't know the age of the standing rigging it might be good insurance to replace them even if they look good.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Hull repair cover up [Re: JonT82] #226695
01/12/11 03:43 PM
01/12/11 03:43 PM
California
mmiller Offline
mmiller  Offline
California
You can fill with an epoxy putty and then sand if you are going to paint.
If the shroud's plastic covering is molded on type (vinyl) rather than the kind that is split and slides on a bare wire (which is less UV stable)... they must be pretty old. If the covers are the slip on type... maybe the wires are not too old, but still, I'd replace all the standing rigging if in doubt.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Hull repair cover up [Re: mmiller] #226700
01/12/11 04:19 PM
01/12/11 04:19 PM
Brandon, FL
JonT82 Offline OP
JonT82  Offline OP
Brandon, FL
Thanks for the replies..yea I guess i'll just replace the rigging cause I really dont know how old it is. Better safe than sorry.
Re: Hull repair cover up [Re: JonT82] #226880
01/16/11 05:23 PM
01/16/11 05:23 PM
hobie1616 Offline
hobie1616  Offline
Word!
Re: Hull repair cover up [Re: hobie1616] #231227
04/17/11 03:45 PM
04/17/11 03:45 PM
Mike Siddle Offline
Mike Siddle  Offline
Always follow the manufacturer’s advice as regards to the bottom paint. Remember that most of these paints never go over top of varnish. Done well, a polished, glossy red bottom on a good cedar strip hull can look excellent, and cover up a lot of woes.
Absolute Steel— Steel building and carport kits with nationwide jobsite delivery. Easy DIY—America’s easiest to install building system. Watch this video.
0 registered members (), 269 guests, and 24 spiders.
